20 minutes ago, toby_77 said:
Den har alt dette - dvs neste identisk:
Description.Replace(vbCrLf, "<br/>")
Dette funker fint hos meg. Kan være noe med bruk av "newLine" - kan prøve å endre til annen syntaks og se om det fungerer bedre på tvers av systemer
Husk at linjeskift i windows og unix er to forskjellige ting (Windows=CR/LF. Unix=LF)
Siden du hardkoder til CR/LF så fungerer det ikke i Unix. System.Environment.NewLine er ett bedre valg siden den har forskjellig betydning avhengig av OS.
https://www.jaypm.com/the-difference-between-vbcrlf-vbnewline-and-environment-newline/
5 minutes ago, Bostad said:
Plugin virker ikkje i HS4:
MyZWaveParameters Instance::Error: Only HS3 is Supported by this version
Det stemmer
  • 1 år senere...
Hi Toby,
I posted all the XML files I could find onto the git site, along with a few I have created.
I was wondering if you were still interested in developing the plugin as one great addition would be the ability to control each of a 4 byte parameter under hexcheck independently as v 3.20.0.9 seems to limit it to just 2 sub types.
There does also seem to be a problem with the binarycheck - which I recently posted about in your homeseer forum page.
I am not much of a developer but would be happy to help if I'm able.
Cheers
Andy
