Moskus Skrevet 30. oktober 2017 Forfatter Del Skrevet 30. oktober 2017 11 timer siden, Tor Aage skrev: den havnet for seg selv et annet sted Pic or it didn't happen. Men til de som har problemer med hub'en: Prøv å flytt strømforsyningen lenger bort fra eventuelle andre kilder, eller bytt til en annen strømforsyning. Flyttet den hos svigermor og koblet på en Wall Plug (for å kunne resette den remote), og den har vært helt stabil den siste uka eller så. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
HåPe Skrevet 31. oktober 2017 Del Skrevet 31. oktober 2017 Från FB-gruppen "Svenska Hemautomatiseringsgruppen" (i ett mail från IKEA): We at IKEA would like to inform you about a change to our TRÅDFRI Gateway. We are very happy to see your interest in our gateway and have seen that you are using the CoAP interface. We consider the CoAP interface as our internal interface not developed for third party usage and therefore we do not offer any technical support for this usage. However that does not mean that we want to hinder your work in any way. There are some security improvements in a soon coming update that we would like to inform you about since it will break your implementation. Technically the improvement is that the TRÅDFRI Gateway will start using DTLS Identities which you will need to handle in your application. Please use the Following string to connect to the TRÅDFRI Gateway and create a new DTLS Identity. coap-client -m post -u "Client_identity" -k "SECURITY_CODE" -e '{"9090":"IDENTITY"}' "coaps://IP_ADDRESS:5684/15011/9063" SECURITY_CODE is what is labelled on the Gateway label, IDENTITY is any string that is representing the connection. You will then get back a PRE_SHARED_KEY that can be use in all traffic after that. coap-client -m get -u "IDENTITY" -k "PRE_SHARED_KEY" "coaps://IP_ADDRESS:5684/15001" We also would like to request that the SECURITY_CODE that is printed on the gateway is never stored permanently in your application. 1 1 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
FredrikKan Skrevet 31. oktober 2017 Del Skrevet 31. oktober 2017 Tänkte just göra samma inlägg - kommer denna uppgradering förstöra funktionen i TradfriSeer? Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 1. november 2017 Forfatter Del Skrevet 1. november 2017 15 timer siden, FredrikKan skrev: Tänkte just göra samma inlägg - kommer denna uppgradering förstöra funktionen i TradfriSeer? Ja, i aller høyeste grad. Som alle andre bruker vi COAP for å snakke med Hub'en. Hvis TrådfriSeer er viktig i oppsettet ditt, så IKKE OPPGRADER GATEWAY TIL SISTE VERSJON før jeg har fått sett på det. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
FredrikKan Skrevet 1. november 2017 Del Skrevet 1. november 2017 Tyvärr försent? Är bortrest på semester och minTrådfri hub har passat på att uppgradera sig. Får styra med appen/fjärrkontrollen till dess du hunnit uppdatera TradfriSeer. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Tor Aage Skrevet 1. november 2017 Del Skrevet 1. november 2017 På 30.10.2017 den 10.03, Moskus skrev: Men til de som har problemer med hub'en: Prøv å flytt strømforsyningen lenger bort fra eventuelle andre kilder, eller bytt til en annen strømforsyning. Flyttet den hos svigermor og koblet på en Wall Plug (for å kunne resette den remote), og den har vært helt stabil den siste uka eller så. Er det noen begrensning på hvor lang kabelen kan være mellom hub og router? Jeg skal uansett flytte hub, men det er ikke rett i nærheten av routeren.. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 1. november 2017 Forfatter Del Skrevet 1. november 2017 Akkurat nå, Tor Aage skrev: Er det noen begrensning på hvor lang kabelen kan være mellom hub og router? Jeg skal uansett flytte hub, men det er ikke rett i nærheten av routeren.. I utgangspunktet ikke så vidt jeg vet. Men lenger strekk gir potensielt lavere spenning (selv om det da skal være langt spenn)... Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Tor Aage Skrevet 1. november 2017 Del Skrevet 1. november 2017 2 timer siden, Moskus skrev: Hvis TrådfriSeer er viktig i oppsettet ditt, så IKKE OPPGRADER GATEWAY TIL SISTE VERSJON før jeg har fått sett på det. Det ER oppsettet mitt :-p En annen ting; Det hadde vært fint med en mulighet for å restarte plugin av seg selv ved feilmelding som emty respons. Den kommer dessverre kun i loggen, men jeg tror ikke jeg har funnet noen mulighet for å bruke loggen som trigger til noe.. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
ZoRaC Skrevet 1. november 2017 Del Skrevet 1. november 2017 3 minutter siden, Tor Aage skrev: Den kommer dessverre kun i loggen, men jeg tror ikke jeg har funnet noen mulighet for å bruke loggen som trigger til noe.. Mener Jon00 har en plugin som kan trigge på logg-innslag. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 1. november 2017 Forfatter Del Skrevet 1. november 2017 2 minutter siden, Tor Aage skrev: Det hadde vært fint med en mulighet for å restarte plugin av seg selv ved feilmelding som emty respons. Det tror jeg ikke nødvendigvis er mulig, for det kan dessverre være mange grunner til at det er en "Empty Response" (bl.a. at pæren ikke har strøm). Men det er mulig jeg kan legge inn en Event Trigger der, så kan du selv trigge et Event når plugin'en finner "Empty Response". 1 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Tor Aage Skrevet 1. november 2017 Del Skrevet 1. november 2017 1 time siden, FredrikKan skrev: Tyvärr försent Är bortrest på semester och minTrådfri hub har passat på att uppgradera sig. Får styra med appen/fjärrkontrollen till dess du hunnit uppdatera TradfriSeer. Huben min har også rukket å oppdatere seg selv Og i all hovedsak er husets lys basert på IKEA og Trådfriseer :-/ Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Odd Skrevet 1. november 2017 Del Skrevet 1. november 2017 Oppdaterer den seg automatisk? Er på jobb og får faktisk ikke til å gjøre noe med akkurat det. Litt synd om Ikea's oppdatering ødelegger for TråfriSeer. Jeg kan ta pærene inn via conBee og JowiHUE, men jeg savner "ON last Level" på det grensesnittet. ConBee tenkte jeg å kun benytte for fjernkontrollene og bevegelses sensoren fra Ikea. Satser på at Moskus har mulighet til å få til TrådfriSeer igjen. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
ZoRaC Skrevet 1. november 2017 Del Skrevet 1. november 2017 (endret) Changelog på siste firmware-oppdatering fra IKEA: Sitat Release Version: 1.2 New features and changes in Accessories: Stability improvements. Optimisation of power consumption. New features and changes in Gateway: 1.2.42: Stability improvements in application connectivity to gateway. Added support for CoAP DTLS sessions. Added Gateway version info in mDNS response. Use vendor specific NTP servers. Endret 1. november 2017 av ZoRaC Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Tor Aage Skrevet 1. november 2017 Del Skrevet 1. november 2017 1 time siden, Odd skrev: Oppdaterer den seg automatisk? Er på jobb og får faktisk ikke til å gjøre noe med akkurat det. Litt synd om Ikea's oppdatering ødelegger for TråfriSeer. Ja, da jeg gikk inn i IKEA sin app så sto det at en viktig oppdatering var utført :-< Tror nok IKEA gjør noe litt halvdumt hvis de begynner å stenge ute folk fra å eksperimentere slik vi gjør. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Tor Aage Skrevet 1. november 2017 Del Skrevet 1. november 2017 Men uten et fnugg av kunnskap, så ser det vel ut som om IKEA vil hjelpe til også, i innlegget om det svenske forumet..? Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 1. november 2017 Forfatter Del Skrevet 1. november 2017 20 minutter siden, Tor Aage skrev: Men uten et fnugg av kunnskap, så ser det vel ut som om IKEA vil hjelpe til også, i innlegget om det svenske forumet..? Hvis de ville hjelpe til så kunne de advart oss på forhånd, og kjørt med to parallelle måter å autentisere på en måned eller så... Men den gode nyheten er at jeg tror jeg har en fiks klar, må teste den i kveld. Det er muligens ikke den beste måten å gjøre det på, men det viktigste er å få TrådfriSeer til å fungere igjen... 1 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Odd Skrevet 1. november 2017 Del Skrevet 1. november 2017 22 minutter siden, Moskus skrev: er at jeg tror jeg har en fiks klar Hvorfor er jeg ikke overrasket Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 1. november 2017 Forfatter Del Skrevet 1. november 2017 1 time siden, Odd skrev: Hvorfor er jeg ikke overrasket Kanskje du burde være det, siden jeg ikke bruker Trådfri selv i "hovedoppsettet"... Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
gullfrode Skrevet 1. november 2017 Del Skrevet 1. november 2017 Magic Moskus, venter i spenning. Har belasta Hue-huben litt til max så fint med Ikea-hub. Mener du ikke burde mistet noe nattesøvn om du hadde valgt å legge Tradfriseer i Homeseerstore og faktusk fått noen Trump-penger for bryet. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 1. november 2017 Forfatter Del Skrevet 1. november 2017 2 minutter siden, gullfrode skrev: Mener du ikke burde mistet noe nattesøvn om du hadde valgt å legge Tradfriseer i Homeseerstore og faktusk fått noen Trump-penger for bryet. Den skal nok i Updateren til slutt, men hadde vært greit om Ikea ble ferdig med å endre APIen først... Det viser seg å være hakket vanskeligere enn tenkt. Å definere (det jeg regner med er et brukernavn) med "-u" opsjonen i java-klienten var tydeligvis vesentlig vanskeligere i .NET, som er kanskje et litt for omfattende bibliotek... ? Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 2. november 2017 Forfatter Del Skrevet 2. november 2017 Se så, folkens. Oppdater til 0.0.1.5. 2 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 2. november 2017 Forfatter Del Skrevet 2. november 2017 Kan de som har oppgradert sjekke om "Grupper" fungerer som tiltenkt? Ser ut som om status i hub'en ikke blir oppdatert når man prøver å styre gruppa... ? EDIT: Problem funnet, og korrigert. Må vel kjøre ut en oppdatering igjen om litt. Ikea har endret litt på API'en, men "On Last Level" fungerer. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
agaffa Skrevet 2. november 2017 Del Skrevet 2. november 2017 Har sett at Plugin mister IP og Key ved restart av HS. Må legges inn på nytt og saves, men trenger ikke rescanne pærene. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Odd Skrevet 2. november 2017 Del Skrevet 2. november 2017 Dette er vel kjent men sender nå inn allikevel. Samme erfaring som agaffa. Gruppene setter dim, men mister status. GW ver. 1.2.42 Pærer 1.2.217 Fjernkontroll 1.2.214 Plugin 0.0.15 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Moskus Skrevet 2. november 2017 Forfatter Del Skrevet 2. november 2017 54 minutter siden, agaffa skrev: Har sett at Plugin mister IP og Key ved restart av HS. Må legges inn på nytt og saves, men trenger ikke rescanne pærene. Jeg har testet dette på mange systemer, og jeg kan ikke replikere det. 40 minutter siden, Odd skrev: Gruppene setter dim, men mister status. Ja, se to poster over din. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
