Jeg har en Fibaro Dimmer 2 som er utrolig treg i blant.. Noen ganger skrur den på lyset på under 1sek og andre ganger kan det ta opptil 20sek.
Det er ikke langt til neste enhet, og alle andre dingser rundt fungerer bra.
Noen som har tips om hvordan jeg kan feilsøke?
Kjører UZB1 på Open Zwave og Hassio.
Ozw log:
021-01-11 10:47:47.947 Info, Node037, Sending (Send) message (Callback ID=0x3e, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=37): 0x01, 0x0a, 0x00, 0x13, 0x25, 0x03, 0x26, 0x01, 0x63, 0x25, 0x3e, 0x9f
2021-01-11 10:47:47.958 Detail, Node037,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2021-01-11 10:47:47.958 Detail, Node037,   ZW_SEND_DATA delivered to Z-Wave stack
2021-01-11 10:47:48.053 Detail, Node037,   Received: 0x01, 0x07, 0x00, 0x13, 0x3e, 0x00, 0x00, 0x09, 0xdc
2021-01-11 10:47:48.053 Detail, Node037,   ZW_SEND_DATA Request with callback ID 0x3e received (expected 0x3e)
2021-01-11 10:47:48.053 Info, Node037, Request RTT 107 Average Request RTT 100
2021-01-11 10:47:48.053 Detail,   Expected callbackId was received
2021-01-11 10:47:48.053 Detail,   Expected reply was received
2021-01-11 10:47:48.053 Detail,   Message transaction complete
2021-01-11 10:47:48.053 Detail, Node037, Removing current message
2021-01-11 10:47:48.053 Info, Node037, Sending (Send) message (Callback ID=0x3f, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=37): 0x01, 0x09, 0x00, 0x13, 0x25, 0x02, 0x26, 0x02, 0x25, 0x3f, 0xfc
2021-01-11 10:47:48.065 Detail, Node037,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2021-01-11 10:47:48.065 Detail, Node037,   ZW_SEND_DATA delivered to Z-Wave stack
2021-01-11 10:47:48.164 Detail, Node037,   Received: 0x01, 0x07, 0x00, 0x13, 0x3f, 0x00, 0x00, 0x0b, 0xdf
2021-01-11 10:47:48.164 Detail, Node037,   ZW_SEND_DATA Request with callback ID 0x3f received (expected 0x3f)
2021-01-11 10:47:48.164 Info, Node037, Request RTT 111 Average Request RTT 105
2021-01-11 10:47:48.164 Detail,   Expected callbackId was received
2021-01-11 10:47:48.233 Detail, Node037,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x25, 0x03, 0x26, 0x03, 0x63, 0x92
2021-01-11 10:47:48.233 Info, Node037, Response RTT 179 Average Response RTT 179
2021-01-11 10:47:48.233 Info, Node037, Received SwitchMultiLevel report: level=99
2021-01-11 10:47:48.233 Detail, Node037, Refreshed Value: old value=0, new value=99, type=byte
2021-01-11 10:47:48.233 Detail, Node037, Changes to this value are not verified
2021-01-11 10:47:48.233 Detail, Node037,   Expected reply and command class was received
2021-01-11 10:47:48.233 Detail, Node037,   Message transaction complete
2021-01-11 10:47:48.233 Detail, Node037, Removing current message
2021-01-11 10:47:48.233 Detail, Node037, Notification: ValueChanged
2021-01-11 10:47:49.041 Detail, Node037,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x25, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x6d, 0xab
Og screenshot fra noden i HA:
