Jeg forsøker å legge til min Steca Inverter til Home Assistant.
I min configuration.yaml  ser det sånn ut :
sensor:
    - platform: rest
      resource: http://192.168.10.195/measurements.xml
      value_template: "{{ now() }}"
      json_attributes:
        - root
Den http fungerer, har jeg tested, leverer :
<root>
<Device Name="StecaGrid 3010" Type="Inverter" Serial="751786BE005998740019" BusAddress="1" NetBiosName="INV005998740019" IpAddress="192.168.10.195" DateTime="2022-10-01T07:11:33">
<Measurements>
<Measurement Value="241.868" Unit="V" Type="AC_Voltage"/>
<Measurement Value="0.203" Unit="A" Type="AC_Current"/>
<Measurement Value="30.320" Unit="W" Type="AC_Power"/>
<Measurement Value="49.990" Unit="Hz" Type="AC_Frequency"/>
<Measurement Value="319.552" Unit="V" Type="DC_Voltage"/>
<Measurement Value="0.152" Unit="A" Type="DC_Current"/>
<Measurement Value="48.350" Unit="W" Type="DC_Power"/>
<Measurement Value="28.500" Unit="°C" Type="Temp"/>
<Measurement Value="nan" Unit="W" Type="Consumption PV"/>
<Measurement Value="nan" Unit="W" Type="Consumption Grid"/>
<Measurement Value="nan" Unit="W" Type="GridPower"/>
<Measurement Value="100.0" Unit="%" Type="Dearting"/>
</Measurements>
</Device>
</root>
Som resultat får jeg en sensor, men med dette :
This entity ('sensor.stecagrid') does not have a unique ID, therefore its settings cannot be managed from the UI. See the documentation for more detail
Har jeg glemt noe ?
