Mitsubishi varmepumpe. ESP8266 mqtt kontroll. Oppsett i konfigfiler
Dette er ikke en guide, men mere ett pågående arbeide.
Håpet er at jeg kan få tips om forbedringer.
Forhåpentligvis vil det også hjelpe andre til relativt raskt å få ett oppsett å bygge videre på.
Å sømme samen småbiter fra internet til det jeg poster hær var en ganske lang og frustrerende ørkenvandring.
broker.things:
mqtt:broker:mosquittoBroker "Mosquitto mqtt broker" [ host="192.168.1.20", secure=false ]
mqtt.things:
    Thing mqtt:topic:varmepumpe "Varmepumpe" (mqtt:broker:mosquittoBroker) @"Stue" {
    Channels:
        Type switch : power "varmepumpePower" [
            stateTopic="varmepumpe",        transformationPattern=   "JSONPATH:$.power",
            commandTopic="varmepumpe/set",  formatBeforePublish="{\"power\" : \"%s\"}",
            on="ON", off="OFF"
        Type string : mode  "varmepumpeMode"  [
            stateTopic="varmepumpe",        transformationPattern=   "JSONPATH:$.mode",
            commandTopic="varmepumpe/set",  formatBeforePublish="{\"mode\" : \"%s\"}",
            allowedStates="HEAT,DRY,COOL,FAN,AUTO"
        Type number : temperature "VarmepumpeTemp" [
            stateTopic="varmepumpe",        transformationPattern=   "JSONPATH:$.temperature",
            commandTopic="varmepumpe/set",  formatBeforePublish="{\"temperature\" : \"%s\"}"
        Type string : fan "Varmepumpe vifte" [
            stateTopic="varmepumpe",        transformationPattern=   "JSONPATH:$.fan",
            commandTopic="varmepumpe/set",  formatBeforePublish="{\"fan\" : \"%s\"}",
            allowedStates="AUTO,QUIET,1,2,3,4"
        Type string : vane "Varmepumpe Vane" [
            stateTopic="varmepumpe",        transformationPattern=   "JSONPATH:$.vane",
            commandTopic="varmepumpe/set",  formatBeforePublish="{\"vane\" : \"%s\"}",
            allowedStates="AUTO,1,2,3,4,5,SWING"
        //Type string : wvane "Varmepumpe WideVane" [
         //   stateTopic="varmepumpe",        transformationPattern=   "JSONPATH:$.wideVane",
        //    commandTopic="varmepumpe/set",  formatBeforePublish="{\"wideVane\" : \"%s\"}",
        //    allowedStates="<<,<,|,>,>>,<>,SWING"
        Type switch : operating "Varmepumpa jobber" [
            stateTopic="varmepumpe/status",        transformationPattern=   "JSONPATH:$.operating",
            on="true", off="false"
        Type number : roomTemperature "VarmepumpeRomTemp" [
            stateTopic="varmepumpe/status",        transformationPattern=   "JSONPATH:$.roomTemperature"
Grunnen til at broker.things er splittet fra mqtt.things er at en bug i Openhab krever full restart av openhab -servicen når fila med brokeroppsettet blir editert.
Dette var en alvorlig snubblefelle som stjal mye tid.
Jeg kommenterte ut widevane i mqtt.things.
Ett eller annet med dette gjør at openhab bomber fra seg en haug av feilmeldinger.
Noe er også litt rart med hele vane-oppsettet.
Tror det er noe i programmet i ESPen som ikke er helt med på utstyret pumpa mi har.
varmepumpe.items:
Switch varmepumpePower "Varmepumpe Power" {channel= "mqtt:topic:varmepumpe:power"}
String varmepumpeMode  "Varmpumpe Mode"   {channel= "mqtt:topic:varmepumpe:mode"}
Number varmepumpeTemp  "Varmepumpe Temp"  {channel= "mqtt:topic:varmepumpe:temperature"}
String varmepumpeFan   "Varmepumpe Vifte" {channel= "mqtt:topic:varmepumpe:fan"}
String varmepumpeVane  "Varmepumpe Vane"  {channel= "mqtt:topic:varmepumpe:vane"}
String varmepumpeWideVane "Varmepumpe WideVane" {channel= "mqtt:topic:varmepumpe:wvane"}
Switch varemepumpeOperating "Varmepumpa jobber"     {channel= "mqtt:topic:varmepumpe:operating"}
Number varmepumpeRomTemp    "Varmepumpe RomTemp"    {channel= "mqtt:topic:varmepumpe:roomTemperature"}
Brukte en Adafruit Huzza breakout med programmvare herfra https://github.com/SwiCago/HeatPump
HeatPump-master/examples/mitsubishi_heatpump_mqtt_esp8266_esp32
Jeg skrev mere om ESPen hær:
Endret av NilsOF
