Får ikke aktivert ZHA på Home Assitant OS. Har fungert stabilt i et par måneder, men siste to dagne begynt å bli trøblete. For nå å ikke starte i det hele tatt. Har en RaspberryPI 4 med SSD. Zigbee dongelen er koblet til en 1 meters forlengelseskabel.
Kan dette være den beryktede inferens utfordringen mellom Zigbee og SSD, HW feil som plutselig slo til, eller noe SW greier?
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:172
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 21:25:53 (3 occurrences)
Last logged: 21:26:40
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator (attempt 1 of 3)
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator (attempt 2 of 3)
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator (attempt 3 of 3)
Traceback (most recent call last):
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 664, in _skip_bootloader
    result = await responses.get()
  File "/usr/local/lib/python3.10/asyncio/queues.py", line 159, in get
    await getter
asyncio.exceptions.CancelledError
During handling of the above exception, another exception occurred:
  File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 172, in async_initialize
    self.application_controller = await app_controller_cls.new(
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 144, in new
    await app.startup(auto_form=auto_form)
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 124, in startup
    await self.connect()
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py", line 106, in connect
    await znp.connect()
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 706, in connect
    self.capabilities = (await self._skip_bootloader()).Capabilities
  File "/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py", line 663, in _skip_bootloader
    async with async_timeout.timeout(CONNECT_PROBE_TIMEOUT):
  File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 129, in __aexit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 212, in _do_exit
    raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
Det enkle er å kikke i "hardware" oversikten til HA og se om "dingsen" fortsatt står tilkoblet samme usb-port.
Hvilken adresse har du brukt? Den korte lignende dette, /dev/ttyUSB0 som kan endre seg?
Eller den lange, lignende dette, /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 som ikke skal bli endret av operativsystemet?
USB porten er ttyACM0 og jeg tror den har vært det hele tiden. Usikker på hvor jeg sjekker det i ZHA. Husker jeg la inn adressen da jeg satt det opp, men finner ikke noe sted å sjekke det nå.
Mulig dette er et sent svar, men du kan finne ut hvilken usb port du brukte ved å gå inn på din HA backup og lete etter filen "core.config_entries". Det er en skjult fil som ligger under disse katalogene: C:\Temp\core_2022_9_7\homeassistant.tar\homeassistant\data\.storage. I filen core.config_entries søker du etter "zha" eller "USB Serial".
        "entry_id": "38844e21bb87da901b1d041250503be4",
        "version": 3,
        "domain": "zha",
        "title": "USB Serial, s/n: n/a",
        "data": {
          "radio_type": "znp",
          "device": {
            "path": "/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0",
            "baudrate": 115200,
            "flow_control": null
Endret av haraldov
