Frontend improvements continue
Thanks to @Andrey-git we now have an option to consume the frontend in modern JavaScript. This makes the frontend faster to download and run. For now it's opt-in but we're looking into making it opt-out in the future. The ES5 version of the frontend will remain available for older devices.
To use it in on a single browser, add ?latest to your Home Assistant bookmark. To make it the default for browsers opening the frontend, update your config to look like this:
frontend:
  javascript_version: latest
Note on custom UI: this will need to be updated to work with the untranspiled version and won't work out of the box.
System log enhanced
Our about screen that shows the error logs has gained a nice upgrade by @postlund. Now the 50 latest exceptions will be displayed with the option to get more information.
The Hass.io release will be delayed by a couple of days because Pascal is moving this weekend.
New Platforms
Breaking Changes
  • hass.states.is_state_attr(entity_id, attribute, value)has been removed. The template version still exists. Unused method parameter wait has been removed from hass.bus.async_fire(@balloob - #10305) (breaking change)
  • Refactor Neato botvac components as a vacuum (@jabesq - #9946) (neato docs) (switch.neato docs) (vacuum.neato docs) (breaking change) (new-platform)
  • Lutron released a firmware updated for the Caseta system which removed our ability to connect to and control the bridge device over SSH, breaking compatibility with pylutron_caseta and Home Assistant. Component has been updated to work again, please see the docs on how to set it up. (@mdonoughe - #10286) (lutron_caseta docs) (breaking change)
All changes
