Har tidligere fått instalert 2 stk Aeotec Home Energy målere (zw095-C).
Disse prøver jeg nå å sette opp slik at jeg kan se hva huset bruker av strøm.
MEN.... Jeg sjønner at ikke det kan være så enkelt som å bare montere og bruke ting i denne hjemmeautomasjon verden.
Jeg har sett at @Moskus messer om at Homeseer skal i gruppe 1 uten endpoint.  Men får dette tilbake fra loggen
Quote
mai-01 17:46:20   Z-Wave 3 out of 3 Child devices of node 4 were created successfully.
mai-01 17:46:19   Z-Wave Getting association information for Energi Hele Huset HeleHuset
mai-01 17:46:18   Z-Wave Assigning return route from node 1 to Energi Hele Huset HeleHuset
mai-01 17:46:18   Z-Wave Z-wave: Adding association for Z-Wave device Energi Hele Huset HeleHuset (Node 4, Group 1, Endpoint 1) to HomeSeer
mai-01 17:46:18   Z-Wave All associations for node 4 have been retrieved successfully, it supports associations on these groups: 1.
mai-01 17:46:18   Z-Wave Node 4 Association Group 1 can have 5 associations, and currently has 2
mai-01 17:46:18   Z-Wave Getting association information for node 4
mai-01 17:46:18   Z-Wave Warning Could not get the METER TYPE from node 4, so devices for the METER class will not be created or rebuilt.
mai-01 17:46:18   Z-Wave Processing Information for Node 4 Multi-CHANNEL Command Class of METER_V3, Endpoint 3
mai-01 17:46:18   Z-Wave Processing Information for Node 4 Multi-CHANNEL Command Class of METER_V3, Endpoint 2
mai-01 17:46:18   Z-Wave Processing Information for Node 4 Multi-CHANNEL Command Class of METER_V3, Endpoint 1
mai-01 17:46:18   Z-Wave Node 4 is a Z-Wave Plus node. Retrieving ZWPlus Info...
mai-01 17:46:18   Z-Wave Node 4 is Z-Wave version: Lib: 4,34 App: 1.4
mai-01 17:46:17   Z-Wave Node: 4 Controls Class(es): MARK
mai-01 17:46:17   Z-Wave Node: 4 Supports Class(es): ZWAVEPLUS_INFO, VERSION_V2, MANUFACTURER_SPECIFIC_V2, METER_V3, CRC_16_ENCAP, MULTI_CHANNEL_V3, MULTI_CHANNEL_ASSOCIATION_V3, CONFIGURATION_V4, ASSOCIATION_GRP_INFO_V2, ASSOCIATION_V2, FIRMWARE_UPDATE_MD_V2, POWERLEVEL, DEVICE_RESET_LOCALLY
mai-01 17:46:17   Z-Wave Syncing Z-Wave nodes with device list...
<br> Så må jeg faktisk sette endpoint på denne eller trenger jeg ikke?
Eventuelt hva må jeg gjøre for å få dette riktig ??
Takk
2 minutes ago, Moskus said:
Dette har mer med oppsett å gjøre enn assosiasjoner. Kjører du siste Z-wave plugin versjon? Prøvd beta?
Z-wave 3.0.1.190
Nei Ikke prøvd BETA :)
@Moskus
Det ser ut som du har rett med endpoint. det virker i alle fall.
Beta prøvd Annet problem.
Fra loggen :
Quote
mai-01 20:05:02   Z-Wave Warning
(2) Received a METER class report from node 5 for MT=Electric_meter, MST=0, but the corresponding child device could not be found.
Har som sagt to like Node 4 og node 5.
Trodde jeg hadde satt opp alt likt, men det ser jo ikke slik ut da. ?
Noen som har noen hint ?
Endret av clio75
41 minutes ago, ZoRaC said:
Mulig du må ta en exclude/include etter du oppdatert plugin?
Takk for tips, men samme feil etter ekskludering og inkludering.
mai-01 21:07:57   Z-Wave Warning (2) Received a METER class report from node 16 for MT=Electric_meter, MST=0, but the corresponding child device could not be found.
Ja Ja Morsomt med problemer som bare blir borte. ?
Case Closed. Vi får fortsette diskusjonen om feilen dukker opp i igjen hos noen andre
