JowiHue Error: (WaitEventThread)::Invalid reference passed through an event ref=1095 please check your events?
Hm., får lignende feil på de fleste lysene.
Mistenker ny wifi-til å være årsaken, har samme ip som før.
Fra mobil er det ok.
Gode råd er dyre...
Ai, pokker.
Fungerte 75% i noen dager, men nå er det bare krøll.
sep-03 11.17.17	 	Info	Plugin JowiHue has connected. IP:127.0.0.1:64606
sep-03 11.17.17	 	Warning	I/O interface JowiHue is down, executable is not running, restarting ...
sep-03 11.17.03	 	Info	Plugin JowiHue with instance: has disconnected
sep-03 11.17.03	 	JowiHue	Initialisation bridgedevices did not complete correctly, exiting plugin
sep-03 11.17.03	 	JowiHue	Error: (FindBridgesSelf)::Objektreferanse er ikke satt til en objektforekomst.
sep-03 11.16.47	 	Starting Plug-In	Plugin JowiHue started successfully in 289 milliseconds
sep-03 11.16.47	 	JowiHue	InitIO:Plugin basic initialisation done
sep-03 11.16.47	 	JowiHue	Starting plugin JowiHue 2.0.4.7 on Windows
sep-03 11.16.47	 	Starting Plug-In	Initializing plugin JowiHue ...
Håper utvikleren snart finner en løsning.
sep-05 11.37.07	 	Warning	Plugin JowiHue is not responding but it is still running, not restarting yet.
sep-05 11.36.54	 	Info	Plugin JowiHue with instance: has disconnected
sep-05 11.36.54	 	JowiHue	Initialisation bridgedevices did not complete correctly, exiting plugin
sep-05 11.36.54	 	JowiHue	Error: (FindBridgesSelf)::Objektreferanse er ikke satt til en objektforekomst.
sep-05 11.36.52	 	Plug-In	Finished initializing plug-in JowiHue
sep-05 11.36.52	 	Starting Plug-In	JowiHue loaded in 15025 milliseconds
sep-05 11.36.37	 	Starting Plug-In	Plugin JowiHue started successfully in 248 milliseconds
sep-05 11.36.37	 	JowiHue	InitIO:Plugin basic initialisation done
sep-05 11.36.37	 	JowiHue	Starting plugin JowiHue 2.0.4.8 on Windows
sep-05 11.36.37	 	Starting Plug-In	Initializing plugin JowiHue ...
sep-05 11.36.37	 	Info	Plugin JowiHue has connected. IP:127.0.0.1:53833
NIX, dette fungerer ikke.
Beta 2.0.4.8 hjalp ikke, la inn plug-ins fra backup, før beta, men da vil den ikke starte.
Bruker ikke HS-forumet men jeg kan ikke være den eneste nordmannen med Jowiehue.
Finnes det alternativer eller må jeg begynne fra start?
Nei, men det er der plugin-forfatteren er...
  • Haha 1
