Når N/A på graf og det er ingen verdier i tabellen.
Prøvde i dag å oppdatere til siste versjon av Nordpool (0.0.5) og HA 2022.4.7 men fortsatt samme resultat.
Noen flere som får det samme?
Her er log-info:
Logger: homeassistant.components.sensor
Source: helpers/template.py:409
Integration: Sensor (documentation, issues)
First occurred: 7:12:24 PM (2 occurrences)
Last logged: 7:12:24 PM
Error adding entities for domain sensor with platform nordpool
Error while setting up nordpool platform for sensor
Traceback (most recent call last):
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 407, in async_render
    render_result = _render_with_context(self.template, compiled, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1820, in _render_with_context
    return template.render(**kwargs)
  File "/usr/local/lib/python3.9/site-packages/jinja2/environment.py", line 1291, in render
    self.environment.handle_exception()
  File "/usr/local/lib/python3.9/site-packages/jinja2/environment.py", line 926, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "<template>", line 1, in top-level template code
jinja2.exceptions.UndefinedError: 'dict object' has no attribute 'night'
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 382, in async_add_entities
    await asyncio.gather(*tasks)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 614, in _async_add_entity
    await entity.add_to_platform_finish()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 798, in add_to_platform_finish
    await self.async_added_to_hass()
  File "/config/custom_components/nordpool/sensor.py", line 484, in async_added_to_hass
    await self.check_stuff()
  File "/config/custom_components/nordpool/sensor.py", line 445, in check_stuff
    self._update(today)
  File "/config/custom_components/nordpool/sensor.py", line 304, in _update
    formatted_prices = [
  File "/config/custom_components/nordpool/sensor.py", line 305, in <listcomp>
    self._calc_price(
  File "/config/custom_components/nordpool/sensor.py", line 268, in _calc_price
    template_value = self._ad_template.async_render(now=faker())
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 409, in async_render
    raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'dict object' has no attribute 'night'
Jeg hadde et annet problem med apexcharts og nordpool, den virket igjen etter at jeg hadde fjernet 3 kodelinjer med "extend_to_end: false" i apexchart
Men sikkert ikke samme problem som deg
@KjetilBDu er sikker på at det ikke er konfigurasjonen din som er feil, da?
KjetilB skrev (11 timer siden):
Katla skrev (På 3.5.2022 den 20.32):
Denne er direkte relatert til en breaking change hos apexcharts; "extend_to_end:" er erstattet med "extend_to:".
stigvi skrev (På 4.5.2022 den 7.19):
Jeg tror kanskje ikke det er individuelle konfigurasjonsfeil, for denne feilen har nylig dukket opp hos ganske mange som har hatt det rullende i lang tid uten endring, tror det dukket opp med 2022.04 versjonen.
Restart av HA løser det for noen dager, så dukker feilen dessverre opp igjen.
