De siste ukene har jeg hatt problemer med websocket i Home Assistant. Et eller annet klusser det til og Home Assistant lukker alle forbindelser og tar de opp igjen. Noe som blant annet fører til at alt i Deconz er utilgjengelig i ca 10s. Dette kan skje flere ganger til dagen. Noen ganger går det timer mellom hver gang og andre ganger sekunder.
Det er ting som tyder på at Tibber er synderen. Er det andre som har problemer? Eller er det et eller annet og Tibber er bare symptomet?
2020-09-14 13:00:41 ERROR (MainThread) [tibber] Timed out when connecting to Tibber
2020-09-14 13:08:51 ERROR (MainThread) [graphql_subscription_manager] Connection error
Traceback (most recent call last):
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 827, in transfer_data
    message = await self.read_message()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 895, in read_message
    frame = await self.read_data_frame(max_size=self.max_size)
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 971, in read_data_frame
    frame = await self.read_frame(max_size)
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 1047, in read_frame
    frame = await Frame.read(
  File "/usr/local/lib/python3.8/site-packages/websockets/framing.py", line 105, in read
    data = await reader(2)
  File "/usr/local/lib/python3.8/asyncio/streams.py", line 721, in readexactly
    raise exceptions.IncompleteReadError(incomplete, n)
asyncio.exceptions.IncompleteReadError: 0 bytes read on a total of 2 expected bytes
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.8/site-packages/graphql_subscription_manager/__init__.py", line 101, in running
    msg = await asyncio.wait_for(self.websocket.recv(), timeout=30)
  File "/usr/local/lib/python3.8/asyncio/tasks.py", line 483, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 509, in recv
    await self.ensure_open()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 803, in ensure_open
    raise self.connection_closed_exc()
websockets.exceptions.ConnectionClosedError: code = 1006 (connection closed abnormally [internal]), no reason
2020-09-14 13:09:46 ERROR (MainThread) [graphql_subscription_manager] Connection error
    return fut.result()
2020-09-14 13:11:05 ERROR (MainThread) [graphql_subscription_manager] 504 - "<!DOCTYPE html>\n<html>\n<head>\n<title>Error</title>\n<style>\n    body {\n        width: 35em;\n        margin: 0 auto;\n        font-family: Tahoma, Verdana, Arial, sans-serif;\n    }\n</style>\n</head>\n<body>\n<h1>An error occurred.</h1>\n<p>Sorry, the page you are looking for is currently unavailable.<br/>\nPlease try again later.</p>\n<p>If you are the system administrator of this resource then you should check\nthe error log for details.</p>\n<p><em>Faithfully yours, nginx.</em></p>\n</body>\n</html>\n"
2020-09-14 13:11:05 ERROR (MainThread) [graphql_subscription_manager] Connection error
    return fut.result()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 812, in ensure_open
websockets.exceptions.ConnectionClosedError: code = 1011 (unexpected error), no reason
2020-09-14 13:11:22 ERROR (MainThread) [homeassistant.components.tibber.sensor] {'message': 'RequestError: Error: getaddrinfo ENOTFOUND tibber_customer.dev', 'locations': [{'line': 3, 'column': 15}], 'path': ['liveMeasurement'], 'extensions': {'code': 'INTERNAL_SERVER_ERROR', 'exception': {'innerError': {'errno': 'ENOTFOUND', 'code': 'ENOTFOUND', 'syscall': 'getaddrinfo', 'hostname': 'tibber_customer.dev'}}}}
  stigvi skrev (På 14.9.2020 den 12.40):
Her er min logg for idag, mye som er likt.
Ser faktisk nå Tibber mister kontakten ofte.
  Vis skjult innhold
Endret av Offpiste
  • 1 år senere...
