Har brukt ZHA til nå, men ønsker å forsøke Zigbee2MQTT isteden. Men har problemer med å sette opp Zigbee2MQTT og trenger derfor litt hjelp. Bruker Home Assistant Cloud (Nabu Casa) om det skulle bety noe. Hva gjør jeg feil?
Mosquitto broker er startet med standard konfigurasjon.
certfile: fullchain.pem
customize:
  active: false
  folder: mosquitto
keyfile: privkey.pem
logins: []
require_certificate: true
MQTT integrasjonen er installert.
I konfigurasjonen til Zigbee2MQTT har jeg skrevet dette.
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: '-d -d'
  log: false
mqtt:
  server: mqtt://localhost:1883
serial:
  port: /dev/ttyUSB0
permit_join: true
frontend:
  port: 8080
Jeg bruker en Sonoff Zigbee 3.0 dongle og den er funnet her.
ttyUSB0
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b04a1db9ea5fec119e5c395f25bfaa52-if00-port0
Zigbee2MQTT logg ser sånn ut.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[08:30:56] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[08:30:57] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Zigbee2MQTT:info  2022-04-10 08:31:03: Logging to console and directory: '/config/zigbee2mqtt/log/2022-04-10.08-31-01' filename: log.txt
Zigbee2MQTT:info  2022-04-10 08:31:03: Starting Zigbee2MQTT version 1.25.0 (commit #unknown)
Zigbee2MQTT:info  2022-04-10 08:31:03: Starting zigbee-herdsman (0.14.20)
Zigbee2MQTT:info  2022-04-10 08:31:04: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2022-04-10 08:31:04: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info  2022-04-10 08:31:04: Currently 0 devices are joined:
Zigbee2MQTT:info  2022-04-10 08:31:04: Zigbee: disabling joining new devices.
Zigbee2MQTT:info  2022-04-10 08:31:04: Connecting to MQTT server at mqtt://localhost:1883
Zigbee2MQTT:error 2022-04-10 08:31:04: MQTT failed to connect: connect ECONNREFUSED 127.0.0.1:1883
Zigbee2MQTT:error 2022-04-10 08:31:04: Exiting...
Zigbee2MQTT:info  2022-04-10 08:31:04: Stopping zigbee-herdsman...
Zigbee2MQTT:info  2022-04-10 08:31:16: Stopped zigbee-herdsman
[08:31:17] INFO: Handing over control to Zigbee2mqtt Core ...
Mosquitto broker logg ser sånn ut.
[fix-attrs.d] done.
[cont-init.d] mosquitto.sh: executing...
[08:33:40] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] done.
[08:33:41] INFO: Starting NGINX for authentication handling...
[08:33:41] INFO: Starting mosquitto MQTT broker...
1649572421: mosquitto version 1.6.12 starting
1649572421: |-- *** auth-plug: startup
[08:33:42] INFO: Successfully send discovery information to Home Assistant.
[08:33:42] INFO: Successfully send service information to the Supervisor.
Katla skrev (8 minutter siden):
Er ip-adressen riktig ?
Mqtt og Zigbee2Mqtt er installert på samme maskin. Skal jeg bytte ut localhost med en statisk ip-adresse?
TomJacobsen skrev (2 minutter siden):
Hvis ip-adressen i loggen er en annen enn 127.0.0.1   så kan det kansje hjelpe å bytte ut localhost  med en statisk ip-adresse
