Da har det visst kommet en ny versjon av domoticz
https://www.domoticz.com/forum/viewtopic.php?f=3&t=13942
Latest changes:
Version 3.5837 (October 30th 2016)
- Fixed: Blockly/Lua, FOR and RANDOM are now again in minutes
Version 3.5834 (October 29th 2016)
- Implemented: TSL2561 illuminance I2C sensor (ldrolez)
- Implemented: AccuWeather support
- Implemented: Air Quality graph, Avarage and Previous month/year
- Implemented: Atag One Thermostat support
- Implemented: Blockly/Lua Camera device, to send camera snapshots with subject after xx seconds
- Implemented: Blockly upgraded to latest version (fixed and cleaned some code as well), this fixes problem with long sensor lists
- Implemented: Blockly, option to excecute a script in the DO statement
- Implemented: Custom Sensor
- Implemented: Denkovi Smartden with LAN Interface
- Implemented: Devices Tab, Log icon for Pressure
- Implemented: Dust Sensor (ug/m3)
- Implemented: Error Log, option to send error logs by email
- Implemented: Hourly rainrate for all rain sensors
- Implemented: MySensors, Implemented Acknowledge Timeout per Child sensor
- Implemented: MySensors, S_WATER_QUALITY, water PH
- Implemented: MySensors, S_WATER_QUALITY, water ORP redox potential in mV
- Implemented: MySensors, S_WATER_QUALITY, water electric conductivity S/cm (microSiemens/cm)
- Implemented: MySensors, S_POWER, Reactive power: volt-ampere reactive (var)
- Implemented: MySensors, S_POWER, Apparent power: volt-ampere (VA)
- Implemented: MySensors, S_POWER, Ratio of real power to apparent power: floating point value in the range [-1,..,1]
- Implemented: Nefit Easy, User Mode (as switch, On=Clock, Off=Manual), Flow Temperature, Hot Water Mode
- Implemented: Notifications, custom notification text helpers $name and $value
- Implemented: OpenZWave, Aeotec ZWave+ USB Controller, Enable/Disable blinking mode (@Schmart, Thanks for the magic codes!)
- Implemented: OpenZWave, Node table, now also displays Manufacturer, Product ID and Product Type
- Implemented: OpenZWave, When including Thermostat Setpoints, the zwave Label will be used as Name by default
- Implemented: RFXMeter, Option to specify meter offset
- Implemented: P1 Electra Report, Now also displaying the counters for Return
- Implemented: RFLink: Displaying firmware version in the hardware setup
- Implemented: RFXCom, Blinds T12 (Confexx)
- Implemented: S0 Meter TCP
- Changed: Local I2C sensors grouping (ldrolez)
- Changed: ETH-8020, ignoring return message as it always returns (no more Success message)
- Changed: EventSystem, weather/rain value is now the rain-rate
- Changed: Forecast.io to DarkSky
- Changed: OpenZWave, Better support for Thermostat Modes
- Changed: Stable ID generation for Philips Hue scenes (you need to delete all scenes and restart the hue hardware or domoticz)
- Changed: TE923, Rain counter devided by 2
- Changed: Waterflow sensor, now uses Node+Child as ID (for example 0x0801)
- Changed: Wind Direction graph (now does not display directions when speed was equal to zero)
- Fixed: Better handling of white listed commands/urls
- Fixed: Blockly, fixed extra quote when setting a user variable string value
- Fixed: Database backup is now only possible for admin users
- Fixed: Double checking command rights
- Fixed: Dummy, Creating a new sensor always used the same id
- Fixed: Dummy, when new sensor is created, Add it to the EventSystem
- Fixed: Fix Off Delay not handled for Selector switch (#538).
- Fixed: Fix On/Off delays not saved on the selector switch edit form (#532).
- Fixed: Logitech Harmony, Ping request now working as well for firmware 4.10.30 (Herman)
- Fixed: KMTronic, did not work in timers/groups/scenes
- Fixed: Manual Light/Switch, when created, Add it to the EventSystem
- Fixed: Wind Speed/Gust graph, Plotbands
- Fixed: Added grid lines to percentage/lux/general graphs
- Updated: AngularJS 1.5.8
- Updated: Highcharts 4.2.6
- Updated: SQLite3 v3.13.0
