Ganske snart kommer det nytt default theme i Domoticz: http://domoticz.com/forum/viewtopic.php?f=8&t=17904 ?
These are some of the changes:
  • Cleaned-up and standardized HTML output with lost of useful classes, so themes can more easily change things.
  • Modified HTML hierarchy, allowing for CSS to create more varied designers, like columns, which will improve use of screen space.
  • All themes can now add in their own javascript. This offers a lot more freedom to create and modify the HTML output.
  • The default theme offers a great starting point for creating your own theme. It even allows for quick enabling of disabling of features, like the side bar, data visualization,
  • There is now even an option to merge simple items. If you have multiple items with only one output each, you can combine them into one 'grouped item'.
  • New, custom-made higher resolution icons, for example in in the main menu.
  • Animations are now possible. For example, the fan icon might spin while it's on, the barometer actually spins, etc.
  • Much more.
