Har mistet alle eventene mine etter jeg oppdaterte Node js på win 10 pc, har en noen dager gammel backup(HS3) men hvor skal disse legges inn?
28.07.2020 15.57.25 HomeSeer~!~Startup~!~********************************************************************************
28.07.2020 15.57.25 HomeSeer~!~Startup~!~             HomeSeer version 4.1.2.0 Edition: HS4 Pro Starting Now
28.07.2020 15.57.25 HomeSeer~!~Startup~!~Creating Class Objects...
28.07.2020 15.57.25 HomeSeer~!~Startup~!~COM port classes started.
28.07.2020 15.57.25 HomeSeer~!~Startup~!~Application interface class started.
28.07.2020 15.57.25 HomeSeer~!~Startup~!~Web server class started.
28.07.2020 15.57.25 HomeSeer~!~Startup~!~E-Mail SEND class started.
28.07.2020 15.57.25 HomeSeer~!~Startup~!~E-Mail RECEIVE class started.
28.07.2020 15.57.25 HomeSeer~!~Startup~!~Plug-In Interface class started.
28.07.2020 15.57.25 HomeSeer~!~Startup~!~Local voice recognition class started.
28.07.2020 15.57.25 HomeSeer~!~Startup~!~Loading configuration file ...
28.07.2020 15.57.26 HomeSeer~!~Info~!~Loaded 1523 Devices.
28.07.2020 15.57.26 HomeSeer~!~Info~!~Loaded 0 Events.
28.07.2020 15.57.26 HomeSeer~!~Warning~!~Unable to load counters config file, trying backup
28.07.2020 15.57.26 HomeSeer~!~Error~!~Unable to load counters from normal or backup file!
28.07.2020 15.57.26 HomeSeer~!~Warning~!~Unable to load timers config file, trying backup
28.07.2020 15.57.26 HomeSeer~!~Error~!~Unable to load timers from normal or backup file!
28.07.2020 15.57.26 HomeSeer~!~Startup~!~HomeSeer version is: 4.1.2.0
Bruker HS4 Node.js nå?
HS4 bruker vel den samme databasefilen som før, HomeSeer.hsd eller noe slikt. Se etter .hsd-filer.
Men ta selvfølgelig backup før du gjør noe som helst.
Node js brukes til Homebridge, men det gjorde at Homeseer ble korrupt.
Vet du hvilen fil som innholdet event?
Tok en kopi av hele Homeseer mappen før oppgradering
I HomeSeer3 er det denne filen:
... ligger under /Config hvis jeg ikke husker feil.
