Lar deg sette en vilkårlig device som Root med vilkårlige devicer som Child Devices.
Parameter: RooTID|child1ID,child2ID,etc
Sub Main(ByVal params As String)
        Dim lines() As String = params.ToString.Split("|")
        Dim rootRef As Integer = lines(0)
        Dim children() As String = lines(1).Split(",")
        Dim rootDevice As Scheduler.Classes.DeviceClass = hs.GetDeviceByRef(rootRef)
        rootDevice.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Parent_Root
        Dim childDevice As Scheduler.Classes.DeviceClass
        For Each c As Integer In children
            childDevice = hs.GetDeviceByRef(c)
            rootDevice.AssociatedDevice_Add(hs, c)
            childDevice.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Child
            childDevice.AssociatedDevice_Add(hs, rootRef)
        Next
    End Sub
