Får ikke installert Device History Software Plug-in for HS3
Noe forslag?
Jul-20 19:08:02   Updater Install/Update of package Device History failed.
Jul-20 19:08:02   Updater Error Installation of package Device History failed. Try disabling the plugin first, then re-try the update.
Jul-20 19:08:02   Updater Extraction Complete.
Jul-20 19:08:02   Updater Extracting files from zip file: images.zip
Jul-20 19:08:02   Updater Warning File exists, not overwriting: \home\pi\homeser\HomeSeer\Data\skWare\DeviceHistory\HSPI_SKWARE_DEVICE_HISTORY.db3
Jul-20 19:08:02   Updater Copying file: \home\pi\homeser\HomeSeer\bin\skWare\DeviceHistory\Newtonsoft.Json.dll
Jul-20 19:08:02   Updater Copying file: \home\pi\homeser\HomeSeer\bin\skWare\DeviceHistory\System.Web.DataVisualization.dll
Jul-20 19:08:02   Updater Copying file: \home\pi\homeser\HomeSeer\HSPI_SKWARE_DEVICE_HISTORY.exe.config
Jul-20 19:08:01   Updater Installing package Device History
Jul-20 19:08:01   Updater Update HSPI_SKWARE_DEVICE_HISTORY.exe downloaded successfully
Jul-20 19:07:53   Updater Downloading update: Device History
Jul-20 19:07:53   Updater Starting download of updates
Jul-20 19:07:09   Z-Wave Setting device Sensor Motion Stue nede to value 255
JEG prøvde å slette history filen .
men den hadde beskyttelse så jeg ikke får slettet den ,
Finnes det noen mulighet for å gå uten om beskyttelsen ?
Linux
Har restartet flere ganger. men den appen kommer ikke frem.
Current Date/Time: 7/22/2017 3:54:32 PM CEST
HomeSeer Version: HS3 Pro Edition 3.0.0.326 (Linux)
HomeSeer:
Is Registered
Er dessverre ingen Linux-ekspert, men:
1. Får du til å installere andre plugins?
2. Kan det ha skjedd noe med fil-/mapperettigheter?
3. Kjører du HS med en root-bruker?
Utover det er nok HS-support eller forumet for "Device History" rette sted å spørre. :)
Får installert andre plugins.
Alt fungere unntatt denne plugg inn
Tror jeg kjører som root-bruker, hvordan sjekker jeg det?
