Rogerbl Skrevet 1. juni 2019 Skrevet 1. juni 2019 (endret) ok, da er det en ny feil. Prøv å fjerne plugin'en helt for så å legge den inn på nytt. Prøv også å restart HomeSeer eller hele Linux. Her på min linux ser jeg ikke slike feil og da er det vanskelig å hjelpe deg. Endret 1. juni 2019 av Rogerbl Siter
cp1983 Skrevet 1. juni 2019 Skrevet 1. juni 2019 Slettet config filer og exe filen. Restartet linux boksen. Slette alle enheter i homeseer som hører til plugin. La inn plugin på ny. Krasjer fortsatt. Kjører ubuntu server og ikke debian men ville ikke tro det har noe å si. Jun-01 11:55:10 Info Plugin ECOFan with instance: has disconnected Jun-01 11:54:54 Starting Plug-In Plugin ECOFan started successfully in 137 milliseconds Jun-01 11:54:54 Starting Plug-In Initializing plugin ECOFan ... Jun-01 11:54:54 Starting Plug-In ECOFan loaded in 15013 milliseconds Jun-01 11:54:39 Info Plugin ECOFan has connected. IP:127.0.0.1:45190 Jun-01 11:54:39 Warning I/O interface ECOFan is down, executable is not running, restarting ... Jun-01 11:54:11 Info Plugin ECOFan with instance: has disconnected Jun-01 11:53:38 Starting Plug-In Plugin ECOFan started successfully in 83 milliseconds Jun-01 11:53:38 Starting Plug-In Initializing plugin ECOFan ... Jun-01 11:53:38 Starting Plug-In ECOFan loaded in 15047 milliseconds Jun-01 11:53:23 Info Plugin ECOFan has connected. IP:127.0.0.1:45152 Jun-01 11:53:23 Warning I/O interface ECOFan is down, executable is not running, restarting ... Jun-01 11:53:12 Info Plugin ECOFan with instance: has disconnected Jun-01 11:52:23 Plug-In Finished initializing plug-in ECOFan Jun-01 11:52:23 Starting Plug-In ECOFan loaded in 862 milliseconds Jun-01 11:52:23 Starting Plug-In Plugin ECOFan started successfully in 205 milliseconds Jun-01 11:52:22 Starting Plug-In Initializing plugin ECOFan ... Jun-01 11:52:22 Info Plugin ECOFan has connected. IP:127.0.0.1:45094 Jun-01 11:52:22 Plug-In Interface ECOFan is running as a trial, 22 days remaining. Siter
cp1983 Skrevet 1. juni 2019 Skrevet 1. juni 2019 Prøvde på ett gammelt vanlig Ubuntu VM med HomeSeer, akuratt samme der også. Siter
Rogerbl Skrevet 1. juni 2019 Skrevet 1. juni 2019 cp1983 skrev (På 1.6.2019 den 10.11): Prøvde på ett gammelt vanlig Ubuntu VM med HomeSeer, akuratt samme der også. Ekspander Skal prøve å se på den trial koden. Min Pro versjon går så det suser her. Siter
Rogerbl Skrevet 3. juni 2019 Skrevet 3. juni 2019 Kanskje plugin'en ikke er så kompatibel med dine vifter, ihvertfall ikke på Linux ser det ut til.. Et alternativ til denne kan være mqtt progammene jeg har utviklet for styring og kontroll av de samme enhetene. Siter
ZoRaC Skrevet 24. juli 2019 Skrevet 24. juli 2019 Rogerbl skrev (På 22.3.2018 den 13.35): Jeg benytter beskrivelsen i pdf dokumentet og putter inn HEX verdiene og ipadressene til viftene inn i den plugin'en som Zorac tipset om. Ekspander Er det dette dokumentet som beskriver UDP-dokumentasjonen til Twinfresh RW1-50 også? https://blaubergventilatoren.de/uploads/download/ventoexpertduowsmarthousev11en.pdf Siter
mk1 black limited Skrevet 24. juli 2019 Skrevet 24. juli 2019 Rogerbl skrev (På 22.3.2018 den 13.35): Har også satt opp en Raspberry Pi med "Fart" sensor som gir signal om det er vond lukt på WC, og som deretter sørger for at man kan kjøre vifta. Ekspander Den sensoren høres artig ut, mener jeg har lest om den et sted, men finner det ikke igjen. Har du oppskriften liggende? Siter
Rogerbl Skrevet 26. juli 2019 Skrevet 26. juli 2019 mk1 black limited skrev (På 24.7.2019 den 19.13): Den sensoren høres artig ut, mener jeg har lest om den et sted, men finner det ikke igjen. Har du oppskriften liggende? Ekspander Den ligger her:https://projects.raspberrypi.org/en/projects/fart-detector ? Funker greit på WC der den starter vifta fra tid til annen. Siter
ZoRaC Skrevet 26. juli 2019 Skrevet 26. juli 2019 Så du spørsmålet mitt, @Rogerbl? ZoRaC skrev (På 24.7.2019 den 8.51): Er det dette dokumentet som beskriver UDP-dokumentasjonen til Twinfresh RW1-50 også? https://blaubergventilatoren.de/uploads/download/ventoexpertduowsmarthousev11en.pdf Ekspander 1 Siter
Rogerbl Skrevet 26. juli 2019 Skrevet 26. juli 2019 ZoRaC skrev (På 26.7.2019 den 19.31): Så du spørsmålet mitt, @Rogerbl? Ekspander ja , det stemmer Zorac. 1 Siter
Rogerbl Skrevet 25. februar 2020 Skrevet 25. februar 2020 Har nå ferdig Mqtt programvare for å styre v.2 Vento Expert wifi modellene fra Blauberg! Kompatibel med Vents Twinfresh og Flexit v.2 enhetene. Der er også en ny versjon av programvare for v.1 modellene som samspiller med v.2 slik at de "smelter sammen" som ett system. Les mer på min nettbutikk: https://blomkvistitk.no/produkt/styring-og-monitorerings-programvare-for-blauberg-vento-expert-wifi-v-2-enheter/ Det planlegges en egen dedikert Homeseer plugin for v.2 modellene i løpet av året. Siter
Mathias Skrevet 17. mars 2020 Skrevet 17. mars 2020 (endret) For de av dere med Home Assistant så finnes det en custom component laget av @aglehmann på Github som fungerer greit. Det vil si; man kan slå av og på viften fra HA, og det er dønn stabilt, men viftehastighet og modus fungerer ikke. Uansett så bruker jeg denne i HA for å kunne automatisere når vifter går. Jeg har en Flexit Roomie dual wifi. Man finner den her: https://github.com/aglehmann Han har også laget et python-script for samme vifte. Det har jeg ikke testet. EDIT: I siste versjon fungerer endring av viftehastighet også. Endret 25. mars 2020 av Mathias 1 Siter
nilst Skrevet 3. oktober 2020 Skrevet 3. oktober 2020 Mathias skrev (På 17.3.2020 den 11.04): For de av dere med Home Assistant så finnes det en custom component laget av @aglehmann på Github som fungerer greit. Det vil si; man kan slå av og på viften fra HA, og det er dønn stabilt, men viftehastighet og modus fungerer ikke. Uansett så bruker jeg denne i HA for å kunne automatisere når vifter går. Jeg har en Flexit Roomie dual wifi. Man finner den her: https://github.com/aglehmann Han har også laget et python-script for samme vifte. Det har jeg ikke testet. EDIT: I siste versjon fungerer endring av viftehastighet også. Ekspander Dessverre har den ikke støtte for versjon 2 ennå. Siter
nilst Skrevet 4. oktober 2020 Skrevet 4. oktober 2020 Det har kommet en Home Assistant AddOn for Duka One vifter som også fungerer utmerket på Vents Twinfresh v.2, Blauberg Expert v.2 og Flexit Roomie v2. https://github.com/dingusdk/ha-dukaone 1 Siter
Moskus Skrevet 5. oktober 2020 Skrevet 5. oktober 2020 Er det noen som vet om en versjon av denne eller tilsvarende med mindre diameter på rørføringen?`Ø160 er en del... Siter
gullfrode Skrevet 5. oktober 2020 Skrevet 5. oktober 2020 Moskus skrev (På 5.10.2020 den 7.25): Er det noen som vet om en versjon av denne eller tilsvarende med mindre diameter på rørføringen?`Ø160 er en del... Ekspander Alle jeg har sett er 160mm ihvertfall. hadde kvadratiske hull på 15cm i kjelleren, så var mest puss jeg måtte meisle vekk fra opprinnelige kanaler(mangler en del i 1. etg ennå) Har forøvrig kjøpt HS3 plugin og fått Python-script for MQTT, men Hassiointegrasjon(og MQTT fra Hassio) var lettere for meg å sette opp) Siter
nilst Skrevet 6. oktober 2020 Skrevet 6. oktober 2020 Moskus skrev (På 5.10.2020 den 7.25): Er det noen som vet om en versjon av denne eller tilsvarende med mindre diameter på rørføringen?`Ø160 er en del... Ekspander Du kan jo se på denne: Blauberg Vento Expert A30 W V.2 Foris kan muligens skaffe denne (?) Mener den er rett i overkant av 100mm. 1 Siter
Moskus Skrevet 6. oktober 2020 Skrevet 6. oktober 2020 nilst skrev (På 6.10.2020 den 7.47): Du kan jo se på denne: Blauberg Vento Expert A30 W V.2 Foris kan muligens skaffe denne (?) Mener den er rett i overkant av 100mm. Ekspander Supert! Jeg skal sjekke den. (Ikke til meg, men til svigermor). Siter
gullfrode Skrevet 6. oktober 2020 Skrevet 6. oktober 2020 Moskus skrev (På 6.10.2020 den 7.58): Supert! Jeg skal sjekke den. (Ikke til meg, men til svigermor). Ekspander @Rogerbl importerer vel Blauberg,så kanskje han kan hjelpe 1 Siter
Rogerbl Skrevet 16. oktober 2020 Skrevet 16. oktober 2020 (endret) Rogerbl skrev (På 25.2.2020 den 13.38): Har nå ferdig Mqtt programvare for å styre v.2 Vento Expert wifi modellene fra Blauberg! Kompatibel med Vents Twinfresh og Flexit v.2 enhetene. Der er også en ny versjon av programvare for v.1 modellene som samspiller med v.2 slik at de "smelter sammen" som ett system. Les mer på min nettbutikk: https://blomkvistitk.no/produkt/styring-og-monitorerings-programvare-for-blauberg-vento-expert-wifi-v-2-enheter/ Det planlegges en egen dedikert Homeseer plugin for v.2 modellene i løpet av året. Ekspander HS3/Hs4 plugin for v.2 enheter er ferdige. Det er også Mqtt program(python basert) for v.1 og v.2 modeller. Disse har også fyringsmodus og vaccum modus(for tekniske rom). Fyringsmodus(overtrykksmodus) kan visstnok benyttes for å forhindre radon å trenge inn. Testet også med Duka One S6W enheter... Endret 16. oktober 2020 av Rogerbl 1 Siter
Rogerbl Skrevet 16. oktober 2020 Skrevet 16. oktober 2020 (endret) gullfrode skrev (På 6.10.2020 den 17.00): @Rogerbl importerer vel Blauberg,så kanskje han kan hjelpe Ekspander A30-1 har også 160mm kanaler. Men Blauberg Freshbox har 100mm kanaler(to stk). Disse forhandler jeg også. Disse har jeg også utviklet Hs3/Hs4 plugins for og også Mqtt modul til. Endret 16. oktober 2020 av Rogerbl Siter
Moskus Skrevet 17. oktober 2020 Skrevet 17. oktober 2020 Men da må man altså ha to kanaler? Det finnes ingenting som passer i 100 mm? Siter
Rogerbl Skrevet 17. oktober 2020 Skrevet 17. oktober 2020 (endret) Moskus skrev (På 17.10.2020 den 11.34): Men da må man altså ha to kanaler? Det finnes ingenting som passer i 100 mm? Ekspander Denne har 100 og 125mm kanaler:https://blomkvistitk.no/produkt/smart-wifi-ivifte-serien/ Det er en vifte uten varmegjenvinning, men har Mqtt programvare til den også. Endret 17. oktober 2020 av Rogerbl Siter
Moskus Skrevet 17. oktober 2020 Skrevet 17. oktober 2020 Hmmm.... det er jo varmegjenvinningen som er interessant. Siter
