Jeg har noen noder som "henger" som jeg ikke blir kvitt. Vet faktisk ikke hvor de kom fra i sin tid engang.
"Remove Bad Node" gir feilmelding, og hvis jeg bare sletter de som dukker de opp igjen senere (er vel i forbindelse med Optimize de dukker opp kanskje).
Feilmeldingen:
Node 20 was not removed from any interface in the system, it may still be communicating or function aborted.
Noen råd? Har lest at man må manuelt endre databasen og importere denne til UZB, men at man da mister all ruting og må vekke batterinoder for å få de inn igjen i nettverket. Ikke så keen på det..
Logg fra resett, ser ikke ut som om det går helt knirkefritt..
nov-20 07.15.53	 	Z-Wave	UZB is the SIS for the network.
nov-20 07.15.53	 	Z-Wave	UZB There is a SUC/SIS in the network.
nov-20 07.15.53	 	Z-Wave	UZB Controller is static lib.
nov-20 07.15.53	 	Z-Wave	UZB Controller chip type is ZW050x.
nov-20 07.15.53	 	Z-Wave	The interface's security support has been set.
nov-20 07.15.53	 	Z-Wave	UZB: Found 37 Z-Wave nodes in interface node ID 1 (UZB)
nov-20 07.15.53	 	Z-Wave	UZB: Z-Wave interface node ID: 1, Home ID: CEFFB3A7
nov-20 07.15.53	 	Z-Wave	UZB: Z-Wave Serial API version: 5
nov-20 07.15.50	 	Z-Wave	UZB: Controller firmware version: 5.6
nov-20 07.15.50	 	Z-Wave	UZB: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4
nov-20 07.15.48	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.15.48	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.15.46	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.15.46	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.15.35	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.15.34	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.15.27	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.15.27	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.15.15	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.15.14	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.15.07	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.15.07	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.15.00	 	Log Info	The log database is currently 49.87MB in size.
nov-20 07.14.55	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.14.54	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.14.52	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.14.52	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.14.40	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.14.40	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.14.28	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.14.28	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.14.26	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.13.52	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.13.40	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.13.36	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.13.26	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.13.26	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.13.24	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.13.23	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.13.11	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.13.11	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
nov-20 07.12.59	 	Z-Wave	UZB: Getting node information from controller...
nov-20 07.12.59	 	Z-Wave	UZB: ----------------------------------------------------------------------
nov-20 07.12.59	 	Z-Wave	Initializing Z-Wave interface UZB (Z-Wave.me UZB) on COM8
nov-20 07.12.59	 	Z-Wave	UZB: ======================================================================
nov-20 07.12.52	 	Z-Wave	UZB: Exiting COM Device Thread
nov-20 07.12.52	 	Z-Wave Warning	A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
Jeg får fremdeles ikke fjernet nodene.
Dette problemet har vedvart gjennom flere restarter av maskinen. Har tilogmed byttet USB-kontrolleren på selve maskinen fordi jeg mistenke at det var noe "rusk" med den nye jeg hadde satt inn for et par uker tilbake.
Beklager hvis jeg "offer" meg mye og er negativ her :P Jeg er i utgangspunktet oppvokst med å formatere Windows når det skjer noe sånn "drit" som dette, men det å "formatere" hele Homeseer/Z-wave nettverket er jo en uhorvelig oppgave..
Jeg bruker å trykke på  "Test connectivity" på noden først. Så fort Homeseer rapporterer at den ikke svarer, trykker jeg på "Remove Bad Node". Funker i 99/100 tilfeller. :)
Godt forslag, men det virket ikke for meg dessverre.
Du mister all routing, men batterinoder er jo i nettverket. Hvis du har mange noder er det jo uansett anbefalt å ikke optimalisere... ;)
Men du sier nodene er gamle, og at du ikke vet hvor de kom fra. Men er det reelle noder? Får du svar når du spør dem? Hvilken info om den er det på Node Information (Plugins -> Z-wave -> Node Information)?
Ang. Optimize så har jeg 37 noder, og forstår at det er i grenseland for når man bør stoppe Optimize
Har nå slettet node 20 som device i Homeseer, så derfor den mangler navn tenker jeg.
Jeg vet ærlig talt ikke hvor disse kom fra, men mistenker egen loking rundt i systemet og med noen noder fra tidligere.. dessverre.
1877033577_Screenshot2019-11-20at19_57_04.thumb.png.b7cac33ad8f90901b56ad5d3e3d3cee4.png
1919197184_Screenshot2019-11-20at19_55_36.thumb.png.e23fe8079fbf8920d7dcadf93e1cceec.png
Ai... det gjør det vanskeligere å fjerne den. Du får vel gjøre en IMPORT og se om den dukker opp.
Sletting av devicer i HomeSeer gjør ingenting. Det er i selve interfacet den må fjernes.
