https://community.logitech.com/s/question/0D55A00008D2zYDSAZ/harmony-hub-fw-415206
Logitech har postet denne:
  Sitat
Harmony Hub FW 4.15.206
Hi folks. We are aware of the feedback from some Harmony Hub customers about firmware version 4.15.206.
We recently released a firmware update for Harmony hub-based remotes. A few consumers have told us they are experiencing issues with certain configurations of the these remotes. We will follow up soon with more details.
Thank you for your patience.
En som jobber høyt i systemet til Logitech (Todd Walker) har bekreftet nå på twitter at de nå ikke har noen planer for å legge tilbake lokal kontroll.
Ser ut som det kommer en løsning snart for Harmony  componenten til Home Assistant. De skal etter planen slippe en fiks idag som gjør at man igjen kan kontrollere de.
https://www.home-assistant.io/blog/2018/12/17/logitech-harmony-removes-local-api/
  Sitat
Home Assistant developer @ehendrix23, with the help of @chadcb and other amazing people in the comments to this post, did manage to figure out how the local websocket API works for the Logitech Harmony, which is also used by the Logitech Harmony iOS app. There is now an open pull request for Home Assistant to update the Harmony integration to use it. This PR is currently being tested, and if all works well, will be released as a hot fix on the 19th.
  Dennis87 skrev (På 19.12.2018 den 8.53):
Da er det bare å hamre på Twitter til de forandrer mening. Dette er ikke OK.
Problemet med Websocket løsningen er vel at den bl.a. ikke publiserer "Activities", men får håpe noen finner ut av det...
