Har kjøpt meg en https://www.elektroimportoren.no/namron-z-wave-4-kanaler-fjernkontroll/4512711/Product.html
Fant ingen config til zwcfg slik at jeg kunne bruke zwave.scene_activated, så laget en, denne gjør så man kan bruke alle 12 knappene til og aktivere scener/automatiseringer.
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="4" innif="true" scenecount="12">
	<Instance index="1" />
	<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
  	<Value type="int" genre="user" instance="1" index="1" label="Scene 1 On" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="2" label="Scene 1 Off" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="3" label="Scene 2 On" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="4" label="Scene 2 Off" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="5" label="Scene 3 On" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="6" label="Scene 3 Off" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="7" label="Scene 4 On" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="8" label="Scene 4 Off" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
  	<Value type="int" genre="user" instance="1" index="9" label="Scene 5 On" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="10" label="Scene 5 Off" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="11" label="Scene 6 On" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
	<Value type="int" genre="user" instance="1" index="12" label="Scene 6 Off" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
</CommandClass>
