Jeg trenger hjelp til å finne ut hva som er problemet med en Dimmer 2 jeg har. Ofte når jeg skal slå på lyset så prøver den, men ender med null resultat. Oftest er dette hvis lyset har vært av en stund.
Logg:
2020-10-23 07:15:09.142 Info, Node025, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2020-10-23 07:15:09.142 Detail, Node025, Refreshed Value: old value=255, new value=255, type=byte
2020-10-23 07:15:09.142 Detail, Node025, Changes to this value are not verified
2020-10-23 07:15:09.143 Info, Node025, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 255
2020-10-23 07:15:09.143 Info, Node025, SwitchMultilevel::Set - Setting to level 255
2020-10-23 07:15:09.143 Info, Node025,   Duration: Default
2020-10-23 07:15:09.143 Detail, Node025, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=25): 0x01, 0x0f, 0x00, 0x13, 0x19, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0xff, 0xff, 0x25, 0x12, 0x8f
2020-10-23 07:15:09.143 Detail, Node025, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=25): 0x01, 0x0d, 0x00, 0x13, 0x19, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0x13, 0x81
2020-10-23 07:15:09.143 Detail, Node025, Notification: ValueChanged
2020-10-23 07:15:09.156 Detail,
2020-10-23 07:15:09.156 Info, Node025, Sending (Send) message (Callback ID=0x12, Expected Reply=0x13) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Set (Node=25): 0x01, 0x0f, 0x00, 0x13, 0x19, 0x08, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x01, 0xff, 0xff, 0x25, 0x12, 0x8f
2020-10-23 07:15:09.180 Detail, Node025,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-23 07:15:09.180 Detail, Node025,   ZW_SEND_DATA delivered to Z-Wave stack
2020-10-23 07:15:09.197 Detail, Node025,   Received: 0x01, 0x07, 0x00, 0x13, 0x12, 0x00, 0x00, 0x02, 0xfb
2020-10-23 07:15:09.197 Detail, Node025,   ZW_SEND_DATA Request with callback ID 0x12 received (expected 0x12)
2020-10-23 07:15:09.197 Info, Node025, Request RTT 40 Average Request RTT 81
2020-10-23 07:15:09.197 Detail,   Expected callbackId was received
2020-10-23 07:15:09.197 Detail,   Expected reply was received
2020-10-23 07:15:09.197 Detail,   Message transaction complete
2020-10-23 07:15:09.197 Detail, Node025, Removing current message
2020-10-23 07:15:09.197 Info, Node025, Sending (Send) message (Callback ID=0x13, Expected Reply=0x04) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=25): 0x01, 0x0d, 0x00, 0x13, 0x19, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0x13, 0x81
2020-10-23 07:15:09.212 Detail, Node025,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-23 07:15:09.212 Detail, Node025,   ZW_SEND_DATA delivered to Z-Wave stack
2020-10-23 07:15:09.371 Detail, Node025,   Received: 0x01, 0x07, 0x00, 0x13, 0x13, 0x00, 0x00, 0x10, 0xe8
2020-10-23 07:15:09.371 Detail, Node025,   ZW_SEND_DATA Request with callback ID 0x13 received (expected 0x13)
2020-10-23 07:15:09.371 Info, Node025, Request RTT 173 Average Request RTT 127
2020-10-23 07:15:09.371 Detail,   Expected callbackId was received
2020-10-23 07:15:09.507 Detail, Node025,   Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x19, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x03, 0x40, 0xe0
2020-10-23 07:15:09.507 Info, Node025, Response RTT 309 Average Response RTT 387
2020-10-23 07:15:09.508 Info, Node025, Received a MultiChannelEncap from node 25, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2020-10-23 07:15:09.508 Info, Node025, Received SwitchMultiLevel report: level=64
2020-10-23 07:15:09.508 Detail, Node025, Refreshed Value: old value=0, new value=64, type=byte
2020-10-23 07:15:09.508 Detail, Node025, Changes to this value are not verified
2020-10-23 07:15:09.508 Detail, Node025,   Expected reply and command class was received
2020-10-23 07:15:09.508 Detail, Node025,   Message transaction complete
2020-10-23 07:15:09.508 Detail, Node025, Removing current message
2020-10-23 07:15:09.508 Detail, Node025, Notification: ValueChanged
2020-10-23 07:15:10.139 Detail, Node025,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x19, 0x03, 0x26, 0x03, 0x00, 0xcd
2020-10-23 07:15:10.139 Info, Node025, Received SwitchMultiLevel report: level=0
2020-10-23 07:15:10.139 Detail, Node025, Refreshed Value: old value=64, new value=0, type=byte
2020-10-23 07:15:10.139 Detail, Node025, Changes to this value are not verified
2020-10-23 07:15:10.139 Detail, Node025, Notification: ValueChanged
2020-10-23 07:15:10.604 Detail, Node025,   Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x19, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x08, 0x04, 0x00, 0x63
2020-10-23 07:15:10.604 Info, Node025, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Power Management event:4, status=255
2020-10-23 07:15:10.604 Detail, Node025, Refreshed Value: old value=0, new value=0, type=byte
2020-10-23 07:15:10.604 Detail, Node025, Changes to this value are not verified
2020-10-23 07:15:10.605 Detail, Node025, Refreshed Value: old value=0, new value=0, type=byte
2020-10-23 07:15:10.605 Detail, Node025, Changes to this value are not verified
2020-10-23 07:15:10.605 Detail, Node025, Refreshed Value: old value=4, new value=4, type=byte
2020-10-23 07:15:10.605 Detail, Node025, Notification: ValueChanged
2020-10-23 07:15:10.612 Detail, Node025, Notification: ValueChanged
2020-10-23 07:15:10.621 Detail, Node025, Notification: ValueChanged
2020-10-23 07:15:10.634 Detail, Node025, Notification: ValueChanged
Ingen som har noe tips til hva som kan være problemet?
Jeg tenkte først at det var et den gikk i dvale, men ifølge zwave-config så er den awake. Den kommer seg alltid etter hvert når jeg har forsøkt å slå på lyset et par ganger, men ser ikke noe klart mønster her.
Har i grunn plagdes med denne siden var ny.
24 minutes ago, ZoRaC said:
Er det samme problem med bryter? Prøvd å ekskludere/inkludere? Fabrikknullstille?
Litt usikker på hva du mener med bryter. Pr nå så har jeg ingen Fibaro switch, hvis det er det du tenker på?
Ikke ekskludert/inkludert eller reset nei. Hadde håpet å finne en løsning uten det da den er litt fysisk utilgjengelig for øyeblikket...
Tenkte på om du hadde en vanlig lysbryter tilkoblet, for manuell styring.
Nei, det har jeg ikke.
Den er koblet i en veggboks som er utilgjengelig uten en del styr. Er typisk at det er akkurat denne og ikke alle andre enhetene som jeg lett får tak i som har problemer... :)
Er det ikke noe i loggen som indikerer hva som kan være problemet?
