Bytter nå ut mine RFXCom baserte røykvarslere med Fibaro.
Kan rapportere at "wakeup" funker fint ved å trykke en gang på knappen på røykvarslerne.
Tar med nettbrett med HS på, starter optimaliseringen fra den og trykker så umiddelbart på wakeup.
Men @Moskus under inkluderingen så assosierer den 5 grupper til HS.
Hvem av disse skal jeg slette?
-Alle bortsett fra nr 1 ?
-Alle bortsett fra nr 5 ?
Hvilken versjon? Den nyeste med z-wave+ (500 brikke)?
Jeg regner med at det er den nyeste versjonen du har kjøpt og da trenger du kun å assosiere HS med gruppe 1 (lifeline)
1st group – Lifeline. Reporting device state. Only one device - Z-Wave network controller may be set in this group. It’s not recommended to modify this association group.
2nd group – Smoke Alarm. Sending the BASIC SET control command once smoke is detected. Its value may be modified in advanced parameters (see section XVI). Group may control up to five on/off devices.
3rd group – Tamper. Sending the notification NOTIFICATION REPORT (TYPE = BURGLAR, EVENT = PRODUCT COVERING REMOVED) to associated devices once casing opening is detected. Up to five devices supporting casing opening command (NOTIFICATION REPORT) may be included in this group.
4th group – Smoke Alarm. Sending the notification SENSOR ALARM REPORT (TYPE = SMOKE ALARM) to associated devices once smoke is detected. Up to five devices supporting SMOKE ALARM command may be included in this group
5th group – Tamper. Sending SENSOR ALARM REPORT notification (TYPE = GENERAL) to associated devices once casing opening is detected. Up to five devices supporting SENSOR ALARM REPORT command may be included in this group.
