Et script som sjekker når du får levert post.
1. Du trenger en referanse til Newtonsoft.Json i ScriptingReferences.
2. Du trenger en virtuell device uten knapper eller statuser.
3. Du trenger en konto hos MyBring, du kan opprette gratis her (du trenger ikke firmanavn): https://www.mybring.com/signup/register/user
4. En API-key som du finner på denne siden: https://www.mybring.com/useradmin/account/settings/api
Kjør dette scriptet ved midnatt:
    Sub Main(ByVal params As Object)
        Dim devRef As Integer = DIN_DEVICEREF_HER
        Dim postnummer As Integer = DITT_POSTNUMMER_HER
        Dim mybring_email As String = "[email protected]"
        Dim mybring_key As String = "DIN_KEY_FRA_MYBRING"
        Dim url As String = "https://api.bring.com/address/api/no/postal-codes/" & postnummer & "/mailbox-delivery-dates"
        Dim source As String = ""
        Try
            Using client As New System.Net.WebClient
                Net.ServicePointManager.SecurityProtocol = Net.SecurityProtocolType.Tls12
                client.Headers.Add("x-mybring-api-uid", mybring_email)
                client.Headers.Add("x-mybring-api-key", mybring_key)
                client.BaseAddress = url
                source = client.DownloadString(url)
            End Using
            Dim json As Object = Newtonsoft.Json.JsonConvert.DeserializeObject(Of Object)(source)
            Dim nestePost As String = json.item("delivery_dates").item(0).ToString
            Dim nestePostDato As Date = DateTime.Parse(nestePostDato)
            Dim dagerTilPost As Integer = nestePostDato.Date.Subtract(Now.Date).Days
            Dim output As String = ""
            For i As Integer = 0 To json("delivery_dates").Count - 1
                Dim currentDate As Date = DateTime.Parse(json.item("delivery_dates").item(i))
                output &= GetDateDescription(currentDate) & "<br>"
            Next
            hs.SetDeviceValueByRef(devRef, dagerTilPost, True)
            hs.SetDeviceString(devRef, output, False)
        Catch ex As Exception
            hs.SetDeviceValueByRef(devRef, -1, True)
            hs.SetDeviceString(devRef, "Feil: " & ex.Message, False)
        End Try
    End Sub
    Function GetDateDescription(ByVal nextDate As Date)
        Dim dagerTilPost As Integer = nextDate.Date.Subtract(Now.Date).Days
        If dagerTilPost = 0 Then
            Return "I dag"
        ElseIf dagerTilPost = 1 Then
            Return "I morgen"
        Else
            Return nextDate.ToString("dddd d. MMM")
        End If
    End Function
Devicen vil da se slik ut:
Device Value er antall dager til postleveranse. "0" betyr da at posten blir levert i dag, kan f.eks. brukes som trigger til noe. :)
EDIT: Takk til @daniel.h.iversen som fant ut at Posten har oppdaget at 2020 var i fjor. 👍
EDIT2: Takk til @DeVille som fant ut at siste 1 skal erstattes med 9.
EDIT3: Takk til @ZoRaC for sin oppdatering etter API-omleggingen hos Posten versjon som jeg bygget litt videre på.
  • Thanks 4
Får dette som status på devicen:
Quote
Feil: Strengen ble ikke gjenkjent som en gyldig DateTime. Et ukjent ord begynner ved indeks 1.
Kjør denne versjonen og post resultatet, så ser vi hva jeg ikke har klart å ta hensyn til. :)
        Dim devRef As Integer = 3915
        Dim postnummer As Integer = 4026
        Dim url As String = "https://www.posten.no/levering-av-post-2020/_/component/main/1/leftRegion/1?postCode=" & postnummer
        Try
                client.Headers.Add("x-requested-with", "XMLHttpRequest")
            End Using
            Dim json = Newtonsoft.Json.JsonConvert.DeserializeObject(Of Object)(source)
            For i As Integer = 0 To json("nextDeliveryDays").Count - 2
                output &= json("nextDeliveryDays")(i).ToString & "<br>"
            Next
            output &= json("nextDeliveryDays")(json("nextDeliveryDays").Count - 1).ToString
            'Dim nestePostdag As Date = DateTime.Parse((json("nextDeliveryDays")(0).ToString).Replace("i morgen", "").Replace("i dag", ""))
            'Dim dagerTilPost As Integer = nestePostdag.Date.Subtract(Now.Date).Days
            Dim dagerTilPost as Integer = 0
        End Try
    End Sub
Da kommer devicestring som forventet, og devicevalue blir satt til 0.
Vet ikke om det er relevant, men om jeg forsøker url`n i nettleser, så får jeg bare en hvit side. (med riktig postnummer i url)
Jo, men hva er device-stringen? Jeg ser at den kan inneholde tekst som "i dag" eller "i morgen", og derfor fjerner jeg dem før jeg prøver å parse verdien til en dato. Men det ser ut som du har fått noe som ikke har tatt hensyn til, eller at jeg har bommet på en.
Det stemmer, det er fordi man må legge til headeren "x-requested-with:XMLHttpRequest".
Ai, da. Det er jo det samme jeg skulle ha, det hadde jeg trodd skulle fungere. :(
Da er det mulig jeg må sende CultureInfo.
Prøv dette, da. :)
        Try
            End Using
            Next
            Dim nestePostdag As Date = DateTime.Parse((json("nextDeliveryDays")(0).ToString.ToLower).Replace("i morgen", "").Replace("i dag", ""), New System.Globalization.CultureInfo("nb-NO"))
        End Try
    End Sub
... da skal "value" bli 1.
Denne bør også fungere i HS4? Jeg er ikke veldig stø i dette ennå, men fikk lagt inn scriptet og knyttet det til en event. Når jeg kjører eventen, kjører scriptet, men det skjer ingenting med devicen jeg har opprettet. Ser heller ingen feil i loggen. Mulig jeg har oversett ett eller annet, og i så fall mistenker jeg at det gjelder oppsettet av den virtuelle devicen. Usikker på hvordan man oppretter en slik "uten knapper eller statuser" (slik det står i første post). Noen som har tips til løsning?
hs.SetDeviceString burde gjøre jobben uansett, hvis ikke den fungerer, så er det mye som burde fungere.
Men du kan jo prøve å kjøre dette miniscriptet:
hs.SetDeviceString(DIN_DEV_REF,  "Dette er en test", True)
Tusen takk for god hjelp!
Joda, det fungerer faktisk glimrende... det gjorde det hele vanskeligere å forstå...
Men når jeg nå ser i loggen (mulig jeg hadde på et filter tidligere siden jeg ikke så den da); så ser jeg (etter å ha kjørt Posten-scriptet):
Compiling script posten.vb: 'Newtonsoft' is not declared. It may be inaccessible due to its protection level.
og Compiling script posten.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Jeg har lagt til i settings.ini (nder ScriptingReferences:
Newtonsoft.Json;C:\Program Files (x86)\HomeSeer HS3\Bin\homeseer\Newtonsoft.Json.dll
Jeg har også sjekket at dll'en ligger i stien over (har oppgradert fra HS3, derfor hs3 i stien). Noe mer jeg bør gjøre i forbindelse med denne dll'en?
Prøv med " rundt path:
"C:\Program Files (x86)\HomeSeer HS3\Bin\homeseer\Newtonsoft.Json.dll"
Husk restart av HomeSeer etterpå.
Desverre, @ZoRaC. har forsøkt det også. Ingen forskjell. Det virker nesten ikke som om ScriptingReferences-linja blir lest inn...
Den ser for øvrig slik ut. Linja ligger nederst i [Settings] seksjonen.
ScriptingReferences=System.Core;System.Core.dll;System.Net;System.Net.dll;Newtonsoft.Json;"C:\Program Files (x86)\HomeSeer HS3\Bin\homeseer\Newtonsoft.Json.dll"
ini-fila blir lest inn og skrevet til ved hver oppstart av HS, så jeg vet at det er rett fil.
Ja, fila ligger der, men jeg har også flere andre newtonsoft.dll-filer på maskinen. Et søk ga faktisk over 120 eksemplarer. Noen ligger i andre plug-ins mapper (eks. DoorBird og Z-Wave), Ettersom jeg også har Nuget installert, er det noen eksemplarer under der. Noen ligger under Visual Studio. Den jeg peker på i ini-fila er på 474 KB. Noen er på 514, 478 og 457. Tror du jeg peker på feil versjon?
Ser forøvrig også at Newtonsoft er definert i HS4.exe.config:
<dependentAssembly>
          <assemblyIdentity name="Newtonsoft.Json"
                    publicKeyToken="30ad4fe6b2a6aeed"	/>
          <codeBase version="12.0.0.0"
                href="bin/homeseer/Newtonsoft.Json.dll" />
          <codeBase version="8.0.0.0"
                href="bin/Z-Wave/Newtonsoft.Json.dll" />
</dependentAssembly>
Men jeg aner ikke om det har noe å si...
Min Scriptingsreferences linje har semikolon for å skille "tjeneste-" og "dll-" parene og komma mellom hvert par. Ser ut som at du har semikolon hele veien.
Altså slik: (farget hvert par for å gjøre det lesbart) Hva om du gjør om på dette?
Fantastisk!
Der forsvant feilmeldingene gitt! Ble riktignok erstattet av en ny: Compiling script posten.vb: Illegal characters in path.
Men det er nok noe annet.
Tusen takk for god hjelp så langt!
Den siste feilen forsvant da jeg tok vekk "-tegnene i pathen. Nå funker skriptet som det skal! 😀
Endret av nilst
  • 4 uker senere...
Noen som har testet på Linux?
Får bare en devicestring som denne:
Exception has been thrown by the target of an invocation.
EDIT:
Måtte endre litt på denne for at det skulle funke:
Dim output As String = json.item("nextDeliveryDays").item(0).tostring
Endret av ZoRaC
  • 4 uker senere...
Oi, hva har jeg gjort galt nå da?
sep-16 08.31.31 ErrorCompiling script C:\Program Files (x86)\HomeSeer HS3\scripts\moskus-pat.vb: Newtonsoft er ikke deklarert. Den kan være utilgjengelig på grunn av beskyttelsesnivået.
sep-16 08.31.31 ErrorCompiling script C:\Program Files (x86)\HomeSeer HS3\scripts\moskus-pat.vb: Navneområdet eller typen som er angitt i importene System.Core, inneholder ikke noe felles medlem eller finnes ikke. Kontroller at navneområdet eller typen er definert og inneholder minst ett felles medlem. Kontroller at det importerte elementnavnet ikke bruker noen aliaser.
