Steve0 Skrevet 22. desember 2021 Skrevet 22. desember 2021 6 hours ago, AndersRS said: Kom du helt i mål? Gjorde det! Har nå kjørt stabilt med Aidon måler i Home Assistant (zwave2mqtt) i over et halvt år. Så kult at jeg fanget interessen Er bortreist til 7. januar, men kan se om jeg har noe deler / pcb’er til deg etter at jeg er tilbake? Send gjerne pm om det er av interesse. Siter
Gunnar-K Skrevet 13. november 2022 Skrevet 13. november 2022 spenceme skrev (På 28.10.2019 den 22.07): I've forked the gskjold repository and updated the best I could tonight with the latest design and some of my thoughts. @nicbra, this would be the best place to follow for the latest. Although all the design details are there, I suggest to wait a little before building much to give us a chance to debug on other meters. https://github.com/dakarym/AmsToMqttBridge @ArnieO, I updated the sketch on my repository with the sketch I am running today for the changes needed. I'm not sure if the gskjold fork runs the other Kamstrup and Kafia meters 100%, but it runs the Aidon I have perfectly. Hopefully it is okay. Hi! Would the powersupply work with ESP32 also? Siter
ArnieO Skrevet 14. november 2022 Forfatter Skrevet 14. november 2022 Gunnar-K skrev (13 timer siden): Hi! Would the powersupply work with ESP32 also? It works with ESP32-S2 (single core version of ESP32), which is used now in Pow-U. The ESP32-S2 hase a "base consumption" that is higher than ESP8266, but the firmware exploits power saving modes in the ESP. I do not think it will not work with a "traditional" dual core ESP32, and it will not work via a HAN-NVE module on a Kamstrup Omnipower meter. For Kamstrup meters it is better to exploit the "internal" power supply - which is what is done on Pow-K+. Siter
Gunnar-K Skrevet 14. november 2022 Skrevet 14. november 2022 Thanks😀 Could build another 8266 based interface, but would like to get the energy prices from Entsoe-e. Siter
ArnieO Skrevet 14. november 2022 Forfatter Skrevet 14. november 2022 Gunnar-K skrev (23 minutter siden): Thanks😀 Could build another 8266 based interface, but would like to get the energy prices from Entsoe-e. Reading prices from Entso-E is why we converted to ESP32; we could not squeeze that into AmsToMqttBridge for the 8266 (the API is too heavy). Siter
stigvi Skrevet 14. november 2022 Skrevet 14. november 2022 https://github.com/JaccoR/hass-entso-e 1 Siter
Gunnar-K Skrevet 21. november 2022 Skrevet 21. november 2022 stigvi skrev (På 14.11.2022 den 16.31): https://github.com/JaccoR/hass-entso-e Works fine 🙂 Siter
Gunnar-K Skrevet 8. desember 2022 Skrevet 8. desember 2022 spenceme skrev (På 21.2.2021 den 10.49): I have all the parts and can build one for you. Haven't looked at this much for the last year since mine has been running perfectly since 2019. I'll send you a message. Hi! I would like to try to build this HAN-reader. Is there a BOM available? Couldn`t find it in the Github repository.. If not I can make one from the schematics I guess. Siter
Alpøy Skrevet 11. desember 2022 Skrevet 11. desember 2022 @ArnieOHei, er det noen spesielt som må gjøres for at AmsToMqttBridge skal publishe "prices" som står nevnt i message format i Wikien? Kjører på en ESP32 og har forsøkt både 2.1.15 og nå 2.2 (beta) Siter
tronde Skrevet 11. desember 2022 Skrevet 11. desember 2022 Alpøy skrev (3 timer siden): @ArnieOHei, er det noen spesielt som må gjøres for at AmsToMqttBridge skal publishe "prices" som står nevnt i message format i Wikien? Kjører på en ESP32 og har forsøkt både 2.1.15 og nå 2.2 (beta) Har du aktivert ENTSO-E så du ser priser i web-grensesnittet? Jeg får i alle fall ut priser som MQTT-RAW med ESP32. Siter
Alpøy Skrevet 11. desember 2022 Skrevet 11. desember 2022 (endret) tronde skrev (2 timer siden): Har du aktivert ENTSO-E så du ser priser i web-grensesnittet? Jeg får i alle fall ut priser som MQTT-RAW med ESP32. Jepp får priser i web gui'et men ikke i MQTT (så langt jeg kan se hvert fall) 🤔 Edit: Tok full reinstall og får det nå til å virke, mulig jeg bare har gått glipp av publishen...hvor ofte publishes "price" ? Endret 11. desember 2022 av Alpøy Siter
ArnieO Skrevet 11. desember 2022 Forfatter Skrevet 11. desember 2022 Alpøy skrev (1 time siden): mulig jeg bare har gått glipp av publishen...hvor ofte publishes "price" ? Jeg mener de kun publiseres i forbindelse med at de hentes fra Entso-E, som skjer et sted mellom klokka 13 og 14 hver dag (randomisert tidspunkt for å unngå at alle som bruker firmwaren spør APIet eksakt samtidig). 1 Siter
tronde Skrevet 11. desember 2022 Skrevet 11. desember 2022 (endret) Pris på MQTT går vel ut av interfacet hver time når det oppdaterer grafikken i webgrensesnittet. Interfacet må selvfølgelig ha hentet det inn først. I nettleser kan du også se en del med "ip-adressen til interfacet"/data.json og "ip-adressen til interfacet"/energyprice.json Den siste gir alle fremtidige priser pluss nåværende. Funker vel best i Firefox som formaterer json automatisk. Endret 11. desember 2022 av tronde 1 Siter
gskjold Skrevet 12. desember 2022 Skrevet 12. desember 2022 Prisene hentes fra ENTSO-E mellom 13 og 14 som @ArnieO nevner, og publiseres deretter på MQTT hver hele time. 2 Siter
Gunnar-K Skrevet 8. januar 2023 Skrevet 8. januar 2023 Jeg bruker fortsatt det gamle interfacet, som får tilført 5V. Har prøvd å få til noe mere beregning av priser, strømstøtte, Apexcharts card osv. Får antakelig koblet til solceller i morra, og det kunne jo være opplysende å regne ut hvor mye disse kaster av seg.. For et par dager siden la jeg merke til at "Accumulated active import" ikke oppdateres konsekvent hver time. Så forbruk pr time blir ikke riktig. Kanskje flere har merket dette, eller er det noe feil hos meg? Siter
Gunnar-K Skrevet 15. januar 2023 Skrevet 15. januar 2023 Ruteren min tok kvelden, det er nok ustabilt nett som er årsaken, virker igjen nå med ny ruter. 1 Siter
