GrandbeingMX0404.vb
Script for å styre en Grandbeing MX0404 HDMI matrise. Lager en root med tilhørende child-devicer for hver utgang hvor man kan trykke på de forskjellige inngangene. Alt i et script, men dette blir nok en plugin på sikt (der er det lettere å få til en autorefresh, og sånt).
    '© Moskus 2014
    Dim Scriptname As String = "GrandbeingMX0404.vb"
    Dim hdmi_outputs() As String = {"None", "TV", "SageTV", "Xbox", "Extra"}
    Dim ip_address As String = "192.168.0.39"
    Public Sub Main(parm As Object)
    End Sub
    Public Sub Setup(parm As Object)
        'Setting up devices
        'Creating master device
        Dim dt As New HomeSeerAPI.DeviceTypeInfo
        Dim devref As Integer = hs.NewDeviceRef("Root")
        Dim dv As Scheduler.Classes.DeviceClass = hs.GetDeviceByRef(devref)
        Try
            dv.Location(hs) = "HDMI matrix"
            dv.Location2(hs) = "Media"
            dv.Device_Type_String(hs) = "HDMI root"
            dv.DeviceType_Set(hs) = New HomeSeerAPI.DeviceTypeInfo
            dv.Status_Support(hs) = True
            dv.Can_Dim(hs) = False
            hs.SaveEventsDevices()
            dv.MISC_Set(hs, HomeSeerAPI.Enums.dvMISC.SHOW_VALUES)
            dv.MISC_Clear(hs, HomeSeerAPI.Enums.dvMISC.STATUS_ONLY)
            'Adding a "Refresh" button to the root device
            hs.DeviceScriptButton_AddButton(devref, "Refresh", 0, Scriptname, "ButtonPress", "Refresh", 1, 1, 1)
            Dim SVpair As New HomeSeerAPI.VSPair(HomeSeerAPI.ePairStatusControl.Status)
            SVpair.PairType = HomeSeerAPI.VSVGPairType.SingleValue
            SVpair.Value = 0
            SVpair.Status = "HDMI matrix"
            hs.DeviceVSP_AddPair(devref, SVpair)
            Dim VGpair As New HomeSeerAPI.VGPair
            VGpair.PairType = HomeSeerAPI.VSVGPairType.SingleValue
            VGpair.Set_Value = 0
            VGpair.Graphic = "images/Moskus/icon_hdmi.png"
            hs.DeviceVGP_AddPair(devref, VGpair)
            hs.WriteLog("HDMI matrix", "Root device for HDMI matrix created")
        Catch ex As Exception
            hs.WriteLog("HDMI matrix", "Error creating root device: " & ex.Message)
        End Try
        'Creating child devices
        dv.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Parent_Root
        For i As Integer = 1 To 4
            Dim childref As Integer = CreateOutputDevice(i, devref)
            If childref > 0 Then dv.AssociatedDevice_Add(hs, childref)
        Next
    End Sub
    Public Function CreateOutputDevice(ByVal output As Integer, masterdevice As Integer) As Integer
        'Creating device
        Dim devref As Integer = hs.NewDeviceRef("Output " & output)
        Try
            dv.Device_Type_String(hs) = "HDMI out " & output
            dv.Relationship(hs) = HomeSeerAPI.Enums.eRelationship.Child
            dv.AssociatedDevice_Add(hs, masterdevice)
            dv = Nothing
            hs.WriteLog("HDMI matrix", "Test Device for output " & output & " created")
            hs.WriteLog("HDMI matrix", "Error creating devices: " & ex.Message)
            Return 0
        End Try
        Dim SVpair_off As New HomeSeerAPI.VSPair(HomeSeerAPI.ePairStatusControl.Status)
        SVpair_off.PairType = HomeSeerAPI.VSVGPairType.SingleValue
        SVpair_off.Value = 0
        SVpair_off.Status = "None"
        hs.DeviceVSP_AddPair(devref, SVpair_off)
        Dim VGpair_off As New HomeSeerAPI.VGPair
        VGpair_off.PairType = HomeSeerAPI.VSVGPairType.SingleValue
        VGpair_off.Set_Value = 0
        VGpair_off.Graphic = "images/Moskus/icon_hdmi_X.png"
        hs.DeviceVGP_AddPair(devref, VGpair_off)
        'Adding buttons, values and graphic
            hs.DeviceScriptButton_AddButton(devref, output & "-" & i, i, Scriptname, "ButtonPress", output & "-" & i, 1, i, 1)
            SVpair.Value = i
            SVpair.Status = "Input " & i
            VGpair.Set_Value = i
            VGpair.Graphic = "images/Moskus/icon_hdmi_" & i & ".png"
        Next
        Return devref
    End Function
    Public Sub ButtonPress(Input As Object)
        Dim devref As Integer = Input(0)
        Dim ButtonName As String = Input(1)
        Dim output As String = String.Empty 'Gets filled by GetURLIE
        Dim device As Integer = 0
        Dim master As Integer = hs.GetDeviceParentRefByRef(devref)
        If master = 0 Then master = devref
        Dim dv As Scheduler.Classes.DeviceClass = hs.GetDeviceByRef(master)
        For Each devid As Integer In dv.AssociatedDevices(hs)
            Dim dev As Scheduler.Classes.DeviceClass = hs.GetDeviceByRef(devid)
            Select Case dev.Device_Type_String(hs)
                Case Is = "HDMI root"
                    device = 0
                Case Is = "HDMI out 1"
                    device = 1
                Case Is = "HDMI out 2"
                    device = 2
                Case Is = "HDMI out 3"
                    device = 3
                Case Is = "HDMI out 4"
            End Select
        Next
        Dim command As String = "Refresh"
        If device > 0 Then
            Dim value As Integer = hdmi_outputs.ToList.IndexOf(ButtonName)
            command = device & "-" & value
        End If
        Select Case command
            Case Is = "Refresh"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=refrash", True) '"refrash" is actually not a typo on my part...
            Case Is = "1-1"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a09", True)
            Case Is = "1-2"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a1D", True)
            Case Is = "1-3"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a1F", True)
            Case Is = "1-4"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a0D", True)
            Case Is = "2-1"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a17", True)
            Case Is = "2-2"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a12", True)
            Case Is = "2-3"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a59", True)
            Case Is = "2-4"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a08", True)
            Case Is = "3-1"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a5E", True)
            Case Is = "3-2"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a06", True)
            Case Is = "3-3"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a05", True)
            Case Is = "3-4"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a03", True)
            Case Is = "4-1"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a18", True)
            Case Is = "4-2"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a44", True)
            Case Is = "4-3"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a0F", True)
            Case Is = "4-4"
                output = hs.GetURLIE("http://" & ip_address & "/get_data?type=port&cmd=a51", True)
        End Select
        InterpretOutput(devref, output)
    End Sub
    Public Sub InterpretOutput(ByVal devref As Integer, ByVal output As String)
        'output: Output1=1Output2=1Output3=1Output4=1
        Dim data(3) As Integer
        data(0) = CInt(output(8).ToString)
        data(1) = CInt(output(17).ToString)
        data(2) = CInt(output(26).ToString)
        data(3) = CInt(output(35).ToString)
                    If hs.DeviceValue(devid) <> data(0) Then
                        hs.SetDeviceValueByRef(devid, data(0), True)
                    Else
                        hs.SetDeviceValueByRef(devid, data(0), False)
                    End If
                    If hs.DeviceValue(devid) <> data(1) Then
                        hs.SetDeviceValueByRef(devid, data(1), True)
                    Else
                        hs.SetDeviceValueByRef(devid, data(1), False)
                    End If
                    If hs.DeviceValue(devid) <> data(2) Then
                        hs.SetDeviceValueByRef(devid, data(2), True)
                    Else
                        hs.SetDeviceValueByRef(devid, data(2), False)
                    End If
                    If hs.DeviceValue(devid) <> data(3) Then
                        hs.SetDeviceValueByRef(devid, data(3), True)
                    Else
                        hs.SetDeviceValueByRef(devid, data(3), False)
                    End If
            End Select
        Next
    End Sub
Gir:
Jeg har laget en ett matrise oppsett med VIrtuelle Devicer, men mine innganger er ikke gruppert sånn som dine. Jeg ser du gjør dette via ett script, betyr det at devicene blir opprettet hver gang du kjører dette scriptet. Når kjører du det ? Er det mulig å gruppere devicer i fra Websiden, eller må dette gjøres vha script ?
Som du ser i scriptet har jeg en "Setup()" rutine.
Her er "dv" root-devicen, og siste delen lager children og assosierer dem med root:
Next
  • 10 måneder senere...
Hva gjør den siste subrutina ?
Hva er output(8), output(17), output(26), og output(35) ?
"Output" er bare en laaaang streng. "Output(8)" henter ut den niende bokstaven (som "Char") og konverterer den til String. Og deretter blir hele sulamiten konvertert til et tall. :)
