revell2000 Skrevet 4. januar 2023 Del Skrevet 4. januar 2023 Hi I'm having some trouble. The plugin keeps crashing every few seconds. I tried reinstalling and I have tried a few different version. Weird thing is that I had been using the PI for weeks when I noticed in the log that it was crashing every now and then. So I updated and it seemed fine then. But now I find it crashing again. It seems to run fine before I add my device. I'm using a Sensibo Pure. I'll PM Guathdim the log. Many thanks if you take a look at it. Kind regards Revell Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Guahtdim Skrevet 12. januar 2023 Del Skrevet 12. januar 2023 @revell2000 I need a bit more info to be able to do further investigation. Check your PM. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
FredLap Skrevet 7. mars 2023 Del Skrevet 7. mars 2023 (endret) Hi, after updating to version 4.2.18.0, I'm having an issue with the SensiboClimate plugin. Any clue on how to resolve this ? Here's the warning in the logs : 3-07-2023 08:34:10 HomeSeer Info Plugin SensiboClimate has connected. IP:127.0.0.1:61094 3-07-2023 08:34:10 HomeSeer Warning I/O interface SensiboClimate is down, executable is not running, restarting ... 3-07-2023 08:33:40 HomeSeer Starting Plug-In Plugin SensiboClimate started successfully in 36 milliseconds 3-07-2023 08:33:40 Legacy-Plugin SensiboClimate Plugin still updating to next version. Please wait. 3-07-2023 08:33:40 HomeSeer Starting Plug-In Initializing plugin SensiboClimate ... 3-07-2023 08:33:40 HomeSeer Starting Plug-In SensiboClimate loaded in 15088 milliseconds 3-07-2023 08:33:25 HomeSeer Info Plugin SensiboClimate has connected. IP:127.0.0.1:61013 3-07-2023 08:33:25 HomeSeer Warning I/O interface SensiboClimate is down, executable is not running, restarting ... 3-07-2023 08:32:55 HomeSeer Starting Plug-In Plugin SensiboClimate started successfully in 36 milliseconds 3-07-2023 08:32:55 Legacy-Plugin SensiboClimate Plugin still updating to next version. Please wait. 3-07-2023 08:32:54 HomeSeer Starting Plug-In Initializing plugin SensiboClimate ... 3-07-2023 08:32:54 HomeSeer Starting Plug-In SensiboClimate loaded in 15080 milliseconds 3-07-2023 08:32:39 HomeSeer Info Plugin SensiboClimate has connected. IP:127.0.0.1:60992 Additional information when I try to launch the HSPI_SensiboClimate.exe Start 2023-03-07 08:58:41 of HSPI_SensiboClimate, version 2.0.1.0 SensiboClimate Connecting to HomeSeer at 127.0.0.1:10400 ... connection to HomeSeer successful. Exception non gérée : System.NullReferenceException: La référence d'objet n'est pas définie à une instance d'un objet. à HSPI_SensiboClimate.Plugin.Helpers.CommunicationHandler.GetAllDevices(Boolean overrideCaching) à HSPI_SensiboClimate.SensiboPlugin.StartDeviceUpdate() à System.Threading.ThreadHelper.ThreadStart_Context(Object state) à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) à System.Threading.ThreadHelper.ThreadStart() Thanks for your help! Endret 7. mars 2023 av FredLap Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
RickS Skrevet 25. april 2023 Del Skrevet 25. april 2023 Unfortunately I am having the same problem with the plugin constantly restarting. Homseer 4.2.18.5 on Windows 11 and plugin 2.0.1.0 4/25/2023 2:26:59 AM HomeSeer Info Plugin SensiboClimate with ID: and Instance: has disconnected 4/25/2023 2:26:48 AM HomeSeer Plug-In Finished initializing plug-in SensiboClimate 4/25/2023 2:26:48 AM HomeSeer Starting Plug-In SensiboClimate loaded in 212 milliseconds 4/25/2023 2:26:48 AM HomeSeer Starting Plug-In Plugin SensiboClimate started successfully in 15 milliseconds 4/25/2023 2:26:48 AM HomeSeer Starting Plug-In Initializing plugin SensiboClimate ... 4/25/2023 2:26:48 AM HomeSeer Info Plugin SensiboClimate has connected. IP:127.0.0.1:56105 4/25/2023 2:26:36 AM HomeSeer Info Plugin SensiboClimate with ID: and Instance: has disconnected 4/25/2023 2:26:22 AM HomeSeer Starting Plug-In Plugin SensiboClimate started successfully in 17 milliseconds 4/25/2023 2:26:22 AM HomeSeer Starting Plug-In Initializing plugin SensiboClimate ... 4/25/2023 2:26:22 AM HomeSeer Starting Plug-In SensiboClimate loaded in 15092 milliseconds 4/25/2023 2:26:07 AM HomeSeer Info Plugin SensiboClimate has connected. IP:127.0.0.1:56088 4/25/2023 2:26:07 AM HomeSeer Warning I/O interface SensiboClimate is down, executable is not running, restarting ... 4/25/2023 2:25:50 AM HomeSeer Info Plugin SensiboClimate with ID: and Instance: has disconnected 4/25/2023 2:25:37 AM HomeSeer Plug-In Finished initializing plug-in SensiboClimate 4/25/2023 2:25:37 AM HomeSeer Starting Plug-In SensiboClimate loaded in 320 milliseconds 4/25/2023 2:25:37 AM HomeSeer Starting Plug-In Plugin SensiboClimate started successfully in 15 milliseconds 4/25/2023 2:25:37 AM HomeSeer Starting Plug-In Initializing plugin SensiboClimate ... 4/25/2023 2:25:37 AM HomeSeer Info Plugin SensiboClimate has connected. IP:127.0.0.1:56067 And this from running the exe file in a command window: Unhandled Exception: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_SensiboClimate.Plugin.Helpers.HomeSeerDevices.UnitDeviceUpdater.GetSwingValue(String swingModeAsString) at HSPI_SensiboClimate.Plugin.Helpers.HomeSeerDevices.UnitDeviceUpdater.UpdateChangeSwingDevice(Int32 dvRef, SensiboDeviceInfo sensiboDeviceInfo) at HSPI_SensiboClimate.Plugin.Helpers.HomeSeerDevices.UnitDeviceUpdater.UpdateDeviceWithData(SensiboDeviceInfo sensiboDeviceInfo, Int32 dvRef, Boolean allDevices) at HSPI_SensiboClimate.Plugin.Helpers.HomeSeerDevices.UnitDeviceUpdater.UpdateSensiboUnitDevices(SensiboDeviceInfo sensiboInfo, LocalDeviceClass rootDevice, Boolean allDevices) at HSPI_SensiboClimate.Plugin.Helpers.HomeSeerDevices.UnitDeviceUpdater.UpdateDevice(SensiboDeviceInfo sensiboInfo, Boolean allDevices) at HSPI_SensiboClimate.Plugin.Helpers.DeviceHandler.UpdateControlPanel(List`1 sensiboUnits) at HSPI_SensiboClimate.SensiboPlugin.UpdateDevices() at HSPI_SensiboClimate.SensiboPlugin.<UpdateAirConStates>b__29_0() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() PS C:\Program Files (x86)\Homeseer HS4> Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
RickS Skrevet 25. april 2023 Del Skrevet 25. april 2023 I might have resolved this. Two of my mini-splits are standard commercial units. The third A/C is a floor style portable with a more limited set of commands. It does not have swing vanes but the plugin created a change swing device. When I added the mini-splits the plugin would not crash. When I added the portable A/C it started to crash. After I deleted the change swing device in HomeSeer for the portable A/C, the plugin no longer crashed. Thanks very much for making this avalable! -Rick 1 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Guahtdim Skrevet 25. april 2023 Del Skrevet 25. april 2023 Nice solution. Looking at the error message you did the correct fix. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
RickS Skrevet 25. april 2023 Del Skrevet 25. april 2023 33 minutes ago, Guahtdim said: Nice solution. Looking at the error message you did the correct fix. The plugin ran all night with no crashes. All is well. Thanks again for this nice plugin. -Rick Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Fjosepose Skrevet 6. november 2023 Del Skrevet 6. november 2023 Jeg søker tydeligvis ikke på riktige nøkkelord... Nå har jeg lasted ned zip-filen med siste Sensibo-plugin, men klarer ikke helt å finne ut hva som er neste skritt for å kunne installere denne på HS4? Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Guahtdim Skrevet 6. november 2023 Del Skrevet 6. november 2023 On 29/12/2018 at 23:41, Frankis78 said: Anbefaler Backup før man gjør oppdatering Først deaktiver Sensibo plugin i plugin manager. Slett evt Sensibo devicer i Homeseer Man kan deretter slette filer følgende før man innstallerer: I Homeseer Root mappen: Slett disse filene HSPI_SensiboPluginClimate.exe , HSPI_SensiboPluginClimate.exe.config , HSPI_SensiboPluginClimate.exe.pdb I Homeseer Bin mappen: Slett hele SensiboPluginClimate mappen I Homeseer Config folderen: Slett filen SensiboClimateConfig.xml Deretter Dra alle filene inn i Homeseer root folderen og start plugin i plugin manager. Har testet den på windows og linux, og alt fungerer bra. Pakk ut filen og gjør som over. Det lønner seg å ta kopi av hele HomeSeer folderen før du begynner å legge inn de nye filene. Jeg er usikker på om dette stemmer helt eksakt nå med tanke på filnavn etc, men mener det er bortimot likt. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Fjosepose Skrevet 6. november 2023 Del Skrevet 6. november 2023 (endret) 31 minutes ago, Guahtdim said: Pakk ut filen og gjør som over. Det lønner seg å ta kopi av hele HomeSeer folderen før du begynner å legge inn de nye filene. Jeg er usikker på om dette stemmer helt eksakt nå med tanke på filnavn etc, men mener det er bortimot likt. Dette er en førstegangs installasjon. Jeg har sett at man muligens trenger en fil som heter noe ala "updater override"... Å legge filene over i mappen ser ikke ut til å fungere. Endret 6. november 2023 av Fjosepose Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Guahtdim Skrevet 6. november 2023 Del Skrevet 6. november 2023 (endret) Jeg bruker ikke HS4 selv, men mener prosessen er lik for HS4 som for HS3. I windows mener jeg at det skal holde å pakke ut siste versjon ved å bare benytte samme struktur som det er i zip-filen. Pakk ut filen i din Homeseer katalog - pass på at du får følgende oppsett (katalogen "Homeseer HS4" skal inneholde 2 nye filer HSPI_SensiboClimate.exe og HSPI_SensiboClimate.exe.config, mens du i katalogen Homeseer HS4\bin og Homeseer HS4\html\images skal ha fått en ny underkatalog - SensiboClimate) Restart Homeseer Endret 6. november 2023 av Guahtdim Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Fjosepose Skrevet 6. november 2023 Del Skrevet 6. november 2023 (endret) 20 minutes ago, Guahtdim said: Pakk ut filen i din Homeseer katalog - pass på at du får følgende oppsett (katalogen "Homeseer HS4" skal inneholde 2 nye filer HSPI_SensiboClimate.exe og HSPI_SensiboClimate.exe.config, mens du i katalogen Homeseer HS4\bin og Homeseer HS4\html\images skal ha fått en ny underkatalog - SensiboClimate) Restart Homeseer Jeg har forsøkt dette i litt forskjellige varienter uten hell. Når jeg nøyaktig gjorde som i oppskriften over fikk jeg dette: Warning, Cannot load EXE file (possibly missing dependencies) HSPI_SensiboClimate.exe: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.Warning, Error details with EXE HSPI_SensiboClimate.exe: Could not load file or assembly 'Hspi, Version=1.4.177.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. Endret 6. november 2023 av Fjosepose Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Guahtdim Skrevet 6. november 2023 Del Skrevet 6. november 2023 Det kan være at du mangler en .Net Framework pakke eller de filene som ligger innunder bin-katalogen ikke er blitt plassert korrekt. Men det at du får en feilmelding er faktisk positivt siden HomeSeer prøver å laste inn plugin. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Fjosepose Skrevet 6. november 2023 Del Skrevet 6. november 2023 (endret) Ser ut til at det ha hatt noe med hvordan filene ble kopiert inn fra zip-filen, og dermed kanskje også fil-rettighetene, til de ulike lokasjonene, for nå virker det finfint. Litt videre spinn: Det jeg mangler er innstillinger for horizontalSwing...men dette kan jo muligens implementeres i et eget script om det er mulig å sende en PATCH-request fra scripting via events i Homeseer? Har ikke helt klart å finne noe der om metoden PATCH? Endret 6. november 2023 av Fjosepose Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Guahtdim Skrevet 7. november 2023 Del Skrevet 7. november 2023 Jeg kan desverre ikke hjelpe deg der. Jeg bruker ikke Sensibo selv, men bare hjalp eieren av plugin med å få den i havn. Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Fjosepose Skrevet 19. oktober Del Skrevet 19. oktober (endret) Hei. Der ser ut til å være litt "krøll" med oppdateringen av variabler fra Sensibo-server til Homeseer-plug-in. Om jeg endrer verdien med fjernkontroll eller Sensibo-app så oppdateres ikke verdiene i Homeseer-plug-in'en. Homeseer plug-in'en fungerer dog til sende ut kommandoer/verdier(og dette reflekteres i Sensibo-app). Jeg har snust litt på Homey-appen og der ser i change loggen at noe i API'et er endret: Endret 19. oktober av Fjosepose Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
Fjosepose Skrevet 20. oktober Del Skrevet 20. oktober Nå er Sensibo tydeligvis tilbake i god form...så kanskje bare en tilfeldig feil eller noe annet. 1 Siter Lenke til kommentar Del på andre sider Flere delingsvalg…
