Noen som har noen gode råd?
Jeg sliter med Verisure, Somfy og Mill som tillegg. Det står sjekk config, og den har jeg sjekket mange ganger uten å finne noe feil.
Det virket med en gang jeg låg det inn, men så har det plutselig sluttet å virke.
Ett lite utdrag fra en veldig lang log:
Spoiler
019-04-28 20:02:53 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform netatmo Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=hass.loop) File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for return fut.result() File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/sensor.py", line 76, in setup_platform auto_config(auth, config, dev) File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/sensor.py", line 120, in auto_config for module_name in data.get_module_names(): File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/sensor.py", line 380, in get_module_names self.update() File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/sensor.py", line 411, in update raise Exception("No Weather nor HomeCoach devices found") Exception: No Weather nor HomeCoach devices found 2019-04-28 20:02:53 ERROR (SyncWorker_1) [smart_home] Traceback (most recent call last): File "/usr/local/lib/python3.7/urllib/request.py", line 1317, in do_open encode_chunked=req.has_header('Transfer-encoding')) File "/usr/local/lib/python3.7/http/client.py", line 1229, in request self._send_request(method, url, body, headers, encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1275, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1224, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1016, in _send_output self.send(msg) File "/usr/local/lib/python3.7/http/client.py", line 956, in send self.connect() File "/usr/local/lib/python3.7/http/client.py", line 1384, in connect super().connect() File "/usr/local/lib/python3.7/http/client.py", line 928, in connect (self.host,self.port), self.timeout, self.source_address) File "/usr/local/lib/python3.7/socket.py", line 707, in create_connection for res in getaddrinfo(host, port, 0, SOCK_STREAM): File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo for res in _socket.getaddrinfo(host, port, family, type, proto, flags): socket.gaierror: [Errno -3] Try again
Jeg hadde på en måte greid å legge inn både homeassistant og hassio på Docker (kjører Ubuntu). Jeg tror problemene oppstod når jeg fjernet homeassistant.
  Skjul innhold
Siden du har hatt to instanser inne på samme boks: er du sikker på at du jobber i riktig konfig?
tja... Jeg bruker den configuratoren som ligger i hassio. Og gjør jeg endringer der så synes det på dashbordet mitt.
Somfy (tahoma) og Mill hadde jeg ikke lagt inn på den andre config`en.
Det jeg lurer på, er om enten ikke hassio har kontakt med omverden ut av docker, eller om det ligger noen forflytninger av ip eller port i docker som jeg ikke ser.
Har lagt inn portainer og sånn ser network ut der:
Er helt grønn på docker...
Litt mer fra loggen rett etter en restart:
Spoiler
http://ubuntuserver:8123/frontend_es5/app.0d431883.js:2:79851 Uncaught TypeError: Cannot convert undefined or null to object
9:40 AM components/system_log/__init__.py (ERROR)
Error doing job: Task exception was never retrieved
9:35 AM /usr/local/lib/python3.7/site-packages/homeassistant/core.py (ERROR)
Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:None [Try again]
9:35 AM __main__.py (WARNING)
Error when getting home data.
9:34 AM components/netatmo/climate.py (ERROR)
Traceback (most recent call last): File "/usr/local/lib/python3.7/urllib/request.py", line 1317, in do_open encode_chunked=req.has_header('Transfer-encoding')) File "/usr/local/lib/python3.7/http/client.py", line 1229, in request self._send_request(method, url, body, headers, encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1275, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1224, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1016, in _send_output self.send(msg) File "/usr/local/lib/python3.7/http/client.py", line 956, in send self.connect() File "/usr/local/lib/python3.7/http/client.py", line 1384, in connect super().connect() File "/usr/local/lib/python3.7/http/client.py", line 928, in connect (self.host,self.port), self.timeout, self.source_address) File "/usr/local/lib/python3.7/socket.py", line 707, in create_connection for res in getaddrinfo(host, port, 0, SOCK_STREAM): File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo for res in _socket.getaddrinfo(host, port, family, type, proto, flags): socket.gaierror: [Errno -3] Try again During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/smart_home/__init__.py", line 39, in postRequest if params File "/usr/local/lib/python3.7/urllib/request.py", line 222, in urlopen return opener.open(url, data, timeout) File "/usr/local/lib/python3.7/urllib/request.py", line 525, in open response = self._open(req, data) File "/usr/local/lib/python3.7/urllib/request.py", line 543, in _open '_open', req) File "/usr/local/lib/python3.7/urllib/request.py", line 503, in _call_chain result = func(*args) File "/usr/local/lib/python3.7/urllib/request.py", line 1360, in https_open context=self._context, check_hostname=self._check_hostname) File "/usr/local/lib/python3.7/urllib/request.py", line 1319, in do_open raise URLError(err) urllib.error.URLError: <urlopen error [Errno -3] Try again>
9:34 AM components/netatmo/sensor.py (ERROR) - message first occured at 9:34 AM and shows up 2 times
Setup of platform netatmo is taking over 10 seconds.
9:34 AM __main__.py (WARNING)
Failed to connect to Mill
9:34 AM components/mill/climate.py (ERROR)
Error connecting to Mill
9:34 AM /usr/local/lib/python3.7/site-packages/mill/__init__.py (ERROR)
Setup of platform mill is taking over 10 seconds.
Setup failed for tahoma: Component failed to initialize.
9:34 AM setup.py (ERROR)
Setup failed for verisure: Component failed to initialize.
Error when trying to log in to the Tahoma API
9:34 AM components/tahoma/__init__.py (ERROR)
Could not log in to verisure, HTTPSConnectionPool(host='e-api01.verisure.com', port=443): Max retries exceeded with url: /xbn/2/cookie (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fd93ff52748>: Failed to establish a new connection: [Errno -3] Try again'))
9:34 AM components/verisure/__init__.py (ERROR)
Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
9:34 AM components/device_tracker/__init__.py (ERROR)
