Jeg kjører Linuz på Raspberry server.
Plutselig så har det skjedd noe.
Så nå får jeg ikke slått av og på lyset her.
Noe forslag?
jan-23 00.39.44   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.44   Z-Wave New Interface: The Z-Wave Command Execution Thread was Started or Restarted.
jan-23 00.39.44   Z-Wave New Interface: ----------------------------------------------------------------------
jan-23 00.39.44   Z-Wave Initializing Z-Wave interface New Interface (Aeon Labs Aeotec Z-Stick) on /dev/ttyACM0
jan-23 00.39.44   Z-Wave New Interface: ======================================================================
jan-23 00.39.42   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.40   Z-Wave Warning Z-Wave Interface New Interface (Node 1) on Network EC19570F FAILED initialization with the message: Timeout looking for Z-Wave interface., will keep trying.
jan-23 00.39.40   Z-Wave Error New Interface: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
jan-23 00.39.40   Z-Wave Error New Interface: Timeout looking for Z-Wave interface.
jan-23 00.39.36   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.35   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.28   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.26   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.26   Z-Wave New Interface: The Z-Wave Command Execution Thread was Started or Restarted.
jan-23 00.39.26   Z-Wave New Interface: ----------------------------------------------------------------------
jan-23 00.39.26   Z-Wave Initializing Z-Wave interface New Interface (Aeon Labs Aeotec Z-Stick) on /dev/ttyACM0
jan-23 00.39.26   Z-Wave New Interface: ======================================================================
jan-23 00.39.22   Z-Wave Warning Z-Wave Interface New Interface (Node 1) on Network EC19570F FAILED initialization with the message: Timeout looking for Z-Wave interface., will keep trying.
jan-23 00.39.22   Z-Wave Error New Interface: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
jan-23 00.39.22   Z-Wave Error New Interface: Timeout looking for Z-Wave interface.
jan-23 00.39.19   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.17   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.08   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.08   Z-Wave New Interface: The Z-Wave Command Execution Thread was Started or Restarted.
jan-23 00.39.08   Z-Wave New Interface: ----------------------------------------------------------------------
jan-23 00.39.08   Z-Wave Initializing Z-Wave interface New Interface (Aeon Labs Aeotec Z-Stick) on /dev/ttyACM0
jan-23 00.39.08   Z-Wave New Interface: ======================================================================
jan-23 00.39.07   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.04   Z-Wave Warning Z-Wave Interface New Interface (Node 1) on Network EC19570F FAILED initialization with the message: Timeout looking for Z-Wave interface., will keep trying.
jan-23 00.39.04   Z-Wave Error New Interface: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
jan-23 00.39.04   Z-Wave Error New Interface: Timeout looking for Z-Wave interface.
jan-23 00.39.02   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.39.00   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.38.53   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.38.50   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.38.50   Z-Wave New Interface: The Z-Wave Command Execution Thread was Started or Restarted.
jan-23 00.38.50   Z-Wave New Interface: ----------------------------------------------------------------------
jan-23 00.38.50   Z-Wave Initializing Z-Wave interface New Interface (Aeon Labs Aeotec Z-Stick) on /dev/ttyACM0
jan-23 00.38.50   Z-Wave New Interface: ======================================================================
jan-23 00.38.49   Z-Wave Warning New Interface: The serial port (/dev/ttyACM0) was not found in the system. Will keep waiting for it...
jan-23 00.38.46   Z-Wave Warning Z-Wave Interface New Interface (Node 1) on Network EC19570F FAILED initialization with the message: Timeout looking for Z-Wave interface., will keep trying.
jan-23 00.38.46   Z-Wave Error New Interface: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
jan-23 00.38.46   Z-Wave Error New Interface: Timeout looking for Z-Wave interface.
Endret av Rune L
Slå av z-wave plugin, ta ut og inn USB-pinnen og start z-wave igjen.
Er det en UZB1?
Det har kommet en beta av z-wave-plugin som retter en feil mot UZB1-interface.
4 minutter siden, Rune L skrev:
Hvor finner jeg den betaversjonen?
Plugins-manage.
Helt nederst der er det den beta-seksjon.
Husk backup!
35 minutter siden, Rune L skrev:
modulen heter
ZW090-C
PC Interface - ZW090
Aha, da er det Aeotech sin.
Dette er den som de har fikset en bug for: https://www.tronika.no/no/interface/760-interface-uzb1.html
Changed in version 3.0.1.179 (Beta)
* Fixed plugin not always starting up with UZB interface
Kan uansett være verdt et forsøk. :)
34 minutter siden, Rune L skrev:
Det må du forklare bedre. bruker homeseer
1: image.png.2201a1e60dde218353211c07c27926e8.png
2: image.png.7b2778d8a56f9425d9ab10ea4b6dfff4.png
3: image.png.8849a2ae81c6b7d3ef95ffcf54fafff7.png
4: image.png.8e25eb1729af404434b2294523174c80.png
Moderator:
Slo sammen den nye tråden din (under) med denne, siden det er samme sak. :)
Jeg har en z-wave modul som jeg har mistanke om at har sluttet å fungere,
Eller att programmet på server har tullet seg til .
https://www.tronika.no/no/interface/830-interface-zw090.html
Kjører raspberry pi
Linux
Homeseer.
Noen som kan hjelpe meg personlig. online?
Har ikke lys i huset  :-)
