13 hours ago, wmbusmeters said:
Multical21 always broadcasts the meter values regularly. Yep, that is one radio signal every 15 seconds, for 10-16 years, depending on the model. Pretty remarkable tech.
A passive listener will of course not drain its battery more.
I see you've started on energy meters as well, I was wondering if you think we should be able to pick up data from our Aidon energy meter as well? As far as I can tell they do have wireless enabled, but I'm uncertain about whether they publish MBUS notification packets. I've contacted my power supplier about this. If it should be possible, is there anything I can do to help getting it implemented?
Sure, adding more meter is always fun!
However a quick google on Aidon energy meters seems to indicate that they use a proprietary protocol to build a mesh network to reach the municipality. Even though they seem to use the same radio freq band as wmbus, it might not be wmbus.
But I could be wrong. So please check.
Have you tried both auto and /dev/ttyUSB0 (or whatever tty it was assigned) ?
Auto only works if you have added the udev rules.
And did you check the read/write permissions on the ttyUSB0 device?
Endret av wmbusmeters
Run
wmbusmeters  - - c1 - - debug /dev/ttyUSB0
and email me the log output. My email is on the github page.
Please try from a linux computer as well. (I mean the build computer... ? )
2 hours ago, mk1 black limited said:
I've tried both auto (have added udev rules) as well as /dev/ttyUSB0 (and USB1). rw set to 777 right now, still same error.
@Tor Magnus. have you got yours to work?
It arrived yesterday, but I didn't have time to pick it up. Will be picking it up today so I'll be able to test it later.
Run
Got this:
(cmdline) using usb device: /dev/ttyUSB1
(cmdline) number of meters: 0
(serial) opened /dev/ttyUSB1
(serial /dev/ttyUSB1) received "00"
(amb8465) are you there?
(serial /dev/ttyUSB1) sent "FF0B00F4"
(serial) closed /dev/ttyUSB1
(im871a) are you there?
(serial /dev/ttyUSB1) sent "A5010100"
No wmbus device found!
Anyway, as this is a very old Pi I've gone out and invested in a new 3B+ which I will try as soon as I get back home. Great excuse to get a new Pi. :)
root@plex:~# wmbusmeters --robot=json auto WaterMeter multical21 <id> <key>
{"media":"cold water","meter":"multical21","name":"WaterMeter","id":"58079516","total_m3":4.749000,"target_m3":0.000000,"flow_temperature":127,"external_temperature":127,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-23T16:10:42Z"}
{"media":"cold water","meter":"multical21","name":"WaterMeter","id":"58079516","total_m3":4.749000,"target_m3":0.000000,"flow_temperature":127,"external_temperature":20,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-23T16:12:18Z"}
{"media":"cold water","meter":"multical21","name":"WaterMeter","id":"58079516","total_m3":4.749000,"target_m3":0.000000,"flow_temperature":127,"external_temperature":20,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-23T16:13:54Z"}
Looks good!
Would have been cool if this was implemented as a HA plugin, but I guess I can MQTT it.
1 hour ago, Tor Magnus said:
Hm, flow_temperature does not seem to get updated, even after 8 packets.
Interesting, it could be that you have a meter with another configuration. The customer (municipality) can pick and choose what values the meter should send, depending on what they are interested in.
Run with --debug for a while and look for long and short packages. In the long ones, you should be able to see almost exactly the contents of the package received.
If you find something that you would like to have in the json, it is easy to add it.
Very strange, my new 3B+ has the same problem:
Quote
pi@PI-mbus:~ $ lsusb
Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 001 Device 005: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@PI-mbus:~ $ wmbusmeters-master/build/wmbusmeters  --c1 --debug /dev/ttyUSB0
(cmdline) using usb device: /dev/ttyUSB0
(serial) closed /dev/ttyUSB0
Looks like it's not sending it. There's no extra information as far as I can se.
I seem to be getting flow temperature, @Tor Magnus:
{"media":"cold water","meter":"multical21","name":"WaterMeter","id":"12345678","total_m3":46.618000,"target_m3":41.335000,"flow_temperature":5,"external_temperature":13,"current_status":"","time_dry":"","time_reversed":"","time_leaking":"","time_bursting":"","timestamp":"2019-01-24T08:09:22Z"}
Endret av mk1 black limited
H
That's odd. Could my meter be a bit borked?
Are you also in Skedsmo (so same meter and config)?
Endret av Tor Magnus
Try placing the dongle in different angles, sometimes it receives better in a different orientation.
Or try closer to the water meter.
Do you want a different json format than the one that wmbusmeter currently generates?
Yes, that would be the idea. Also with Home Assistant and auto-discovery of devices it is possible to initially send a config for the sensor. I'm currently containerising wmbusmeters, and I'll see if I can get the container to send a config message on startup before staring wmbusmeters.
I'll have a go using a USB extension cord. A bit limited when it comes to moving the NUC that it's attached to. :)
Jeg fikk installert en vannmåler i går, ifølge rørleggeren så var muligheten for å lese av vann automatisk i måleren men at det ikke var aktivert av kommunen ennå.
Løsningen på sikt skal være at søppelbilen har en mottaker og at vannmåleren leses av når søppelbilen tømmer søppel. Levetiden er på 15år på vannmåleren.
På 16.1.2019 den 20.16, mk1 black limited skrev:
Pinne i posten på vei til meg også, vannmåler ble installert i våres. :)
Hvilken endte du opp med å bestille? Bor også i Skedsmo, så tenker et nytt prosjekt denne våren.
