I am trying to control Z-WATER with Z-TEMP2 and I am having problems.I am using Homey Pro as hub.
Z-WATER has Node ID 62
Z-TEMP2 has Node ID 61
Actuators are connected to Z-WATER channels 2, 3, 4 and 5.
I have created association in Z-TEMP2 in Group 3 as 62.2,62.3,62.4,62.5
When I active the Relays individually in Homey Pro I can hear the click (it is working).
In Homey Pro I see relays 2 to 10 and on named Z-Water. I do not see relay-1.
it says current temperature is 25.5C and I set to 40C but nothing changes.
All relays are off. If I manually active the one named Z-Water in Homey, it stays on for a few seconds and afterwards is off.
Questions:
1. It seems they Z-WATER and Z-TEMP2 are installed individually but I do not see any evidence of communication between them. How do I check it?
2. I change temperature target in Z-TEMP2 but I do not see the relays closing or open. No action on Z-WATER.
3. Why in Homey the item named as Z-WATER does not stays on?
I added some pictures in case it helps to evaluate the problem.
IMG_3020.thumb.PNG.74b637ea312f1ab876c9c1504cd1b461.PNGIMG_3021.thumb.PNG.f0a4113817ff3dc6b5699f526648f148.PNGIMG_3022.thumb.PNG.81185adc1a56fe9aca7e848eca842710.PNGIMG_3023.thumb.PNG.715396ee6cae0f3f8d2e91c98161f708.PNGIMG_3024.thumb.PNG.bb9f5c8d00a5490b6a83c798a09adc7e.PNGIMG_3025.thumb.PNG.eebb36038be6740448472eed426e3e97.PNGIMG_3026.thumb.PNG.eb9c8c5b082a763e0bc33ae1ba8eb70f.PNGIMG_3027.thumb.PNG.061e3d0d7119b6fab65784e738ceebff.PNGIMG_3028.thumb.PNG.9994713dabacd7e2afd3f9676c7b4fc5.PNGIMG_3029.thumb.PNG.1f2e19927a250d69f2b683eda7ef7032.PNG
