Hei.
Rydder, har 6 objekter som har flyttet nordover. Glemte å ekskludere de før jeg solgte de.
Google gav meg denne:
https://forums.homeseer.com/forum/lighting-primary-technology-plug-ins/lighting-primary-technology-discussion/z-wave-homeseer/103974-how-do-i-delete-a-phantom-device?p=1061650#post1061650
Da blir det bare feilmeldinger i liggen:
apr-05 21.59.01 Z-Wave Warning EB: Node 106 was not removed because the interface EB does not have that node in its memory. (It may already be removed.)
apr-05 21.58.40 Z-Wave Warning EB: Node 103 was not removed because the interface EB does not have that node in its memory. (It may already be removed.)
apr-05 21.58.17 Z-Wave Warning EB: Node 101 was not removed because the interface EB does not have that node in its memory. (It may already be removed.)
apr-05 17.33.14 Z-Wave Warning EB: Node 100 was not removed because the interface EB does not have that node in its memory. (It may already be removed.)
apr-05 17.32.31 Z-Wave Warning EB: Node 99 was not removed because the interface EB does not have that node in its memory. (It may already be removed.)
apr-05 17.32.03 Z-Wave Warning EB: Node 98 was not removed because the interface EB does not have that node in its memory. (It may already be removed.)
De ligger i Node Information, kan jeg bare fjerne de fra Device List? Selv om det kommer advarsel:
God påske!
Hvis de ligger i Node List, så bør du ikke fjerne devicen, det gjør det bare vanskeligere for deg selv. Du må få fjernet den fra Interfacet først, og da kan det være verdt å prøve en "Restart Interface" før du trykker Remove Node (Restart ligger på Plugns -> Z-wave -> Controller Information)
Takk @Moskus det hjalp ikke.
Noden er det, samme melding når jeg prøver å kjøre Remove bad node.
På Network connectivity dukker de opp som røde.
Tester litt Optimize etc., tar strømmen. De plager ikke meg.
Det tror jeg du med fordel kan la være (ikke at det vil gå siden HS ikke får kontakt med noden).
De plager ikke meg.
Nei, de plager kanskje ikke deg, men det er mulig de plager nettverket ditt. Det er en fordel å få fjernet noder som ikke finnes.
  • Confused 1
  • 7 måneder senere...
Kom du i mål med dette @Erling? Har samme problem etter at en Telldus strømbryter tok kvelden:
xxx: Node 6 was not removed because the interface xxx does not have that node in its memory. (It may already be removed.)
Remove bad node fungerer altså ikke:
Node 6 was not removed from any interface in the system, it may still be communicating or function aborted.
Restart av z-wave plugin hjelper ikke.
Ja, men jeg vet ikke helt hva det var som gjorde utslaget.
Har lært at det ikke er lurt å kaste enheter eller selge de, uten at de er fjernet.
#skulket-z-wave-skolen
  • Haha 2
