Preference Skrevet 12. april 2019 Skrevet 12. april 2019 ConBee 2 eller ConBee II er nå lansert: http://phoscon.de/de/conbee2 Spent på pris i Norge! Siter
ZoRaC Skrevet 12. april 2019 Skrevet 12. april 2019 Kommer til å koste ca det samme, regner jeg med: https://forums.homeseer.com/forum/lighting-primary-technology-plug-ins/lighting-primary-technology-discussion/jowihue-w-vuyk/1298146-conbee-vs-conbee-ii Sitat price tag stays roughly the same Ekspander 1 Siter
ZoRaC Skrevet 13. april 2019 Skrevet 13. april 2019 ZoRaC skrev (På 12.4.2019 den 20.19): https://forums.homeseer.com/forum/lighting-primary-technology-plug-ins/lighting-primary-technology-discussion/jowihue-w-vuyk/1298146-conbee-vs-conbee-ii Ekspander Sitat What’s new? (not that much) smaller and has a fresh look J New micro-controller 32-bit ARM-Cortex-M0 instead of the 8-bit AVR based SoC used by ConBee/RaspBee The serial protocol is 100% backward- compatible, so projects like Mozilla IoT and zigpy-deconz should just work without modifications Firmware updates become ~ twice as fast New bootloader and GCFFlasher which only use serial protocol and doesn’t need root access anymore (improved updates in Docker container) Same as ConBee/RaspBee it has a power-amplifier for 30m indoor and up to 200m outdoor signal range (compared to the other popular CC2531 USB Stick without PA which provides ~ 5-8 m indoor range) Always-on Watchdog greater worldwide availability (like certification for Canada, Australia / New Zealand) price tag stays roughly the same Ekspander 2 Siter
hakons Skrevet 13. april 2019 Skrevet 13. april 2019 Var i kontakt med Kjell og Co tidligere i uka om å oppdrive Conbee 1, dette kunne de ikke - men informerte om at Conbee II kom til å være tilgjengelig i butikken innen 1-2 uker. 1 Siter
aleks Skrevet 13. april 2019 Skrevet 13. april 2019 Da har jeg bestilt meg en Utenom et par småting i starten har conbee oppført seg svært bra. Siter
ZoRaC Skrevet 13. april 2019 Skrevet 13. april 2019 aleks skrev (På 13.4.2019 den 19.55): Da har jeg bestilt meg en Utenom et par småting i starten har conbee oppført seg svært bra. Ekspander Hvorfor skal du ha en til? Siter
aleks Skrevet 13. april 2019 Skrevet 13. april 2019 ZoRaC skrev (På 13.4.2019 den 19.56): Hvorfor skal du ha en til? Ekspander Fordi jeg vil ha noe nytt. Hvem vil ikke ha "v2"? ? Siter
ZoRaC Skrevet 13. april 2019 Skrevet 13. april 2019 aleks skrev (På 13.4.2019 den 19.57): Fordi jeg vil ha noe nytt. Hvem vil ikke ha "v2"? ? Ekspander Høres bare ut som fryktelig mye jobb med overføring av devicer fra en ConBee til en annen...uten å få noe igjen for innsatsen... Siter
aleks Skrevet 13. april 2019 Skrevet 13. april 2019 ZoRaC skrev (På 13.4.2019 den 20.44): Høres bare ut som fryktelig mye jobb med overføring av devicer fra en ConBee til en annen...uten å få noe igjen for innsatsen... Ekspander Backup ca 5 sekunder, restore ca 5 sekunder? Siter
ZoRaC Skrevet 13. april 2019 Skrevet 13. april 2019 aleks skrev (På 13.4.2019 den 20.45): Backup ca 5 sekunder, restore ca 5 sekunder? Ekspander Siste jeg så på GitHub er at restore ikke funker, men mulig de har fikset det? Sikker på at restore i hele tatt er mulig fra I til II? Siter
aleks Skrevet 13. april 2019 Skrevet 13. april 2019 ZoRaC skrev (På 13.4.2019 den 20.53): Siste jeg så på GitHub er at restore ikke funker, men mulig de har fikset det? Sikker på at restore i hele tatt er mulig fra I til II? Ekspander Aldri hatt problem med å restore jeg? Tenker meg siden det er full bakoverkopibalitet så går det seg nok til. Tror det er mulig å sette begge inn i samme nettverk også Siter
ZoRaC Skrevet 14. april 2019 Skrevet 14. april 2019 aleks skrev (På 13.4.2019 den 20.54): Aldri hatt problem med å restore jeg? Tenker meg siden det er full bakoverkopibalitet så går det seg nok til. Tror det er mulig å sette begge inn i samme nettverk også Ekspander Mulig det funker nå da, selv om issue fortsatt er åpent: https://github.com/dresden-elektronik/deconz-rest-plugin/issues/371 Siter
ZoRaC Skrevet 14. april 2019 Skrevet 14. april 2019 Enkelte ting som har virket problemfritt på I virker ikke nødvendigvis på II med en gang... det er forskjellig firmware på dem, så firmware-problemer må fikses «hver for seg». https://github.com/dresden-elektronik/deconz-rest-plugin/issues/1074#issuecomment-482939425 Siter
aleks Skrevet 14. april 2019 Skrevet 14. april 2019 Enda moro å prøve. Kjøpte den fra Dresden så kostet ikke mange kronene Siter
hakons Skrevet 14. april 2019 Skrevet 14. april 2019 (endret) aleks skrev (På 14.4.2019 den 10.52): Enda moro å prøve. Kjøpte den fra Dresden så kostet ikke mange kronene Ekspander Har du noe erfaring hvordan det blir med mva/toll å bestille rett fra Dresden? Summen går vel over 300,- grensa. Svarer meg selv her. Hvis de følger boka og legger inn rette verdier så blir det Resultat (i norske kroner) Sum før fortolling 491,64 Toll (0 %) 0,00 Merverdiavgift (25 %) 122,91 Sum etter fortolling 614,55 I tillegg må du betale et gebyr til firmaet som fortoller varen for deg. For eksempel tar Posten 158 kroner for å fortolle denne typen sendinger. Dette gir en totalpris på 772,55 kroner. Kilde: Importkalkulator med 51 EUR som er totalt inkl shipping to Norge. Endret 14. april 2019 av Kropling 1 Siter
aleks Skrevet 14. april 2019 Skrevet 14. april 2019 Kommer litt ann på hvordan de sender den og hva de deklarerer. Er litt oddspill om de går under fortolling Siter
Hr Kotelett Skrevet 14. april 2019 Skrevet 14. april 2019 Intin med hjemmeautomasjonsrabatten har vel den billigste conbee'en, om den nye og koster 600 får vi den for 510. Godt jeg ikke bestilte før jeg dro på påskeferie og kan vente til v2 kommer. Siter
aleks Skrevet 14. april 2019 Skrevet 14. april 2019 Jeg legger ut info her når jeg får den. Den var på lager så burde ha den om ikke så lenge Siter
Christian Skrevet 15. april 2019 Skrevet 15. april 2019 Det er vel mulig å ha to, en conbee og en zigbee, sånn at man får bedre dekning eller ?Sent from my iPhone using Tapatalk Siter
ZoRaC Skrevet 15. april 2019 Skrevet 15. april 2019 Christian skrev (På 15.4.2019 den 4.11): Det er vel mulig å ha to, en conbee og en zigbee, sånn at man får bedre dekning eller ? Sent from my iPhone using Tapatalk Ekspander Ja, men da må vel den ene bare fungere som router og da kan du like godt kjøpe en IKEA-pære. tror ikke man kan ha to coordinators i samme ZigBee-nett (men jeg er ikke sikker). Siter
Christian Skrevet 15. april 2019 Skrevet 15. april 2019 conbee og rapsbee mente jeg. En annen ting, er det mulig å bruke raspbee + poe hat på pi 3b+ ? Siter
ZoRaC Skrevet 15. april 2019 Skrevet 15. april 2019 Christian skrev (På 15.4.2019 den 9.37): conbee og rapsbee mente jeg. Ekspander Det var det jeg leste og svarte på. ? Siter
ZoRaC Skrevet 18. april 2019 Skrevet 18. april 2019 Her er anbefalt metode for migrering fra I til II: https://github.com/dresden-elektronik/deconz-rest-plugin/issues/1441#issuecomment-484380610 Siter
aleks Skrevet 24. april 2019 Skrevet 24. april 2019 Da har jeg fått den. Absolutt visuelt mye bedre og passer nok bedre på en PI med en usb over enn den gamle. Får håpe det er noe mer med denne i forhold til den gamle. 1 Siter
