La plutselig nå merke til at det er sykt mye greier i loggen min.
Ser dette normalt ut?
sep-21 18.12.52	 	Z-Wave	Set_New_Level_SWITCH_BINARY FINISHING(H) COMMAND_CLASS_SWITCH_BINARY
sep-21 18.12.52	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.12.52	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Garderobe Stikkontakt lys garderobe - Root, Child:1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter
sep-21 18.12.52	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter, Type=COMMAND_CLASS_SWITCH_BINARY, EndPoint=0
sep-21 18.12.52	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter
sep-21 18.12.52	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SWITCH_BINARY Frame(7)=3
sep-21 18.12.52	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=129
sep-21 18.12.51	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.12.51	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=64
sep-21 18.12.51	 	Z-Wave	Setting device Stikkontakt lys garderobe - Effekt to value 19,2
sep-21 18.12.51	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Garderobe Stikkontakt lys garderobe - Root, Child:1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt
sep-21 18.12.51	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt, Type=COMMAND_CLASS_METER_V3, EndPoint=0
sep-21 18.12.51	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt
sep-21 18.12.51	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
sep-21 18.12.51	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=129
sep-21 18.12.50	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.12.49	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=128
sep-21 18.12.49	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.12.49	 	Z-Wave	UZB1: Sending to node 12 (Secure) CC=COMMAND_CLASS_SWITCH_BINARY
sep-21 18.12.49	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.12.49	 	Device Control	Device: 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter to On (255)
sep-21 18.12.49	 	Event	Event Trigger "Lysstyring Garderobelys på ved bevegelse"
sep-21 18.12.49	 	Z-Wave	Setting device Multisensor yttergang Bevegelse to value 255
sep-21 18.12.49	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Yttergang Multisensor yttergang, Child:1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.12.49	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Yttergang Multisensor yttergang Bevegelse, Type=COMMAND_CLASS_SENSOR_BINARY, EndPoint=0
sep-21 18.12.49	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.12.49	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_BASIC_V2 Frame(7)=1
sep-21 18.12.49	 	Event	Remove Delayed Device Action Removed event: Delayed Actions X - Stikkontakt lys garderobe - Bryter (Delayed Action)
sep-21 18.12.49	 	Z-Wave	Device: 1.ETASJE Yttergang Multisensor yttergang Bevegelse Set to On/Open/Motion
sep-21 18.12.49	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_SENSOR_BINARY Frame(7)=3
sep-21 18.12.49	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_NOTIFICATION_V6 Frame(7)=5
sep-21 18.12.48	 	Z-Wave	Setting device Multisensor yttergang Bevegelse to value 0
sep-21 18.12.48	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Yttergang Multisensor yttergang, Child:1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.12.48	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Yttergang Multisensor yttergang Bevegelse, Type=COMMAND_CLASS_SENSOR_BINARY, EndPoint=0
sep-21 18.12.48	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.12.48	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_BASIC_V2 Frame(7)=1
sep-21 18.12.48	 	Event	Event Trigger "Lysstyring Garderobelys av 10 min etter bevegelse"
sep-21 18.12.48	 	Z-Wave	Device: 1.ETASJE Yttergang Multisensor yttergang Bevegelse Set to Off/Closed/No Motion
sep-21 18.12.48	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_SENSOR_BINARY Frame(7)=3
sep-21 18.12.48	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_NOTIFICATION_V6 Frame(7)=5
sep-21 18.12.34	 	Z-Wave	ApplicationCommandHandler from node 9 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
sep-21 18.12.33	 	Z-Wave	ApplicationCommandHandler from node 9 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
sep-21 18.12.32	 	Z-Wave	ApplicationCommandHandler from node 9 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
sep-21 18.12.20	 	Z-Wave	Setting device Stikkontakt 01- kW-timer to value 23,94
sep-21 18.12.20	 	Z-Wave	Set_New_Level, Parent: U.ETASJE KJELLER Stikkontakt 01- Root, Child:U.ETASJE KJELLER Stikkontakt 01- kW-timer
sep-21 18.12.20	 	Z-Wave	Set_New_Level_Real called for U.ETASJE KJELLER Stikkontakt 01- kW-timer, Type=COMMAND_CLASS_METER_V3, EndPoint=0
sep-21 18.12.20	 	Z-Wave	Set_New_Level_Real: Initial device is U.ETASJE KJELLER Stikkontakt 01- kW-timer
sep-21 18.12.20	 	Z-Wave	ApplicationCommandHandler from node 4 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
sep-21 18.12.20	 	Z-Wave	Set_New_Level_SWITCH_BINARY FINISHING(H) COMMAND_CLASS_SWITCH_BINARY
sep-21 18.12.20	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.12.20	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Garderobe Stikkontakt lys garderobe - Root, Child:1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter
sep-21 18.12.20	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter, Type=COMMAND_CLASS_SWITCH_BINARY, EndPoint=0
sep-21 18.12.20	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter
sep-21 18.12.20	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SWITCH_BINARY Frame(7)=3
sep-21 18.12.20	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=129
sep-21 18.12.20	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.12.20	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=64
sep-21 18.12.20	 	Z-Wave	Device: 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt Set to 19,2 (19,2 Watts)
sep-21 18.12.20	 	Z-Wave	Setting device Stikkontakt lys garderobe - Effekt to value 19,2
sep-21 18.12.20	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Garderobe Stikkontakt lys garderobe - Root, Child:1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt
sep-21 18.12.20	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt, Type=COMMAND_CLASS_METER_V3, EndPoint=0
sep-21 18.12.20	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt
sep-21 18.12.20	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
sep-21 18.12.19	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.12.19	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=128
sep-21 18.12.19	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.12.19	 	Z-Wave	UZB1: Sending to node 12 (Secure) CC=COMMAND_CLASS_SWITCH_BINARY
sep-21 18.12.18	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=128
sep-21 18.12.18	 	Device Control	Device: 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter to On (255)
sep-21 18.12.18	 	Event	Event Trigger "Lysstyring Garderobelys på ved bevegelse"
sep-21 18.12.18	 	Z-Wave	Setting device Multisensor yttergang Bevegelse to value 255
sep-21 18.12.18	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Yttergang Multisensor yttergang, Child:1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.12.18	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Yttergang Multisensor yttergang Bevegelse, Type=COMMAND_CLASS_SENSOR_BINARY, EndPoint=0
sep-21 18.12.18	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.12.18	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_BASIC_V2 Frame(7)=1
sep-21 18.12.18	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.12.18	 	Z-Wave	UZB1: Sending to node 12 (Secure) CC=COMMAND_CLASS_SWITCH_BINARY
sep-21 18.12.18	 	Event	Remove Delayed Device Action Removed event: Delayed Actions X - Stikkontakt lys garderobe - Bryter (Delayed Action)
sep-21 18.12.18	 	Z-Wave	Device: 1.ETASJE Yttergang Multisensor yttergang Bevegelse Set to On/Open/Motion
sep-21 18.12.18	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_SENSOR_BINARY Frame(7)=3
sep-21 18.12.18	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_NOTIFICATION_V6 Frame(7)=5
sep-21 18.12.17	 	Z-Wave	Setting device Multisensor yttergang Bevegelse to value 0
sep-21 18.12.17	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Yttergang Multisensor yttergang, Child:1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.12.17	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Yttergang Multisensor yttergang Bevegelse, Type=COMMAND_CLASS_SENSOR_BINARY, EndPoint=0
sep-21 18.12.17	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.12.17	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_BASIC_V2 Frame(7)=1
sep-21 18.12.17	 	Event	Event Trigger "Lysstyring Garderobelys av 10 min etter bevegelse"
sep-21 18.12.17	 	Z-Wave	Device: 1.ETASJE Yttergang Multisensor yttergang Bevegelse Set to Off/Closed/No Motion
sep-21 18.12.17	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_SENSOR_BINARY Frame(7)=3
sep-21 18.12.17	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_NOTIFICATION_V6 Frame(7)=5
sep-21 18.11.48	 	Z-Wave	Set_New_Level_SWITCH_BINARY FINISHING(H) COMMAND_CLASS_SWITCH_BINARY
sep-21 18.11.48	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.11.48	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Garderobe Stikkontakt lys garderobe - Root, Child:1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter
sep-21 18.11.48	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter, Type=COMMAND_CLASS_SWITCH_BINARY, EndPoint=0
sep-21 18.11.48	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter
sep-21 18.11.48	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SWITCH_BINARY Frame(7)=3
sep-21 18.11.48	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=129
sep-21 18.11.48	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.11.48	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=64
sep-21 18.11.48	 	Z-Wave	Setting device Stikkontakt lys garderobe - Effekt to value 19,4
sep-21 18.11.48	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Garderobe Stikkontakt lys garderobe - Root, Child:1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt
sep-21 18.11.48	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt, Type=COMMAND_CLASS_METER_V3, EndPoint=0
sep-21 18.11.48	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt
sep-21 18.11.48	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
sep-21 18.11.47	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.11.46	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=128
sep-21 18.11.46	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.11.46	 	Z-Wave	UZB1: Sending to node 12 (Secure) CC=COMMAND_CLASS_SWITCH_BINARY
sep-21 18.11.46	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.11.46	 	Device Control	Device: 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter to On (255)
sep-21 18.11.46	 	Event	Event Trigger "Lysstyring Garderobelys på ved bevegelse"
sep-21 18.11.46	 	Z-Wave	Setting device Multisensor yttergang Bevegelse to value 255
sep-21 18.11.46	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Yttergang Multisensor yttergang, Child:1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.11.46	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Yttergang Multisensor yttergang Bevegelse, Type=COMMAND_CLASS_SENSOR_BINARY, EndPoint=0
sep-21 18.11.46	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.11.46	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_BASIC_V2 Frame(7)=1
sep-21 18.11.46	 	Event	Remove Delayed Device Action Removed event: Delayed Actions X - Stikkontakt lys garderobe - Bryter (Delayed Action)
sep-21 18.11.46	 	Z-Wave	Device: 1.ETASJE Yttergang Multisensor yttergang Bevegelse Set to On/Open/Motion
sep-21 18.11.46	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_SENSOR_BINARY Frame(7)=3
sep-21 18.11.46	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_NOTIFICATION_V6 Frame(7)=5
sep-21 18.11.45	 	Z-Wave	Setting device Multisensor yttergang Bevegelse to value 0
sep-21 18.11.45	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Yttergang Multisensor yttergang, Child:1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.11.45	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Yttergang Multisensor yttergang Bevegelse, Type=COMMAND_CLASS_SENSOR_BINARY, EndPoint=0
sep-21 18.11.45	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Yttergang Multisensor yttergang Bevegelse
sep-21 18.11.45	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_BASIC_V2 Frame(7)=1
sep-21 18.11.45	 	Event	Event Trigger "Lysstyring Garderobelys av 10 min etter bevegelse"
sep-21 18.11.45	 	Z-Wave	Device: 1.ETASJE Yttergang Multisensor yttergang Bevegelse Set to Off/Closed/No Motion
sep-21 18.11.45	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_SENSOR_BINARY Frame(7)=3
sep-21 18.11.45	 	Z-Wave	ApplicationCommandHandler from node 17 HANDLING: COMMAND_CLASS_NOTIFICATION_V6 Frame(7)=5
sep-21 18.11.26	 	Z-Wave	Device: U.ETASJE KJELLER Multisensor Kjellertrapp - Lysnivå Set to 7 (Lux)
sep-21 18.11.26	 	Z-Wave	Setting device Multisensor Kjellertrapp - Lysnivå to value 7
sep-21 18.11.26	 	Z-Wave	Set_New_Level, Parent: U.ETASJE KJELLER Multisensor Kjellertrapp - Root, Child:U.ETASJE KJELLER Multisensor Kjellertrapp - Lysnivå
sep-21 18.11.26	 	Z-Wave	Set_New_Level_Real called for U.ETASJE KJELLER Multisensor Kjellertrapp - Lysnivå, Type=COMMAND_CLASS_SENSOR_MULTILEVEL_V7, EndPoint=-1
sep-21 18.11.26	 	Z-Wave	Set_New_Level_Real: Initial device is U.ETASJE KJELLER Multisensor Kjellertrapp - Lysnivå
sep-21 18.11.26	 	Z-Wave	ApplicationCommandHandler from node 19 HANDLING: COMMAND_CLASS_SENSOR_MULTILEVEL_V7 Frame(7)=5
sep-21 18.11.16	 	Z-Wave	Set_New_Level_SWITCH_BINARY FINISHING(H) COMMAND_CLASS_SWITCH_BINARY
sep-21 18.11.16	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.11.16	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Garderobe Stikkontakt lys garderobe - Root, Child:1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter
sep-21 18.11.16	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter, Type=COMMAND_CLASS_SWITCH_BINARY, EndPoint=0
sep-21 18.11.16	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter
sep-21 18.11.16	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SWITCH_BINARY Frame(7)=3
sep-21 18.11.16	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=129
sep-21 18.11.16	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.11.16	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=64
sep-21 18.11.16	 	Z-Wave	Device: 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt Set to 19,4 (19,4 Watts)
sep-21 18.11.16	 	Z-Wave	Setting device Stikkontakt lys garderobe - Effekt to value 19,4
sep-21 18.11.16	 	Z-Wave	Set_New_Level, Parent: 1.ETASJE Garderobe Stikkontakt lys garderobe - Root, Child:1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt
sep-21 18.11.16	 	Z-Wave	Set_New_Level_Real called for 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt, Type=COMMAND_CLASS_METER_V3, EndPoint=0
sep-21 18.11.16	 	Z-Wave	Set_New_Level_Real: Initial device is 1.ETASJE Garderobe Stikkontakt lys garderobe - Effekt
sep-21 18.11.16	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_METER_V3 Frame(7)=2
sep-21 18.11.15	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.11.14	 	Z-Wave	ApplicationCommandHandler from node 12 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=128
sep-21 18.11.14	 	Z-Wave	UZB1: Sending to node 12 (Undefined) CC=COMMAND_CLASS_SECURITY
sep-21 18.11.14	 	Z-Wave	UZB1: Sending to node 12 (Secure) CC=COMMAND_CLASS_SWITCH_BINARY
sep-21 18.11.14	 	Z-Wave	Setting device X - Stikkontakt lys garderobe - Bryter to value 255
sep-21 18.11.14	 	Device Control	Device: 1.ETASJE Garderobe X - Stikkontakt lys garderobe - Bryter to On (255)
sep-21 18.11.14	 	Event	Event Trigger "Lysstyring Garderobelys på ved bevegelse"
sep-21 18.11.14	 	Z-Wave	Setting device Multisensor yttergang Bevegelse to value 255
Se bort fra de reelle hendelsene, de liker jeg å ha i loggen, det er alt jibberishet jeg være foruten.
Andreas
Hvordan gjør DU det? Trodde jeg hadde deaktivert det meste av logging.
Har kun polling på de batteridrevne enhetene som rapporterer batteri. Er det nødvendig?
Har 23 timers intervall på den pollingen.
Hva poller du, og hvorfor?
Har ikke så mye greie på dette, men det så veldig "busy" ut i forhold til min logg. Det er en del typer meldinger jeg ikke kan huske å ha sett i min logg. Har du satt noen innstillinger for ekstra logging, f.eks på UZB1? Tror det er en eller annen innstilling der som gjør at den logger mer av trafikken.
Det ser ut som om du har Z-wave debugging på. Det behøver du ikke. Skru den av ved å gå til:
Plugins -> Manage. Trykk på Z-wave. Deaktiver "Log send and receive device information to the HomeSeer log" (og jeg håper at du ikke har valget under der aktivert).
Vanlig loggin deaktiveres på selve devicen (på den første tab'en). Aktiver "Do not log commands from this device".
@Moskus traff spikeren på hodet! ...igjen!
Det var akkurat det som var tilfellet!
Skulle av og til ønske at jeg ikke hadde admin-rettigheter i Homeseer ;)
Skal det se slik ut da altså?
