Er det noen som har denne?
https://www.tado.com/gb/thermostat-heating
Det står at den skal fungere med varmekabler. Mitt spørsmål er da; passer den inn i en standard Elko-veggramme?
Har sett denne... passer ikke.  Mål: 174x174mm.  Fungerer med varmekabler forutsatt;
Electric underfloor heating systems can only be controlled by tado° if the following conditions are met:
1.    A wired thermostat is currently connected to the electrical underfloor heating.
2.    Smart Thermostats can only control systems up to 6 Amps (1380W). If you are unsure, please check this with an installer/electrician.
3.    Some electric underfloor systems require a floor sensor to make sure that the floor does not exceed a certain temperature. tado° is not able to connect to a floor temperature sensor and therefore we are not compatible with systems that have a floor sensor.
  • 11 måneder senere...
