Fått instalert 2 Aeon Home Meter zw095. Den ene virker veldig bra, men den andre oppdaterer ikke 2 device slik den andre gjøre.
Watt2 og Ampers 2 blir ikke oppdatert alså.
Fra loggen :
apr-13 20:04:32   Z-Wave Device: Node 5 Z-Wave Amperes 1 Set to 7,05 (7,05 Amperes)
apr-13 20:04:32   Z-Wave Device: Node 5 Z-Wave Volts 1 Set to 226,615 (226,615 Volts)
apr-13 20:04:32   Z-Wave Device: Node 5 Z-Wave Watts 1 Set to 1389,452 (1389,452 Watts)
apr-13 20:04:31   Z-Wave Device: Node 5 Z-Wave kW Hours 1 Set to 1,616 (1,616 kW Hours)
apr-13 20:04:31   Z-Wave Device: Node 5 Z-Wave Amperes 3 Set to 7,031 (7,031 Amperes)
apr-13 20:04:31   Z-Wave Device: Node 5 Z-Wave Volts 3 Set to 228,663 (228,663 Volts)
apr-13 20:04:31   Z-Wave Device: Node 5 Z-Wave Watts 3 Set to 1386,989 (1386,989 Watts)
apr-13 20:04:31   Z-Wave Device: Node 5 Z-Wave kW Hours 3 Set to 1,607 (1,607 kW Hours)
apr-13 20:04:31   Z-Wave Device: Node 5 Z-Wave Volts 2 Set to 224,509 (224,509 Volts)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Volts 1 Set to 226,21 (226,21 Volts)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Amperes 1 Set to 7,583 (7,583 Amperes)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Watts 1 Set to 1465,221 (1465,221 Watts)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave kW Hours 1 Set to 7,058 (7,058 kW Hours)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Amperes 3 Set to 8,975 (8,975 Amperes)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Volts 3 Set to 227,983 (227,983 Volts)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Watts 3 Set to 1820,58 (1820,58 Watts)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave kW Hours 3 Set to 4,277 (4,277 kW Hours)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Amperes 2 Set to 13,824 (13,824 Amperes)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Volts 2 Set to 224,42 (224,42 Volts)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave Watts 2 Set to 3072,662 (3072,662 Watts)
apr-13 20:04:03   Z-Wave Device: Node 4 Z-Wave kW Hours 2 Set to 10,944 (10,944 kW Hours)
Node 5 sender alså ikke watt2 og amperes2. Men alt ser riktig ut.
Noen tips til hva jeg kan prøve.
Har gjort FW upgrade, fjernet og lagt inn igjen uten endring i resultat.
Kan dette være relevant?
Changed in version 3.0.1.208 (Beta)
* Fixed AEOTEC Home Energy meter not adding properly in secure mode
Gjelder Z-wave plugin.
