Hva skjer nå? HS er HELT dø, ingen respons ifra HS.
Skulle legge inn Fibaro strips på ny, da den sluttet å fungere(kanskje ødelagt?). Får ikke lovt til å fjerne eller legge til Node`er. Og ingen respons ifra sensorer.
Det er to røde anmerkinger
jan-28 00.21.32   Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\images\HomeSeer\status\angle-position.png
jan-28 00.21.32   Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\images\HomeSeer\status\seismic.png
Hva menes med det?
Log`en
jan-28 00.22.43   Device Control Device: Hoved Etg Gang Switch to Off (0) by/from: CAPI Control Handler
jan-28 00.22.41   Device Control Device: Hoved Etg Gang Switch to On (255) by/from: CAPI Control Handler
jan-28 00.22.37   Device Control Device: Hoved Etg Gang Switch to On (255) by/from: CAPI Control Handler
jan-28 00.22.31   Device Control Device: Hoved Etg Gang Switch to Off (0) by/from: CAPI Control Handler
jan-28 00.22.28   Device Control Device: Hoved Etg Gang Switch to On (255) by/from: CAPI Control Handler
jan-28 00.21.56   TTS Speak ():Web server port number is 8088
jan-28 00.21.53   TTS Speak ():Welcome to Home-Seer
jan-28 00.21.52   Speaker Speaker host added, Name: DESKTOP-V3N8D7O Instance: Default IP address: 127.0.0.1
jan-28 00.21.30   Info System connected to MyHS Service successfully with license ID 126474.
jan-28 00.21.29   Info System connected to MyHS Service, waiting for acknowledge...
jan-28 00.21.29   Startup Start up complete.
jan-28 00.21.29   Startup HSSentry is disabled in Setup, sentry will not be started.
jan-28 00.21.29   Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
jan-28 00.21.29   Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
jan-28 00.21.29   Startup Starting Event Scheduler...
jan-28 00.21.29   Web Server Web Server authorized local login successful from: 192.168.120.2 User: Raymond
jan-28 00.21.29   Startup Running the startup script Startup.vb
jan-28 00.21.29   Startup Starting Find service...
jan-28 00.21.29   Startup Updater services starting...
jan-28 00.21.29   Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
jan-28 00.21.29   Speech Listening for remote speaker connections on port 10401
jan-28 00.21.29   Startup Initializing Speaker Client Interface
jan-28 00.21.29   Startup Start automation engine...
jan-28 00.21.28   Startup Creating ASP.NET application host...
jan-28 00.21.28   Web Server Web Server started on port 8088
jan-28 00.21.28   Web Server Local IP address (subnet) is: 192.168.120.115 (255.255.255.0)
jan-28 00.21.28   Startup HStouch server started, waiting for clients to connect.
jan-28 00.21.28   HSTouch Server Server started on port 10200
jan-28 00.21.28   Plug-In Finished initializing plug-in RFXCOM
jan-28 00.21.28   Plug-In Finished initializing plug-in MyQ
jan-28 00.21.28   Plug-In Interface MyQ is running as a trial, 29 days remaining.
jan-28 00.21.28   Plug-In Finished initializing plug-in JowiHue
jan-28 00.21.28   Plug-In Finished initializing plug-in HSZigBee
jan-28 00.21.28   Plug-In Finished initializing plug-in Z-Wave
jan-28 00.21.28   Startup Initializing Plug-Ins
jan-28 00.21.28   Plug-In Found plug-in: Z-Wave, version: 3.0.1.249
jan-28 00.21.28   Plug-In Found plug-in: HSZigBee, version: 3.0.1.7
jan-28 00.21.28   Plug-In Found plug-in: RFXCOM, version: 30.0.0.37
jan-28 00.21.28   Plug-In Found plug-in: MyQ, version: 1.2018.717.1011
jan-28 00.21.28   Plug-In Found plug-in: JowiHue, version: 2.0.2.8
jan-28 00.21.28   Startup Checking for available plug-ins
jan-28 00.21.28   Error Unable to start plug-in API: Only one usage of each socket address (protocol/network address/port) is normally permitted
jan-28 00.21.28   Startup This version of HomeSeer is registered as a HS3PRO version.
jan-28 00.21.28   HSPhone HomeSeer Phone Web Interface initializing.
jan-28 00.21.28   Startup Initializing phone interface...
jan-28 00.21.28   Startup Creating Speaker Client Interface Object...
jan-28 00.21.28   Startup HomeSeer version is: 3.0.0.435
jan-28 00.21.28   Load Config Loading TIMERS...
jan-28 00.21.28   Load Config Loading COUNTERS...
jan-28 00.21.28   Load Config 4 total events loaded.
jan-28 00.21.28   Load Config Loading Events...
jan-28 00.21.28   Load Config Loading Event Groups...
jan-28 00.21.28   Load Config 65 total devices loaded.
jan-28 00.21.28   Database Loading Devices...
jan-28 00.21.28   Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
jan-28 00.21.28   Startup Loading configuration file ...
jan-28 00.21.28   Startup Database SAVE process started.
jan-28 00.21.27   Startup Local voice recognition class started.
jan-28 00.21.27   Startup HSPhone external interface class started.
jan-28 00.21.27   Startup Plug-In Interface class started.
jan-28 00.21.27   Startup E-Mail RECEIVE class started.
jan-28 00.21.27   Startup E-Mail SEND class started.
jan-28 00.21.27   Startup Web server class started.
jan-28 00.21.27   Startup Application interface class started.
jan-28 00.21.27   Startup COM port classes started.
jan-28 00.21.27   Startup Creating Class Objects...
jan-28 00.21.27   System Ending plug-in process HSPI_ZWave
jan-28 00.21.27   Startup ********************************************************************************
jan-28 00.21.27   Startup HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
jan-28 00.21.27   Startup Settings Loaded.
Det er vel 1til feil
jan-28 00.21.28 ErrorUnable to start plug-in API: Only one usage of each socket address (protocol/network address/port) is normally permitted
Føler hele systemet er ute å kjøre. Ingen sensorer fungere. Buggy hele greia.
Når jeg trykker på PLUG-INS så kommer det bare opp "Manage", ikke resten av menyen.
Antar du har prøvd å starte pc på nytt?
Kan se ut som du har andre programmer oppe som bruker comport til zigbee-stick, z-wave stick eller rfxcom. Hvis ja, lukke dem å start hs på nytt.
Hvis ikke prøv å disable alle plugins, lukk HS. gå inn i settings.ini i HSRoot/config mappa. Fjern alt i linjen etter "io_interfaces=". Start opp HS på nytt, gå inn å enable plugins igjen under manage plugins.
Endret av GeneralVirus
Er usikker på hva som har gjort dette, men som skrevet over her skulle jeg legge inn en Strips sensor på ny.
Jeg har tidligere tatt den ned(ifra Futurhome testing), for å teste og legge inn på ny i HS. Og det har jeg fått til, lagt den til i HS og har fungert 100%, og events har fungert.
Legger på ny dobbeltsidig tape, og setter den opp fysisk på plass over døren. Så fungere den ikke. Da forsøker jeg å ta den vekk, og legge den inn på ny. Men får ikke ta vekk eller legge til noe som helst.
Og det mesta (les alt) er "buggy".
Nå har jeg sjekket at IP adressen er riktig og "låst" til PC/HS. Restartet HS og PC uten hell. Siden jeg fikk feilen:
Er usikker på om det gjelder feilen, men har nå gjort det og.
@GeneralVirus
Ja PC og HS er restartet.
Kommer ikke inn i plugin menyen, så får ikke restartet noe der.
Inn i HS mappa, så er det her du mene?
Kjørte en Polling, uten at jeg vet helt hva det er. Men får ihvertfall lite responser der og ser det ut som....
Det fungerte ikke.
Har og tatt ut RFXcom, og restaret igjen.
Og det fungere heller ikke.
Nå ser fila ut slik
[Settings]
gLastShutdownOK=False
gFirstTimeRun=False
gConfigFilename=HomeSeerData.hsd
gLocLabel=Room
gLocLabel2=Floor
bUseLocation2=True
bLocationFirst=False
gLongitude=-5.6409
gLatitude=59.0784
SADProc=True
gWebSvrPort=8088
gGlobalTempScaleF=False
gEmailUseGmail=True
[email protected]
gGmailPass=4853454E4332705A477765484732646A4547786E7367442F755851513D3D
io_interfaces=Z-Wave:,MyQ:
PluginDebug=False
gLogShortTime=True
gAllowBrowserImageCaching=False
LastDevRef=89
groupPhysical=True
gLastRunVersion=3.0.0.435
gHideDevices=False
gPhoneEnabled=True
[Display]
gSelectedGroupWeb=All Groups
Endret av mr.rs4
Forstår egenligt lite av dette. Eneste forskjellen var ifra i fungerende system, til et system som ikke fungere var at jeg satt på dobbelsidig tape på Fibaro Strips, og satt den på ytterdøra.
Jeg testet sytemet før, pga jeg satt opp alle sensorer som var lagt inn i HS.
Og Fibaro strips var igjen, var bare få tape på og satt på døra = HS krasj.....
17 minutes ago, GeneralVirus said:
Du skrudde av HS før du endret fila? Du har enda 2 plugins enabled der. Z-Wave og MyQ
Ja. Skal prøve igjen
EDIT
Prøvde igjen. Disablet alle plugin`s.
Og config fila ble til
[Settings]
gFirstTimeRun=False
gLocLabel=Room
gLocLabel2=Floor
bUseLocation2=True
gLongitude=-5.6409
gLatitude=59.0784
SADProc=True
gWebSvrPort=8088
gEmailUseGmail=True
[email protected]
PluginDebug=False
gLogShortTime=True
LastDevRef=89
groupPhysical=True
gHideDevices=False
gPhoneEnabled=True
[Display]
Endret av mr.rs4
Kan du legge ut et bilde av settings->Network?
Har du bundet HS til en spesifikk IP?
Kommer du inn på HS fra mobil/annen PC eller bare den du kjører HS på?
Har du sjekket i oppgavebehandling at HS ikke er startet flere ganger?
Oppdaget denne tråden din nå:
Er du sikker på at HomeSeer rakk å avslutte skikkelig før hver omstart? Hvis ikke kan det være en korrupt database... I så fall kan du prøve å gjenopprette den nyeste fra \Data-katalogen (tror jeg det er). Skal ligge 10 filer der. Stopp HS, flytt ut den som ikke har noe tall bak seg til Skrivebordet, kopier den med nyest dato og gi den samme navn som den originale. Start så HS.
Hvis du ikke kommer inn i Plugins -> Manage er det et tegn på at en plugin har hengt seg opp. Du kan stenge dem manuelt ved å åpne TaskManager -> Details -> Sortere på navn og sjekke om noen prosesser som begynner på "HSPI_" kjører. Se om noen av dem bruker mye CPU.
Du kan nok være ganske sikker på at det ikke er årsaken... ;)
Her er kjørende programer, selv om en IKKE kjøre Homeseer
Usikker på hva du mener her, men er det bare bilde av
Nettverket fungere helt fint, og har satt fast IP adresse til PCen
Det gikk en stund ifra jeg fikk til Somfy og RFXcom til jeg fikk problemet. Etter jeg fikk til Somfy/RFXcom, ble det en liten pause. Så begynte jeg å sette opp de sensorene som allerede var lagt til.
Tok med meg en laptop(logget med inn på IP adressen & port nr) og sjekket hver og en  av dør sensorene. Da kunne jeg se bevegelse og hvor jeg kunne sette magneten iforhold til hverandre(åpen & steng posisjon). Alt OK.
Så var det siste Fibaro Strip sensor, den fungerte plutselig ikke. Prøvde å ta vekk og legge til prosedyre, men fikk ikke det til.
Gikk på NUC pc der HS er innstallert, og ser at alt er buggy. Kommer ikke inn på diverse plasser i program osv.
Restarte program og PC.
Så begynte jeg å spøre dere om råd, resten av historien er lagt til over her.
Kan jo ta alt på ny, men jeg liker å finne problemet så det ikke skjer igjen, evt vet hvordan fikse opp i det.
For nå er det ikke så mange sensorer / events, blir nok flere etterhvert, og da er det MER kjedelig når slik skjer.
Endret av mr.rs4
Spoiler
Etter restart og starter PC på ny, og starter HS på så ligger HSPI_ZWave (32bit) ifra 30 til 35% CPU og "jobber". Minne ligger på 13,2MB.
På PCen ellers så ligger CPU % på de andre kjørende programer på 0 til 4%
HomeSeer speaker client er ikke krise. Men du kan kverke HSPI_Zwave.exe.
1 minutt siden, mr.rs4 skrev:
Om Homeseer har kjørt og ikke blitt "ferdig", hvordan ser man det?
Du ser om "HS3.exe" kjører. Det er lettest å sjekke hvis du velger fanen "Details" i Task Manager.
Hvis Z-wave plugin'en kjører så mye (det skal den ikke gjøre) så har det skjedd noe som ikke burde skje. Det første spørsmålet er: Har du gitt plugin'en litt tid til å jobbe seg ferdig?
