Teknor Skrevet søndag kl 11:20 Skrevet søndag kl 11:20 Jeg bruker disse, @Smax: - platform: template sensors: de_fire_billigste_timene: friendly_name: "De fire billigste timene" value_template: >- {% set l=state_attr('sensor.nordpool_kwh_no1_nok_3_10_025', 'raw_today')|sort(attribute='value') %} {% set t = now() %} {{ (t >= l[0].start and t <= l[0].end) or (t >= l[1].start and t <= l[1].end) or (t >= l[2].start and t <= l[2].end) or (t >= l[3].start and t <= l[3].end) }} de_fire_neste_billigste_timene: friendly_name: "De fire nest billigste timene" value_template: >- {% set l=state_attr('sensor.nordpool_kwh_no1_nok_3_10_025', 'raw_today')|sort(attribute='value') %} {% set t = now() %} {{ (t >= l[4].start and t <= l[4].end) or (t >= l[5].start and t <= l[5].end) or (t >= l[6].start and t <= l[6].end) or (t >= l[7].start and t <= l[7].end) }} de_mellomste_timene: friendly_name: "De åtte mellomste timene" value_template: >- {% set l=state_attr('sensor.nordpool_kwh_no1_nok_3_10_025', 'raw_today')|sort(attribute='value') %} {% set t = now() %} {{ (t >= l[8].start and t <= l[8].end) or (t >= l[9].start and t <= l[9].end) or (t >= l[10].start and t <= l[10].end) or (t >= l[11].start and t <= l[11].end) or (t >= l[12].start and t <= l[12].end) or (t >= l[13].start and t <= l[13].end) or (t >= l[14].start and t <= l[14].end) or (t >= l[15].start and t <= l[15].end) }} de_fire_nest_dyreste_timene: friendly_name: "De fire nest dyreste timene" value_template: >- {% set l=state_attr('sensor.nordpool_kwh_no1_nok_3_10_025', 'raw_today')|sort(attribute='value', reverse=true) %} {% set t = now() %} {{ (t >= l[4].start and t <= l[4].end) or (t >= l[5].start and t <= l[5].end) or (t >= l[6].start and t <= l[6].end) or (t >= l[7].start and t <= l[7].end) }} de_fire_dyreste_timene: friendly_name: "De fire dyreste timene" value_template: >- {% set l=state_attr('sensor.nordpool_kwh_no1_nok_3_10_025', 'raw_today')|sort(attribute='value', reverse=true) %} {% set t = now() %} {{ (t >= l[0].start and t <= l[0].end) or (t >= l[1].start and t <= l[1].end) or (t >= l[2].start and t <= l[2].end) or (t >= l[3].start and t <= l[3].end) }} og den_billigste_timen: friendly_name: "Den billigste timen" value_template: >- {% set l=state_attr('sensor.nordpool_kwh_no1_nok_3_10_025', 'raw_today')|sort(attribute='value') %} {% set t = now() %} {{ (t >= l[0].start and t <= l[0].end) }} Siter
sbarmen Skrevet søndag kl 14:58 Skrevet søndag kl 14:58 On 13/12/2024 at 20:29, Smax said: Den var genial. Er den stabil? Funka fjell lenge! Har ikke oppdaget noen feil så langt. Har også lagt ut litt detaljer her: https://github.com/corvy/home-assistant-playground/tree/main/power-management Siter
Teknor Skrevet søndag kl 16:53 Skrevet søndag kl 16:53 (endret) sbarmen skrev (2 timer siden): Funka fjell lenge! Har ikke oppdaget noen feil så langt. Har også lagt ut litt detaljer her: https://github.com/corvy/home-assistant-playground/tree/main/power-management Takk! Kult. Endret søndag kl 17:01 av Teknor Siter
Smax Skrevet søndag kl 16:59 Skrevet søndag kl 16:59 Teknor skrev (1 minutt siden): Takk - hvor limer jeg inn lovelace.yaml innholdet? Takker for opplegget ditt på sensorene! Skal legge til, ikke dumt med de forskjellige. Lovelace innholdet limer du inn på raw configuration editor, etter du har gått inn på edit på ett dashboard. Test på et nytt for og ikke slette det du har. Kan eventuelt ta bort sections: og opp over, - på type på grid card og den siste max_columns: 1. vil tro det fungerer. og sette det inn som et card. @sbarmen takker så meget. Ska prøve og sette det opp også. Siter
sbarmen Skrevet mandag kl 08:44 Skrevet mandag kl 08:44 Når jeg satte opp dette første gangen tok jeg og lagde et nytt dashboard (under settings/dashboard) og så limte jeg inn alt i det nye. Da ødelegger du ikke noe og så kan du kontrollert flytte over når du har fått det til å fungere som du ønsker. Si ifra om det ikke fungerer @Teknor 1 Siter
