Hei.
Jeg har noe av de samme problemene. Mine deviser har ikke oppdatert seg siden 20. januar. Kun devisen "Verisure status" som har oppdatert seg senest i dag med den passende teksten OK ;)
Jeg leger ved utdrag fra meg også om du trenger å titte på litt flere i helga ?
Startup log: (utdrag)
07.02.2019 20.51.11 ~!~Startup~!~Settings Loaded.
07.02.2019 20.51.11 ~!~Startup~!~********************************************************************************
07.02.2019 20.51.11 ~!~Startup~!~            HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
07.02.2019 20.51.12 ~!~Load Config~!~511 total devices loaded.
07.02.2019 20.51.12 ~!~Load Config~!~Loading Event Groups...
07.02.2019 20.51.12 ~!~Load Config~!~Loading Events...
07.02.2019 20.51.12 ~!~Load Config~!~226 total events loaded.
07.02.2019 20.51.12 ~!~Load Config~!~Loading COUNTERS...
07.02.2019 20.51.12 ~!~Load Config~!~Loading TIMERS...
07.02.2019 20.51.12 ~!~Startup~!~HomeSeer version is: 3.0.0.435
07.02.2019 20.51.14 ~!~Plug-In~!~Found plug-in: LSoftVerisure, version: 2.6.293.0
07.02.2019 20.51.21 ~!~Startup~!~Initializing Plug-Ins
07.02.2019 20.51.23 ~!~Plug-In~!~Finished initializing plug-in LSoftVerisure
07.02.2019 20.51.23 ~!~Plug-In~!~Finished initializing plug-in MQTT
07.02.2019 20.51.23 ~!~Info~!~Plugin LSoftVerisure has connected. IP:127.0.0.1:50892
07.02.2019 20.51.23 ~!~Info~!~Plugin MQTT has connected. IP:127.0.0.1:50894
07.02.2019 20.51.23 ~!~Starting Plug-In~!~Initializing plugin LSoftVerisure ...
07.02.2019 20.51.23 ~!~LSoftVerisure~!~LSoftVerisure plugin initializing
07.02.2019 20.51.24 ~!~LSoftVerisure~!~C:\Program Files (x86)\HomeSeer HS3
07.02.2019 20.51.24 ~!~LSoftVerisure~!~Debug:False
07.02.2019 20.51.24 ~!~LSoftVerisure~!~LogToFile:False
07.02.2019 20.51.24 ~!~Starting Plug-In~!~Plugin LSoftVerisure started successfully in 624 milliseconds
07.02.2019 20.51.26 ~!~LSoftVerisure Error~!~System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig.   ved System.Net.HttpWebRequest.GetResponse()   ved Verisure.VerisureSync.‭‍‏‏‎‎‮‬‪‎‭‭‫‍‍‪‪‪‍‬‎‫‪‍‏‮‬‮(WebRequest )   ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt)
07.02.2019 20.51.26 ~!~LSoftVerisure Error~!~{"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"}
07.02.2019 20.51.26 ~!~LSoftVerisure Error~!~Finner ikke devices for lokasjon Åsheimgrenda
07.02.2019 20.51.27 ~!~Plug-In~!~Finished initializing plug-in TibberSeer
Endret til debug:
1547893021_Skjermbilde2019-02-07kl_21_15_42.thumb.png.00416ee0b050ce137f3c5685022205ea.png
Log (utdrag)
feb-07 21.18.29
LSoftVerisure Error
feb-07 21.18.29
LSoftVerisure Error
feb-07 21.18.29
LSoftVerisure Error
System.Net.WebException: Den eksterne serveren returnerte feilen (503) Server ikke tilgjengelig. ved System.Net.HttpWebRequest.GetResponse() ved Verisure.VerisureSync. ‍ ‏‏‎‎‍‍‎ ‍‏(WebRequest ) ved Verisure.VerisureSync.GetDevices(String giid, Int32 attempt)
feb-07 21.18.29
LSoftVerisure Debug
Funnet 1 lokasjoner
feb-07 21.18.28
LSoftVerisure Debug
Henter lokasjoner
feb-07 21.18.28
LSoftVerisure Debug
Login utført
feb-07 21.18.28
LSoftVerisure Debug
Logger inn
f
feb-07 21.17.30
LSoftVerisure Error
feb-07 21.17.30
LSoftVerisure Error
feb-07 21.17.30
LSoftVerisure Error
feb-07 21.17.29
LSoftVerisure Debug
Funnet 1 lokasjoner
feb-07 21.17.28
LSoftVerisure Debug
Henter lokasjoner
feb-07 21.17.28
LSoftVerisure Debug
Login utført
feb-07 21.17.28
LSoftVerisure Debug
Logger inn
feb-07 21.16.29
LSoftVerisure Error
feb-07 21.16.29
LSoftVerisure Error
feb-07 21.16.29
LSoftVerisure Error
feb-07 21.16.28
LSoftVerisure Debug
Funnet 1 lokasjoner
feb-07 21.16.28
LSoftVerisure Debug
Henter lokasjoner
feb-07 21.16.28
LSoftVerisure Debug
Login utført
feb-07 21.16.28
LSoftVerisure Debug
Logger inn
feb-07 21.15.37
LSoftVerisure Debug
Generate html for Åsheimgrenda
feb-07 21.15.37
LSoftVerisure Debug
GenSettings, link:html/LSoft/Verisure/settings.htm parms:
feb-07 21.15.29
LSoftVerisure Error
feb-07 21.15.29
LSoftVerisure Error
feb-07 21.15.29
LSoftVerisure Error
feb-07 21.15.28
LSoftVerisure Debug
Funnet 1 lokasjoner
feb-07 21.15.28
LSoftVerisure Debug
Henter lokasjoner
feb-07 21.15.28
LSoftVerisure Debug
Login utført
feb-07 21.15.28
LSoftVerisure Debug
Logger inn
feb-07 21.14.29
LSoftVerisure Error
feb-07 21.14.29
LSoftVerisure Error
feb-07 21.14.29
LSoftVerisure Error
feb-07 21.14.28
LSoftVerisure Debug
Funnet 1 lokasjoner
feb-07 21.14.28
LSoftVerisure Debug
Henter lokasjoner
feb-07 21.14.28
LSoftVerisure Debug
Login utført
feb-07 21.14.28
LSoftVerisure Debug
plugin last timer run:01.01 00.00
feb-07 21.14.28
LSoftVerisure Debug
Logger inn
feb-07 21.14.28
LSoftVerisure Debug
plugin state:True
feb-07 21.14.28
LSoftVerisure Debug
Timer state:True
feb-07 21.13.29
LSoftVerisure Error
feb-07 21.13.29
LSoftVerisure Error
feb-07 21.13.29
LSoftVerisure Error
feb-07 21.13.28
LSoftVerisure Debug
Funnet 1 lokasjoner
feb-07 21.13.28
LSoftVerisure Debug
Henter lokasjoner
feb-07 21.13.28
LSoftVerisure Debug
Login utført
feb-07 21.13.28
LSoftVerisure Debug
Logger inn
feb-07 21.12.29
LSoftVerisure Error
feb-07 21.12.29
LSoftVerisure Error
feb-07 21.12.29
LSoftVerisure Error
Prøvte å oppgradere fra 2.2 til 2.6 idag, men får denne feilmeldingen?
Initializing plug-in(2): LSoftVerisure Instance::Could not resolve type with token 01000023 from typeref (expected class 'Verisure.StartStatus' in assembly 'Verisure, Version=2.6.283.0, Culture=neutral, PublicKeyToken=null')STACK: Server stack trace: Exception rethrown at [0]: at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.InitIO(string) at Scheduler.clsHSPI.CheckInterfaces () [0x000c4] in <4466e08c7a6c46068e3ccd83aaf1bbac>:0
Kjører HS3 på en Hometroller SEL - Mono 5+ installert, noen som har noen ide hva som er feil?
Har ikke hatt noe linux maskin kjørende her hjemme så siste versjon er ikke testet på linux :( men endringene som er gjort burde ikke ha knekt den. Skal forsøke å sette opp en linux maskin snart for testing
Hei.
Testet Beta, men på Linux, så kanskje ikke beste kandidat slik sett ?
Den funker (etter å ha endret path i HSPI_LSoftVerisure.exe.config fra \ til / ) og jeg får opp komponenter med verdier som jeg kan lage events på, men får også feilmeldinger som følger:
08:52:32:7908:[LSoftVerisure Error]->Feil ved opprettelse av database kobling
2/10/2019 8:52:32 PM: Feil ved opprettelse av database kobling
2/10/2019 8:53:31 PM: XX data hentet
08:53:31:0384:[LSoftVerisure]->XX data hentet
08:53:31:6454:[LSoftVerisure Error]->Feil ved opprettelse av database kobling
2/10/2019 8:53:31 PM: Feil ved opprettelse av database kobling
2/10/2019 8:54:31 PM: XX data hentet
08:54:31:1116:[LSoftVerisure]->XX data hentet
08:54:31:7364:[LSoftVerisure Error]->Feil ved opprettelse av database kobling
2/10/2019 8:54:31 PM: Feil ved opprettelse av database kobling
Feb-10 10:54:36 PM   LSoftVerisure Error System.DllNotFoundException: SQLite.Interop.dll at (wrapper managed-to-native) System.Data.SQLite.UnsafeNativeMethods.sqlite3_config_none(System.Data.SQLite.SQLiteConfigOpsEnum) at System.Data.SQLite.SQLite3.StaticIsInitialized () [0x0001d] in :0 at System.Data.SQLite.SQLiteLog.Initialize () [0x00000] in :0 at System.Data.SQLite.SQLiteConnection..ctor (System.String connectionString, System.Boolean parseViaFramework) [0x00021] in :0 at System.Data.SQLite.SQLiteConnection..ctor (System.String connectionString) [0x00000] in :0 at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteConnection..ctor(string) at Verisure.VerisureSync.‮‏‎‫‎‬‎‪‬‌‮‪‬‭‫‎‪‏‌‫‪‮ (System.String ) [0x00000] in :0 at Verisure.VerisureSync.GenPage (System.String link) [0x005fc] in :0
og den fortsetter slik med sutring over database kopling. Merk at dette er en helt ny installasjon.
Eller virker alt ok på mitt lille anlegg.
-J-
Endret av jmoen
Hmm, linux er ikke min sterkeste side desverre. Den feilmeldinga der indikerer jo at den benytter feil path for sqllite.
Antar det er denne linjen du endret?
<probing privatePath="Bin\LSoft\Verisure" />
Og du har denne path og fila "System.Data.SQLite.dll" liggende der? Og den er versjon 104?
Endret av lilfire
På 10.2.2019 den 11.17, lilfire skrev:
Ny BETA klar LSoftVerisure
Får ikke linken til å virke.
Sliter med at det ikke kommer opp noen devicer. Bare den som heter Verisure status: OK
Kjører 2.6.293.0
Får feilmelding:
feb-11 21.38.29   LSoftVerisure Error Finner ikke devices for lokasjon XXXXXXXXXXXX
feb-11 21.38.29   LSoftVerisure Error {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"}
feb-11 21.38.29   LSoftVerisure Error System.Net.WebException: The remote server returned an error: (503) Server Unavailable. at System.Net.HttpWebRequest.GetResponse() at Verisure.VerisureSync.‭‍‏‏‎‎‮‬‪‎‭‭‫‍‍‪‪‪‍‬‎‫‪‍‏‮‬‮(WebRequest ) at Verisure.VerisureSync.GetDevices(String giid, Int32 attempt)
Hej, får följande fel med senaste betan. Har provat flera användarnamn och användarkontona fungerar felfritt på mypages.
Feb-11 21:30:43         Starting Plug-In    Plugin LSoftVerisure started successfully in 301 milliseconds
Feb-11 21:30:43         LSoftVerisure Error    Kunne ikke loge inn
Feb-11 21:30:43         LSoftVerisure Debug    Login utført
Feb-11 21:30:43         LSoftVerisure Debug    Logger inn
Feb-11 21:30:43         LSoftVerisure    Update every 600 second
Feb-11 21:30:43         LSoftVerisure Debug    a:2.7.62.0
Feb-11 21:30:43         LSoftVerisure Debug    v:2.7.62.0
Feb-11 21:30:43         LSoftVerisure    LogToFile:False
Feb-11 21:30:43         LSoftVerisure    Debug:True
Feb-11 21:30:43         LSoftVerisure    C:\Program Files (x86)\HomeSeer HS3
Feb-11 21:30:43         LSoftVerisure    LSoftVerisure plugin initializing
Feb-11 21:30:43         Starting Plug-In    Initializing plugin LSoftVerisure ...
Kjører 2.6.293.0
Får feilmelding:
2.6 har et problem med at et par av kallene mot verisure kun går mot server 01 og denne er nede nå. Jobber med at server skal velges automagisk i 2.7. Beta linker fungerer kun i et gitt tidsrom eller x antall nedlastninger - så om linken ikke fungere er dette brukt opp.
Hmm, har du noen spesiele tegn i passordet ditt? Dette skal ikke ha noe betydning men vet jo aldri, har jo hatt en feil med dette før så.
Jag hade ! i lösenordet men har tagit bort så att det bara är bokstäver och siffror men ingen skillnad.
Pang! Har aldri fått opp pluginet i Linux tidligere. Ny retning på skråstreken gjorde susen :D
Korrekt.
Skal grave litt mer rundt SQLite saken, er vist kjent mono utfordring, bare jeg er tilbake på landjorden.
-J-
Knall ??
Får du samme melding: feil ved opprettelse av databasekopling ?
-J-
3 minutter siden, jmoen skrev:
Knall ??
-J-
Ser sånn ut, ja
System.DllNotFoundException: SQLite.Interop.dll at (wrapper managed-to-native) System.Data.SQLite.UnsafeNativeMethods:sqlite3_config_none (System.Data.SQLite.SQLiteConfigOpsEnum) at System.Data.SQLite.SQLite3.StaticIsInitialized () [0x0001d] in :0 at System.Data.SQLite.SQLiteLog.Initialize () [0x00000] in :0 at System.Data.SQLite.SQLiteConnection..ctor (System.String connectionString, System.Boolean parseViaFramework) [0x00021] in :0 at System.Data.SQLite.SQLiteConnection..ctor (System.String connectionString) [0x00000] in :0 at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteConnection:.ctor (string) at Verisure.VerisureSync.‮‏‎‫‎‬‎‪‬‌‮‪‬‭‫‎‪‏‌‫‪‮ (System.String ) [0x00000] in :0 at Verisure.VerisureSync.GenPage (System.String link) [0x005fc] in :0
Sender deg en PM
Kan du forsøker flytte/kopiere mappene x64 og x86 fra "Bin\LSoft\Verisure" ut til root mappa til HS for å se om er probing i configen som ikke fungere
Løftet x64 og x84 til /usr/local/HomeSeer/.
Samme db-feilmelding.
Restart hjalp! Litt ustabil, men fikk åpnet døra i alle fall en gang. Herlig :)
Testet litt frem og tilbake og ble til slutt kvitt feilmelding ved å kopiere over System.Data.SQLite.dll med den fra Z-Wave plugin  ;)
Det som ikke funker er Graf, den er blank og jeg får ingen feilmeldinger.
-J-
At det hjalp å løfte filene betyr at det er probingen som ikke fungerer som den skal :/ Første treffet jeg får med å google "mono probing linux" sender meg til HS forumet så kan være det er noe svakheter i HS når det gjelder probing og linux.
-J-
Du kopierte over hvilken fil?
jeg ser at i mitt HS miljø benyter z-wave pluginen versjon 1.0.87. Mens jeg bruker versjon 1.0.104. så å skrive over "min" SQLite.dll med zwave sin er nok ikke en løsning.
Ja Graf har fått lite prioriteringer i de siste versjonene. Jeg vuderer om jeg skal gi det en overhaling eller om jeg skal droppe det. For logging og presentasjon av data har man jo andre plugins man kan benyte som gjør en bedre jobb.
Det er en probing path for verisure.dll filen også; "HomeSeer HS3\Bin\LSoft\Verisure\Verisure.dll.config"
Har du fikset \ der også? For jeg anser ikke det å flytte de mappene ut til root som noen løsning.
Yup, byttet retning på skråstreken først ja.
Det var System.Data.SQLite.dll filen, som ligger i plugin katalogen til ZWave, som jeg overskrev din dll med. Da forsvant alt av feilmeldinger og alt ser vel ut. Jeg antar det er noe i din dll som ikke spiller med min mono (kjører Raspbian) eller motsatt. Er uansett bare ett hack jeg ville prøve og det funket ?
Endret av jmoen
