i et desperat forsøk har jeg kjørt restore til en 3 dager gammel snapshot, men heller ikke her fungerer z-wave nettverket lenger. Ingen ting har endra seg siden i går kveld kl 23, bortsett fra at z-wave ikke vil starte.
Noen tips?
2021-01-15 14:26:51.160 Always, OpenZwave Version 1.4.3469 Starting Up
2021-01-15 14:27:01.136 Info, Setting Up Provided Network Key for Secure Communications
2021-01-15 14:27:01.136 Warning, Failed - Network Key Not Set
2021-01-15 14:27:01.136 Info, mgr,     Added driver for controller /dev/serial/by-id/usb-0658_0200-if00
2021-01-15 14:27:01.141 Info,   Opening controller /dev/serial/by-id/usb-0658_0200-if00
2021-01-15 14:27:01.142 Info, Trying to open serial port /dev/serial/by-id/usb-0658_0200-if00 (attempt 1)
2021-01-15 14:27:01.172 Info, Serial port /dev/serial/by-id/usb-0658_0200-if00 opened (attempt 1)
2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2021-01-15 14:27:01.174 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2021-01-15 14:27:01.174 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-15 14:27:02.175 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-01-15 14:27:02.175 Detail, contrlr, Removing current message
2021-01-15 14:27:02.175 Detail, contrlr, Notification: Notification - TimeOut
2021-01-15 14:27:02.176 Detail,
2021-01-15 14:27:02.176 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2021-01-15 14:27:03.177 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-01-15 14:27:03.177 Detail, contrlr, Removing current message
2021-01-15 14:27:03.177 Detail, contrlr, Notification: Notification - TimeOut
2021-01-15 14:27:03.177 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2021-01-15 14:27:04.178 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-01-15 14:27:04.178 Detail, contrlr, Removing current message
2021-01-15 14:27:04.178 Detail, contrlr, Notification: Notification - TimeOut
2021-01-15 14:27:04.184 Detail,
2021-01-15 14:27:04.184 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2021-01-15 14:27:05.186 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-01-15 14:27:05.186 Detail, contrlr, Removing current message
2021-01-15 14:27:05.187 Detail, contrlr, Notification: Notification - TimeOut
2021-01-15 14:27:05.187 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2021-01-15 14:27:06.189 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-01-15 14:27:06.190 Detail, contrlr, Removing current message
2021-01-15 14:27:06.190 Detail, contrlr, Notification: Notification - TimeOut
Endret av hjemmedude
  • hjemmedude endret tittelen til Z-wave nettverk kan ikke starte - feilsøking? - fiksa.
