Tor Magnus Skrevet 17. januar 2019 Skrevet 17. januar 2019 13 hours ago, wmbusmeters said: Multical21 always broadcasts the meter values regularly. Yep, that is one radio signal every 15 seconds, for 10-16 years, depending on the model. Pretty remarkable tech. A passive listener will of course not drain its battery more. I see you've started on energy meters as well, I was wondering if you think we should be able to pick up data from our Aidon energy meter as well? As far as I can tell they do have wireless enabled, but I'm uncertain about whether they publish MBUS notification packets. I've contacted my power supplier about this. If it should be possible, is there anything I can do to help getting it implemented? Siter
wmbusmeters Skrevet 17. januar 2019 Skrevet 17. januar 2019 Sure, adding more meter is always fun! However a quick google on Aidon energy meters seems to indicate that they use a proprietary protocol to build a mesh network to reach the municipality. Even though they seem to use the same radio freq band as wmbus, it might not be wmbus. But I could be wrong. So please check. Siter
Tor Magnus Skrevet 22. januar 2019 Skrevet 22. januar 2019 I contacted the power company, but so far no response. ? Siter
mk1 black limited Skrevet 22. januar 2019 Forfatter Skrevet 22. januar 2019 @wmbusmeters - got the im871a USB stick today, and installed your program on my Pi, but I get "No wmbus device found!". It seems to be recognized, I see the im871-device in /dev. Any suggestions? Siter
wmbusmeters Skrevet 22. januar 2019 Skrevet 22. januar 2019 (endret) Have you tried both auto and /dev/ttyUSB0 (or whatever tty it was assigned) ? Auto only works if you have added the udev rules. And did you check the read/write permissions on the ttyUSB0 device? Endret 22. januar 2019 av wmbusmeters Siter
mk1 black limited Skrevet 23. januar 2019 Forfatter Skrevet 23. januar 2019 (endret) I've tried both auto (have added udev rules) as well as /dev/ttyUSB0 (and USB1). rw set to 777 right now, still same error. @Tor Magnus. have you got yours to work? Endret 23. januar 2019 av mk1 black limited Siter
wmbusmeters Skrevet 23. januar 2019 Skrevet 23. januar 2019 (endret) Run wmbusmeters - - c1 - - debug /dev/ttyUSB0 and email me the log output. My email is on the github page. Please try from a linux computer as well. (I mean the build computer... ? ) Endret 23. januar 2019 av wmbusmeters Siter
Tor Magnus Skrevet 23. januar 2019 Skrevet 23. januar 2019 2 hours ago, mk1 black limited said: I've tried both auto (have added udev rules) as well as /dev/ttyUSB0 (and USB1). rw set to 777 right now, still same error. @Tor Magnus. have you got yours to work? It arrived yesterday, but I didn't have time to pick it up. Will be picking it up today so I'll be able to test it later. Siter
mk1 black limited Skrevet 23. januar 2019 Forfatter Skrevet 23. januar 2019 3 hours ago, wmbusmeters said: Run wmbusmeters - - c1 - - debug /dev/ttyUSB0 Got this: (cmdline) using usb device: /dev/ttyUSB1 (cmdline) number of meters: 0 (serial) opened /dev/ttyUSB1 (serial /dev/ttyUSB1) received "00" (amb8465) are you there? (serial /dev/ttyUSB1) sent "FF0B00F4" (serial) closed /dev/ttyUSB1 (serial) closed /dev/ttyUSB1 (serial) opened /dev/ttyUSB1 (im871a) are you there? (serial /dev/ttyUSB1) sent "A5010100" (serial) closed /dev/ttyUSB1 (serial) closed /dev/ttyUSB1 No wmbus device found! Anyway, as this is a very old Pi I've gone out and invested in a new 3B+ which I will try as soon as I get back home. Great excuse to get a new Pi. Siter
Tor Magnus Skrevet 23. januar 2019 Skrevet 23. januar 2019 root@plex:~# wmbusmeters --robot=json auto WaterMeter multical21 <id> <key> {"media":"cold water","meter":"multical21","name":"WaterMeter","id":"58079516","total_m3":4.749000,"target_m3":0.000000,"flow_temperature":127,"external_temperature":127,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-23T16:10:42Z"} {"media":"cold water","meter":"multical21","name":"WaterMeter","id":"58079516","total_m3":4.749000,"target_m3":0.000000,"flow_temperature":127,"external_temperature":20,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-23T16:12:18Z"} {"media":"cold water","meter":"multical21","name":"WaterMeter","id":"58079516","total_m3":4.749000,"target_m3":0.000000,"flow_temperature":127,"external_temperature":20,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-23T16:13:54Z"} Looks good! Would have been cool if this was implemented as a HA plugin, but I guess I can MQTT it. Siter
Tor Magnus Skrevet 23. januar 2019 Skrevet 23. januar 2019 Hm, flow_temperature does not seem to get updated, even after 8 packets. Siter
wmbusmeters Skrevet 23. januar 2019 Skrevet 23. januar 2019 1 hour ago, Tor Magnus said: Hm, flow_temperature does not seem to get updated, even after 8 packets. Interesting, it could be that you have a meter with another configuration. The customer (municipality) can pick and choose what values the meter should send, depending on what they are interested in. Run with --debug for a while and look for long and short packages. In the long ones, you should be able to see almost exactly the contents of the package received. If you find something that you would like to have in the json, it is easy to add it. Siter
mk1 black limited Skrevet 23. januar 2019 Forfatter Skrevet 23. januar 2019 Very strange, my new 3B+ has the same problem: Quote pi@PI-mbus:~ $ lsusb Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp. Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub pi@PI-mbus:~ $ wmbusmeters-master/build/wmbusmeters --c1 --debug /dev/ttyUSB0 (cmdline) using usb device: /dev/ttyUSB0 (cmdline) number of meters: 0 (serial) closed /dev/ttyUSB0 (serial) closed /dev/ttyUSB0 No wmbus device found! Siter
Tor Magnus Skrevet 23. januar 2019 Skrevet 23. januar 2019 2 hours ago, wmbusmeters said: Interesting, it could be that you have a meter with another configuration. The customer (municipality) can pick and choose what values the meter should send, depending on what they are interested in. Run with --debug for a while and look for long and short packages. In the long ones, you should be able to see almost exactly the contents of the package received. If you find something that you would like to have in the json, it is easy to add it. Looks like it's not sending it. There's no extra information as far as I can se. Siter
Tor Magnus Skrevet 23. januar 2019 Skrevet 23. januar 2019 Would it be possible to be able to define a template json format to use with mqtt? Would be awesome if one even could include sending an initial discover message for home assistant as well, as described here: https://www.home-assistant.io/docs/mqtt/discovery/ Siter
mk1 black limited Skrevet 24. januar 2019 Forfatter Skrevet 24. januar 2019 (endret) 14 hours ago, wmbusmeters said: Interesting, it could be that you have a meter with another configuration. The customer (municipality) can pick and choose what values the meter should send, depending on what they are interested in. Run with --debug for a while and look for long and short packages. In the long ones, you should be able to see almost exactly the contents of the package received. If you find something that you would like to have in the json, it is easy to add it. I seem to be getting flow temperature, @Tor Magnus: {"media":"cold water","meter":"multical21","name":"WaterMeter","id":"12345678","total_m3":46.618000,"target_m3":41.335000,"flow_temperature":5,"external_temperature":13,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-24T08:09:22Z"} Endret 24. januar 2019 av mk1 black limited Siter
Tor Magnus Skrevet 24. januar 2019 Skrevet 24. januar 2019 (endret) H 6 minutes ago, mk1 black limited said: I seem to be getting flow temperature, @Tor Magnus: {"media":"cold water","meter":"multical21","name":"WaterMeter","id":"12345678","total_m3":46.618000,"target_m3":41.335000,"flow_temperature":5,"external_temperature":13,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-24T08:09:22Z"} That's odd. Could my meter be a bit borked? Are you also in Skedsmo (so same meter and config)? Endret 24. januar 2019 av Tor Magnus Siter
mk1 black limited Skrevet 24. januar 2019 Forfatter Skrevet 24. januar 2019 4 hours ago, Tor Magnus said: H That's odd. Could my meter be a bit borked? Are you also in Skedsmo (so same meter and config)? Sure am. Siter
mk1 black limited Skrevet 24. januar 2019 Forfatter Skrevet 24. januar 2019 Yay! MQTT published and grabbed into Homeseer: 3 Siter
wmbusmeters Skrevet 24. januar 2019 Skrevet 24. januar 2019 16 hours ago, Tor Magnus said: Would it be possible to be able to define a template json format to use with mqtt? Would be awesome if one even could include sending an initial discover message for home assistant as well, as described here: https://www.home-assistant.io/docs/mqtt/discovery/ Do you want a different json format than the one that wmbusmeter currently generates? Siter
wmbusmeters Skrevet 24. januar 2019 Skrevet 24. januar 2019 16 hours ago, Tor Magnus said: Looks like it's not sending it. There's no extra information as far as I can se. Try placing the dongle in different angles, sometimes it receives better in a different orientation. Or try closer to the water meter. Siter
Tor Magnus Skrevet 24. januar 2019 Skrevet 24. januar 2019 3 hours ago, wmbusmeters said: Do you want a different json format than the one that wmbusmeter currently generates? Yes, that would be the idea. Also with Home Assistant and auto-discovery of devices it is possible to initially send a config for the sensor. I'm currently containerising wmbusmeters, and I'll see if I can get the container to send a config message on startup before staring wmbusmeters. Siter
Tor Magnus Skrevet 24. januar 2019 Skrevet 24. januar 2019 3 hours ago, wmbusmeters said: Try placing the dongle in different angles, sometimes it receives better in a different orientation. Or try closer to the water meter. I'll have a go using a USB extension cord. A bit limited when it comes to moving the NUC that it's attached to. Siter
steyr Skrevet 8. mars 2019 Skrevet 8. mars 2019 Jeg fikk installert en vannmåler i går, ifølge rørleggeren så var muligheten for å lese av vann automatisk i måleren men at det ikke var aktivert av kommunen ennå. Løsningen på sikt skal være at søppelbilen har en mottaker og at vannmåleren leses av når søppelbilen tømmer søppel. Levetiden er på 15år på vannmåleren. Siter
iceball Skrevet 8. mars 2019 Skrevet 8. mars 2019 På 16.1.2019 den 20.16, mk1 black limited skrev: Pinne i posten på vei til meg også, vannmåler ble installert i våres. Hvilken endte du opp med å bestille? Bor også i Skedsmo, så tenker et nytt prosjekt denne våren. Siter
