Z-wave Controller vil ikke aktivere seg Data error (cyclic redundancy check).
Har fått en liten krise her hjemme...
Jeg hadde en gammel node som ikke eksisterte lenger i Zwave nettverket mitt, så jeg prøvde meg på "Remove bad node" funksjonen i HomeSeer 3.
Funka greit nok, noden forsvant og det så greit ut.
Men så merker jeg at ingen ting fungerer lenger, og når jeg sjekker status på Zwave kontrolleren, så er den gult med et utropstegn og feilmeldingen:
"Z-Stick Home: Exception transmitting from port COM4: Data error (cyclic redundancy check)."
Om jeg prøver å disable og enable så kommer samme melding.
I loggen står følgende:
des-11 21.33.26	 	Z-Wave	Z-Stick Home: Getting node information from controller...
des-11 21.33.26	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
des-11 21.33.25	 	Z-Wave	Z-Stick Home: Getting node information from controller...
des-11 21.33.25	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
des-11 21.33.23	 	Z-Wave	Z-Stick Home: Getting node information from controller...
des-11 21.33.23	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
des-11 21.33.21	 	Z-Wave	Z-Stick Home: Getting node information from controller...
des-11 21.33.21	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
des-11 21.33.20	 	Z-Wave	Z-Stick Home: Getting node information from controller...
des-11 21.33.20	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
des-11 21.33.19	 	Z-Wave	Z-Stick Home: Getting node information from controller...
des-11 21.33.19	 	Z-Wave	Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
des-11 21.33.19	 	Z-Wave Error	Z-Stick Home: Exception transmitting from port COM4: Data error (cyclic redundancy check).
Hva kan man gjøre her?
Hvis jeg prøver å starte Z-Seer+ Diagnostics Software, så vil den ikke koble til fordi jeg må enable interfacet i HomeSeer først.
Jeg har prøvd å restarte homeseer
Jeg har prøvd å restarte serveren
Jeg har prøvd å ta ut USB kontrolleren og sette den inn i en annen port
På Z-Wave Interfaces siden hvor man får listet opp kontrolleren sin og kan gjøre forskjellige tasks, så er listen over mulige tasks tom (sikkert fordi interfacet er disablet/ikke startet).
Endret av TropiskNektar
