Jeg har utvendige screens og har Aeotec Nano shutter (3stk, montert av elektriker) for styring av disse.
Jeg har klart å legge til Nano shutter'ne i Home Assistant, men fjernstyringen virker ikke.
Noen som har et fungerende oppsett og kan forklare hva jeg skal gjøre for å få dette til å fungere?
Kan ikke se at det kommer noe i loggen når jeg trykker på veggbryter for å ta screen opp/ned.
Jeg hører det klikke i nano shutter når jeg trykker på opp/ned i HA GUI, og følgende kommer i OZW_Log.txt:
2020-01-22 13:46:43.903 Info, Node031, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2020-01-22 13:46:43.904 Info, Node031, SwitchBinary::Set - Setting node 31 to On
2020-01-22 13:46:43.904 Detail, Node031, Queuing (Send) SwitchBinaryCmd_Set (Node=31): 0x01, 0x0a, 0x00, 0x13, 0x1f, 0x03, 0x25, 0x01, 0xff, 0x25, 0x9b, 0x9f
2020-01-22 13:46:43.904 Detail, Node031, Queuing (Send) SwitchBinaryCmd_Get (Node=31): 0x01, 0x09, 0x00, 0x13, 0x1f, 0x02, 0x25, 0x02, 0x25, 0x9c, 0x66
2020-01-22 13:46:43.905 Detail,
2020-01-22 13:46:43.905 Info, Node031, Sending (Send) message (Callback ID=0x9b, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=31): 0x01, 0x0a, 0x00, 0x13, 0x1f, 0x03, 0x25, 0x01, 0xff, 0x25, 0x9b, 0x9f
2020-01-22 13:46:43.913 Detail, Node031,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-22 13:46:43.913 Detail, Node031,   ZW_SEND_DATA delivered to Z-Wave stack
2020-01-22 13:46:43.957 Detail, Node031,   Received: 0x01, 0x07, 0x00, 0x13, 0x9b, 0x00, 0x00, 0x05, 0x75
2020-01-22 13:46:43.957 Detail, Node031,   ZW_SEND_DATA Request with callback ID 0x9b received (expected 0x9b)
2020-01-22 13:46:43.957 Info, Node031, Request RTT 52 Average Request RTT 58
2020-01-22 13:46:43.957 Detail,   Expected callbackId was received
2020-01-22 13:46:43.957 Detail,   Expected reply was received
2020-01-22 13:46:43.957 Detail,   Message transaction complete
2020-01-22 13:46:43.958 Detail, Node031, Removing current message
2020-01-22 13:46:43.958 Info, Node031, Sending (Send) message (Callback ID=0x9c, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=31): 0x01, 0x09, 0x00, 0x13, 0x1f, 0x02, 0x25, 0x02, 0x25, 0x9c, 0x66
2020-01-22 13:46:43.967 Detail, Node031,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-22 13:46:43.967 Detail, Node031,   ZW_SEND_DATA delivered to Z-Wave stack
2020-01-22 13:46:44.091 Detail, Node031,   Received: 0x01, 0x07, 0x00, 0x13, 0x9c, 0x00, 0x00, 0x0d, 0x7a
2020-01-22 13:46:44.091 Detail, Node031,   ZW_SEND_DATA Request with callback ID 0x9c received (expected 0x9c)
2020-01-22 13:46:44.091 Info, Node031, Request RTT 134 Average Request RTT 96
2020-01-22 13:46:44.091 Detail,   Expected callbackId was received
2020-01-22 13:46:44.170 Detail, Node031,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x1f, 0x03, 0x25, 0x03, 0xff, 0x37
2020-01-22 13:46:44.170 Info, Node031, Response RTT 213 Average Response RTT 208
2020-01-22 13:46:44.170 Info, Node031, Received SwitchBinary report from node 31: level=On
2020-01-22 13:46:44.170 Detail, Node031, Refreshed Value: old value=false, new value=true, type=bool
2020-01-22 13:46:44.171 Detail, Node031, Changes to this value are not verified
2020-01-22 13:46:44.171 Detail, Node031,   Expected reply and command class was received
2020-01-22 13:46:44.171 Detail, Node031,   Message transaction complete
2020-01-22 13:46:44.171 Detail, Node031, Removing current message
2020-01-22 13:46:44.171 Detail, Node031, Notification: ValueChanged
2020-01-22 13:46:44.230 Detail, Node031,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x1f, 0x03, 0x25, 0x03, 0xff, 0x37
2020-01-22 13:46:44.230 Info, Node031, Received SwitchBinary report from node 31: level=On
2020-01-22 13:46:44.231 Detail, Node031, Refreshed Value: old value=true, new value=true, type=bool
2020-01-22 13:46:44.231 Detail, Node031, Changes to this value are not verified
2020-01-22 13:46:44.231 Detail, Node031, Notification: ValueChanged
2020-01-22 13:46:44.441 Detail, Node031,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x1f, 0x03, 0x25, 0x03, 0xff, 0x37
2020-01-22 13:46:44.442 Info, Node031, Received SwitchBinary report from node 31: level=On
2020-01-22 13:46:44.442 Detail, Node031, Refreshed Value: old value=true, new value=true, type=bool
2020-01-22 13:46:44.442 Detail, Node031, Changes to this value are not verified
2020-01-22 13:46:44.442 Detail, Node031, Notification: ValueChanged
