Denne vil jeg tro er interessant for opptil flere:
The DoorBird 2-Wire Ethernet PoE Converter is probably the worlds smallest and most powerful converter that transmits network data (Ethernet) and power (PoE) over long distances over a simple two-wire line. For example; existing buildings with a simple two-wire bell wire can be equipped with network technology without having to retrofit any network cables.
datasheet_a1071_en.pdf
Den var spennende, tror jeg skal ha et par..
Jeg bruker også en del PoE til USB+ethernet, driver blant annet Trådfri-hub'en og noen raspberry pi med denne:
https://www.aliexpress.com/item/Active-PoE-Splitter-Power-Over-Ethernet-48V-to-5V-2-4A-Micro-USB-4-Raspberry-Pi/32800364355.html
(edit; whups, ikke akkurat samme ting, men sikkert nyttig for andre som vil bruke PoE mer)
Endret av Sig_rd
