Noen som vet hva dette betyr?
18.02.2018 22:05:40
Could not load file or assembly 'System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The module was expected to contain an assembly manifest.
HomeSeer version: 3.0.0.368
Source: Scheduler
Target: Void WriteMon(System.String, System.String, System.String, Int32, System.String, Int32)
Stack trace:
   at Scheduler.Global_Utils.WriteMon(String mtype, String msg, String color, Int32 Pri, String sFrom, Int32 ErrorCode)
   at Scheduler.SC_Main.ShutDown()
   at HS3.Form1.Form1_FormClosing(Object sender, FormClosingEventArgs e)
   at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
   at System.Windows.Forms.Form.WmClose(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Please specify what you were doing at the time of this error:
Jeg lukket HomeSeer og slo av maskinen pga jeg måtte ta strømmen på det rommet den står.
Når jeg skulle starte HomeSeer på nytt ville den ikke starte.
Fant ut til slutt at jeg skulle prøve å installere Windows updates som ikke var installert og da løste det seg med ny reboot ?
