Jeg har ikke forsøkt dette selv, men mener flere har skrevet om utfordringer med å trigge events med S2? Dette vil kanskje løse problemet?
Sitat
Changed in version 3.0.1.150 (Beta)
* Added support for HS3 to trigger on scene activations from other devices, such as the Fibaro Dimmer 2. The HS3 scene activation trigger will trigger on any scene # sent to HS3 even if no device exists in the system that is assigned that scene #.
https://forums.homeseer.com/showthread.php?t=175414
