1 time siden, Vitellius skrev:
Er lite bevandret i Arduino-verden.
Hvilke konkrete bruksområde(r) har dette produktet? En Z-wave gateway til et 1-Wire nettverk?
F.eks, samtidig som den styrer en par releer, en LCD skjerm og andre morsomme ting.
En Arduino er en programmerbar microcontroller som kan lese og sende digitale og analoge signaler. Har man kunnskap nok om elektronikk og noe programmering, er det knapt begrensninger på det man kan få til.
Jeg bruker en Arduino, styrt over nettverk, til å kontrollere vanningsanlegget.
Z-Uno is comming!
Dear Z-Uno followers!
We are happy to announce that Z-Uno is now available for pre-order from Z-Wave Europe. Currently only 868/869 MHZ version is available (Europe and Russia). Check your local Z-Wave distributor for availability in your preferred e-shop.
Meanwhile we have released new Z-Uno software version 0.7.1. What's new?
  • New 10 channels certification sketch added to examples (Z-Wave Plus certified sketch)
  • Fixed problem with Z-Uno having nodeId > 50 (was unstable in large networks)
  • Many minor fixes (listed on github)
We are also working to release C++ version soon (version 2.0.3). What will be new in C++ version?
  • DHT-11 library built in
  • 1-wire, SPI and I2C protocols support
  • many-many fixes
Documentation on our website is also improving. New examples added (like this CO2 sensor). More examples and projects will be added soon.
Copyright © 2016 Z-Wave.Me, All rights reserved.
You are receiving this email because you subscribed to Z-Uno mailing list.
Our mailing address is:
Z-Wave.Me
ul. Schepkina, 47
Moscow, 129110
Russia
Add us to your address book
Want to change how you receive these emails?
You can update your preferences or unsubscribe from this list
Email Marketing Powered by MailChimp
open.php?u=65cf062504578d2e2e81f8aeb&id=
View full record
Bare en liten presisering:
Z-uno er ikke en addon til en Arduino, det er en selvstendig microprosessor som kan programmeres med Arduino programmerings miljøet.
Den har en innebygget Z-wave modul som kan eksponere forskjellige z-wave devicer etter behov og har pinner som du kan måle/styre ting med, med din egen kode mellom z-wave enheten og pinnene.
Den er tenkt til å bygge z-wave moduler med for input / output og en del innebygget intelligens.
denne må da være genial om man vil ha en "skru-dimmer".
1 stk zuno, 1 stk rotary encoder og et dimmerhjul. da kan man vel med litt koding få til å justere opp og ned dimnmenivå...
spørs om ikke jeg må kjøpe en slik nå..
Genial idé! Noen må lage dette og selge det! Nå!
... og legge ut beskrivelsen til oss andre. ;)
har da bestillt noen rotary encodere for å teste litt mot en vanlig arduino. må vel oppgradere til en zuno etterhvert =)
Rotary encodere fungerer fint med Arduino. Bare husk å "wrappe" verdien når du kommer til 1024 tilbake til 0 (og legg inn en sjekk at hvis du krysset 0 så er det fortsatt en økning), så kan du skru så lenge du orker. :)
It happened! Z-Uno is available for order!
Find you favorite Z-Wave shop in our Where to buy list. More resellers to be listed soon. Start working with your Z-Uno board by following instructions on Getting started page.
If you experience a problem with your Z-Uno, please check for a solution on Troubleshooting page. If this does not help, please write us on the forum or by mail on [email protected].
We would also like to encourage you to share your projects with others. Send us descriptions, photos, schematics and sketch to upload on Z-Uno Projects page.
New C++ beta released (version 2.0.3). What's new?
  • millis() function implemented
  • Serial avaliable, peek, parseInt, parseFloat
  • I2C library added (Wire.h)
  • based on I2C library and example for MCP23017
  • based on I2C library and example for BMP180
  • SPI library added (SPI.h)
  • Keypad library added (called ZMEKeypad)
  • fixed update problems from 0.6.2, 0.6.3, 0.6.7, 0.7.0 and 2.0.x
  • bits operations: bitRead, bitSet, bitClear, bitWrite
  • Macro ARDUINO and F_CPU added
Like before, this C++ beta release is available under http://rus.z-wave.me/files/z-uno/test-ucxx/package_z-wave.me_index.json URL (please remove stable URL in Arduino IDE settings and put this instead)
In next versions we will add DHT11 and some other examples. We plan to finally release stable C++ version in August to substitute current 0.x.x branch (C only) by C++ enabled 2.x.x branch.
Z-Wave.Me
ul. Schepkina, 47
Moscow, 129110
Russia
Ser de skal ha 100,- mer enn Tronika. Hvordan er det med toll/merverdiavgift når du handler hos m.nu? må vel legge på 25%?
De trekker fra svensk mva. (25%) når det sendes til Norge.
Jeg har noen sketcher liggende, for styring av diverse. Er det «mye ekstra» som må til for å bruke disse i Zuno?
Har bl.a annet planer om å bruke akkustsk avstandsmåler for i indikere om det står biler på gårdsplassen. Noen som har gjort noe lignende?
Nei, men jeg har en tilsvarende plan.
Hvis du gjør noe med det, så del gjerne! :)
Håper det starter et marked for folk som lager ting av denne og selger, for jeg tror dessverre ikke jeg har det som skal for å gjøre særlig nytte med denne selv.
8 timer siden, GeneralVirus skrev:
Hvorfor fins det ikke ett Z-Wave shield til Arduino?
... fordi nå kan man like greit kjøpe Z-Uno...?
Ellers så jeg nettopp ZIY: Z-wave It Yourself.
Note to self: IKKE koble når man er trøtt å sliten midt på natta.
Klarte å kortslutte og ødelegge hele z-uno-en :(
Men det var moro og enkelt å jobbe mot så har bestilt 2 nye...
