De siste ukene har jeg hatt problemer med websocket i Home Assistant. Et eller annet klusser det til og Home Assistant lukker alle forbindelser og tar de opp igjen. Noe som blant annet fører til at alt i Deconz er utilgjengelig i ca 10s. Dette kan skje flere ganger til dagen. Noen ganger går det timer mellom hver gang og andre ganger sekunder.
Det er ting som tyder på at Tibber er synderen. Er det andre som har problemer? Eller er det et eller annet og Tibber er bare symptomet?
2020-09-14 13:00:41 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 13:08:51 ERROR (MainThread) [graphql_subscription_manager] Connection error
Traceback (most recent call last):
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 827, in transfer_data
    message = await self.read_message()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 895, in read_message
    frame = await self.read_data_frame(max_size=self.max_size)
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 971, in read_data_frame
    frame = await self.read_frame(max_size)
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 1047, in read_frame
    frame = await Frame.read(
  File "/usr/local/lib/python3.8/site-packages/websockets/framing.py", line 105, in read
    data = await reader(2)
  File "/usr/local/lib/python3.8/asyncio/streams.py", line 721, in readexactly
    raise exceptions.IncompleteReadError(incomplete, n)
asyncio.exceptions.IncompleteReadError: 0 bytes read on a total of 2 expected bytes
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.8/site-packages/graphql_subscription_manager/__init__.py", line 101, in running
    msg = await asyncio.wait_for(self.websocket.recv(), timeout=30)
  File "/usr/local/lib/python3.8/asyncio/tasks.py", line 483, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 509, in recv
    await self.ensure_open()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 803, in ensure_open
    raise self.connection_closed_exc()
websockets.exceptions.ConnectionClosedError: code = 1006 (connection closed abnormally [internal]), no reason
2020-09-14 13:09:46 ERROR (MainThread) [graphql_subscription_manager] Connection error
    return fut.result()
2020-09-14 13:11:05 ERROR (MainThread) [graphql_subscription_manager] 504 - "<!DOCTYPE html>\n<html>\n<head>\n<title>Error</title>\n<style>\n    body {\n        width: 35em;\n        margin: 0 auto;\n        font-family: Tahoma, Verdana, Arial, sans-serif;\n    }\n</style>\n</head>\n<body>\n<h1>An error occurred.</h1>\n<p>Sorry, the page you are looking for is currently unavailable.<br/>\nPlease try again later.</p>\n<p>If you are the system administrator of this resource then you should check\nthe error log for details.</p>\n<p><em>Faithfully yours, nginx.</em></p>\n</body>\n</html>\n"
2020-09-14 13:11:05 ERROR (MainThread) [graphql_subscription_manager] Connection error
    return fut.result()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 812, in ensure_open
websockets.exceptions.ConnectionClosedError: code = 1011 (unexpected error), no reason
2020-09-14 13:11:22 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
Her er min logg for idag, mye som er likt.
Ser faktisk nå Tibber mister kontakten ofte.
Spoiler
2020-09-13 23:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-13 23:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 00:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 00:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 01:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 01:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 02:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 02:41:17 WARNING (Thread-8) [pychromecast.socket_client] [rom1(10.10.88.91):8009] Heartbeat timeout, resetting connection
2020-09-14 02:41:42 ERROR (Thread-8) [pychromecast.socket_client] [rom1(10.10.88.91):8009] Failed to connect to service Chromecast-Ultra-7ca4ca2922b93sadsadads3dc417c267._googlecast._tcp.local., retrying in 5.0s
2020-09-14 03:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 03:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 03:33:33 WARNING (Thread-9) [pychromecast.socket_client] [rom2(10.10.88.92):8009] Heartbeat timeout, resetting connection
2020-09-14 03:47:24 WARNING (Thread-7) [pychromecast.socket_client] [rom3(10.10.88.90):8009] Heartbeat timeout, resetting connection
2020-09-14 04:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 04:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 05:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 05:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 06:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 06:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 07:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 07:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 08:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 08:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 09:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 09:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 10:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 10:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 11:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 11:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 11:25:01 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/config/custom_components/hacs/hacsbase/hacs.py", line 306, in recurring_tasks_all
    await self.async_load_default_repositories()
  File "/config/custom_components/hacs/hacsbase/hacs.py", line 346, in async_load_default_repositories
    await self.queue.execute()
  File "/usr/local/lib/python3.8/site-packages/queueman/manager.py", line 41, in execute
    raise QueueManagerExecutionStillInProgress
queueman.exceptions.QueueManagerExecutionStillInProgress
2020-09-14 12:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 12:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 13:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 13:01:23 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
    return fut.result()
    return fut.result()
2020-09-14 13:10:51 ERROR (MainThread) [graphql_subscription_manager] 502 - "<!DOCTYPE html>\n<html>\n<head>\n<title>Error</title>\n<style>\n    body {\n        width: 35em;\n        margin: 0 auto;\n        font-family: Tahoma, Verdana, Arial, sans-serif;\n    }\n</style>\n</head>\n<body>\n<h1>An error occurred.</h1>\n<p>Sorry, the page you are looking for is currently unavailable.<br/>\nPlease try again later.</p>\n<p>If you are the system administrator of this resource then you should check\nthe error log for details.</p>\n<p><em>Faithfully yours, nginx.</em></p>\n</body>\n</html>\n"
2020-09-14 13:10:51 ERROR (MainThread) [graphql_subscription_manager] Connection error
    return fut.result()
2020-09-14 13:11:07 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
2020-09-14 13:16:37 ERROR (MainThread) [graphql_subscription_manager] No data, reconnecting.
2020-09-14 13:16:54 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
2020-09-14 13:22:24 ERROR (MainThread) [graphql_subscription_manager] No data, reconnecting.
2020-09-14 13:22:40 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
2020-09-14 13:28:11 ERROR (MainThread) [graphql_subscription_manager] No data, reconnecting.
2020-09-14 13:28:27 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
2020-09-14 13:33:57 ERROR (MainThread) [graphql_subscription_manager] No data, reconnecting.
2020-09-14 13:34:14 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
2020-09-14 13:39:44 ERROR (MainThread) [graphql_subscription_manager] No data, reconnecting.
2020-09-14 13:40:00 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
2020-09-14 13:45:31 ERROR (MainThread) [graphql_subscription_manager] No data, reconnecting.
2020-09-14 13:45:47 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
2020-09-14 13:49:22 ERROR (MainThread) [graphql_subscription_manager] Connection error
    return fut.result()
2020-09-14 13:55:10 ERROR (MainThread) [graphql_subscription_manager] No data, reconnecting.
2020-09-14 14:01:03 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 15:01:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 15:01:24 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 15:42:07 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.nas_2_status is taking over 10 seconds
2020-09-14 16:01:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 16:36:07 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.nas_2_status is taking over 10 seconds
2020-09-14 17:01:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 18:20:06 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 275, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp/_http_parser.pyx", line 523, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
2020-09-14 19:01:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.electricity_price_xxx_1234 is taking over 10 seconds
2020-09-14 19:01:24 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
Endret av Offpiste
  • 1 år senere...
Hollendervika skrev (19 minutter siden):
Fant du noe løsning på problemet?? Har fått samme symptomer i HA
Det kom en oppdatering som løste alle problemer og nå er det dønn stabilt.
