Sliter med å få til Pulse - noen tips. Når jeg legger inn Home-ID, så vil ikke plugin. Prøver jeg å starte HSPI_TibberSeer manuelt - får jeg dette i logget;
Connecting to server at 127.0.0.1...
Connected, waiting to be initialized...
Starting initializiation.
CheckAndCreateDevices; Found roots count: 3
30.03.2019 19:51:22: Found price root: 5407
Updating Status Graphics...
30.03.2019 19:51:22: Found consumption root: 5441
30.03.2019 19:51:22: Found realtime root: 5446
CheckAndCreateDevices done!
30.03.2019 19:51:23: TibberRealtime new, root: 5446
StartLiveMeasurementListener starting...
Unhandled Exception: System.NullReferenceException: Objektreferanse er ikke satt til en objektforekomst.
   ved Tibber.Sdk.LiveMeasurementListener.<InitializeInternal>d__11.MoveNext()
--- Slutt på stakksporing fra forrige plassering der unntak ble iverksatt ---
   ved System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   ved System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   ved Tibber.Sdk.LiveMeasurementListener.<Initialize>d__10.MoveNext()
   ved Tibber.Sdk.TibberApiClient.<StartLiveMeasurementListener>d__14.MoveNext()
   ved HSPI_TibberSeer.TibberRealtime.VB$StateMachine_14_StartLiveMeasurementListener.MoveNext()
   ved System.Runtime.CompilerServices.AsyncMethodBuilderCore.<>c.<ThrowAsync>b__6_1(Object state)
   ved System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
   ved System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   ved System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   ved System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   ved System.Threading.ThreadPoolWorkQueue.Dispatch()
   ved System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
Prøvd å slette alle filer for plugin, inkl.config - lastet ned på nytt - samme utfordring.
Har BKK. Får data når jeg tester developer-api explorer. Noen vært borti dette ? Kanskje jeg trenger litt hjelp av @Moskus
Begynte plutselig å fungere her hos meg i dag - uten at jeg har gjort noe. Vet Tibber har hatt noe nedetid på Pulse i forbindelse med sommertid - kanskje det har trigget noe. Uansett, alt ok nå.
  Heggholmen skrev (På 30.3.2019 den 19.01):
... er du sikker på at det er riktig HomeID du bruker?
Er det fleire enn meg som er plaga av at Pulse sluttar å sende data ei kort stund like etter midnatt? Her skjer det nesten kvar natt, med det resultat at TibberSeer kræsjar og stort sett resten av HS stoppar opp. Har løyst dette med eit event som restartar HS, men det er jo ikkje ideelt å gjere det til stadigheit (innbiller eg meg).
  bjornepappa skrev (På 7.4.2019 den 16.19):
Du kan vel i det minste slippe unna med å restarte TibberSeer? Jon00 har script for det.
  GeneralVirus skrev (På 7.4.2019 den 16.22):
Flere som sliter med at "keep realtime alive" funksjonen ikke fungerer?
Nei...?
  Moskus skrev (På 7.4.2019 den 16.24):
Nei...?
Skjer rett som det er at TibberSeer slutter å få data fra Puls. (dagers mellomrom)  Men klarer ikke å reprodusere det. Skal skru på debuglogging å se om jeg kommer noen vei.
Endret av GeneralVirus
Jeg sier ikke at det ikke kan skje, det er bare vanskelig å reprodusere og dermed løse feilen. Vi har byggeplass her og en Aidon måler, og får testet det meste av strømbrudd, etc. Det aller meste går greit.
Jeg bygger bare rundt Tibbers eget .NET API, med litt "att åt" for å luke ut de vanligste feilene.
Jeg får sette meg ned å legge inn en haug med debugging, så er det mulig vi klarer å finne feilen.
Løser seg når jeg trykker restart listener, mulig bare lager ett event som kjører denne hver time eller noe sånn.
Ser jeg får oppdatering fra Puls inn i HS hvert 10 sekund. Mulig å legge inn mulighet til å endre det? Hadde klart meg fint med hvert 30 sek eller hvert minutt.
  GeneralVirus skrev (På 7.4.2019 den 16.57):
TibberSeer leser bare det som kommer til Tibber. Og Tibber leser bare det som kommer fra måleren din. Jeg får data hvert 2-3 sekund.
Det er lite som det er noe poeng i å gjøre i plugin'en, det må i så fall justeres på Tibber sin side.
Takk for tipset, det skal bli!
Ser på config-sida at det under Keep Realtime alive skal gå an å justere tidsintervall. Forsøker å stille dette ned, men ved oppdatering er det tilbake på 1 time. Har eg oversett ein lagreknapp?
Da skjedde dette hos meg i natt også. Jeg får høre med Tibber om det skjer noe hos dem rett over midnatt, det skal jo ikke være slik. I verste fall får jeg tenke ut en dirty fix...
  bjornepappa skrev (På 7.4.2019 den 18.55):
Det er kun for henting av data, har ingenting med Keep Realtime alive å gjøre. Og det er en kjent bug at nytt intervall ikke blir lagret (du kan endre ini-filen hvis du vil).
Ting tar tid, har fått Pulse i hus og prøver meg nå med Tibberseer.
Tibber tok og Tibber HomeID, må de inn i en spesiell rekkefølge?
La inn begge deler samtidig, da starter ikke plug-in igjen, men en rekke kule feilmeldinger:
WARNING: Failed getting InterfaceStatus from TibberSeer - the interface was not found in the list of active interfaces, the list may need to be refreshed.
apr-09 15.40.29         Error    Initializing plug-in(2): TibberSeer Instance::Objektreferanse er ikke satt til en objektforekomst.STACK: ved System.Runtime.Remoting.Messaging.LogicalCallContext.PropagateIncomingHeadersToCallContext(IMessage msg) ved System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) ved HomeSeerAPI.IPlugInAPI.InitIO(String port) ved Scheduler.clsHSPI.CheckInterfaces()
Oransje kommer etter restart av plug-in og den røde er i loggen.
@Moskus, gidder du hjelpe - igjen?
Takk.
  Moskus skrev (På 8.4.2019 den 6.53):
Var du i dialog med Tibber? For etter du skreiv dette trur eg ikkje feilen har oppstått hos oss, og før skjedde det stort sett kvar natt. ?
