Noen som kjører id lock 150 her i OH? Sliter med at den sender "doble" kommandoer, dvs. at den går ON/OFF 2 ganger før den er ferdig med låsing/åpning. Lager noe trøbbel for reglene mine O.o
Låsing via Z-WAVE (ON):
2018-10-16 13:54:12.465 [ome.event.ItemCommandEvent] - Item 'MyLockSwitch ' received command ON
2018-10-16 13:54:12.469 [nt.ItemStatePredictedEvent] - MyLockSwitch predicted to become ON
2018-10-16 13:54:12.476 [vent.ItemStateChangedEvent] - MyLockSwitch changed from OFF to ON
2018-10-16 13:54:14.140 [vent.ItemStateChangedEvent] - MyLockSwitch changed from ON to OFF
2018-10-16 13:54:15.763 [vent.ItemStateChangedEvent] - MyLockSwitch changed from OFF to ON
Åpne lås via Z-WAVE (OFF):
2018-10-16 13:54:24.241 [ome.event.ItemCommandEvent] - Item 'MyLockSwitch ' received command OFF
2018-10-16 13:54:24.246 [nt.ItemStatePredictedEvent] - MyLockSwitch predicted to become OFF
2018-10-16 13:54:24.250 [vent.ItemStateChangedEvent] - MyLockSwitch changed from ON to OFF
2018-10-16 13:54:25.917 [vent.ItemStateChangedEvent] - MyLockSwitch changed from OFF to ON
2018-10-16 13:54:26.481 [vent.ItemStateChangedEvent] - MyLockSwitch changed from ON to OFF
Låse manuelt via insiden (inside):
2018-10-16 13:55:53.986 [vent.ItemStateChangedEvent] - MyLockSwitch changed from OFF to ON
Åpne manuelt fra innsiden (inside):
2018-10-16 13:56:11.513 [vent.ItemStateChangedEvent] - MyLockSwitch changed from ON to OFF
Som beskrevet ovenfor skjer dette kun ved å låse via Z-Wave kommando, ved manuell låsing kommer det bare en state change.
Endret av Alpøy
